Old 01-11-2007, 07:14 PM   #1381
syndr0me's Avatar
Trader Rating: 32 (100%+)
I have no doubt the car designer is infinitely more wise than I, which is why I'm asking, not criticizing. I was under the impression that it's beneficial to keep weight close to the centerline of the chassis. This car appears to be going against that theory. Has AE seen something in their testing that leads them to believe otherwise? If so, it's interesting to contrast that with what's on the horizon for other companies doing quite the opposite, like the new Schumacher and Corally.
There's also the question of balance with future technology like BL and LiPo. The weight bias is quite a bit different with that setup.
I'm not trying to sound critical, I'm really just curious because I think the design process of a touring car is intriguing, and seeing the evolution of a prototype such as this is as close as most of us will ever get to designing a car.
syndr0me is offline   Reply With Quote
Old 01-11-2007, 07:42 PM   #1382
Kevin Boyle's Avatar
OK AE just keep it coming, the loyal fans are behind you.
JUST BRING IT
Served
Later
Kevin Boyle
Kevin Boyle is offline   Reply With Quote
Old 01-11-2007, 08:20 PM   #1383
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
Well let me first say I don't know everything and I could be completely wrong about the following comments.
One of the reasons for the non-vertical inner ballstuds is that you now have vertical ballstuds in the rear of the car and you always had them in the front of the car as well. You fine adjustments can be made there.
The motor sits like it does because it has its own seperate mounting plate that is attached to the rear bulkhead. At least the ones that I saw and what you seen on here.
The diff outdrives will be new plastic, not like the TC3/4 and will be able to handle modified motors.
The aluminum will be blue.
I couldn't tell for sure but it did look like you could adjust the diff height and belt tension on the car. Key word is it looked like it, I did not ask.
Ok now for the disclaimer part. I am not affliated with Team Associated and I never have been and probably never will be. I took the time to sit down with Bob and discuss it at the Novak race. The information that I have provided might not be correct when the production kit comes out.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-11-2007, 08:28 PM   #1384
Here are a few things to help you all out! We are making very good progress towards a great setup! Looking foward to snowbirds!!!
As far as balancing goes, the car is light! All steal screws and I had to put a 1/2oz of lead next to the servo and the car felt very balanced(I use a low profile ko servo) and just made weight with a dna body. With the parma I had to add another 1/2 oz.
As for the white outdrives, they are delrin-just protypes.
Hope this helps, Walter
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 01-11-2007, 08:30 PM   #1385
yep, there are 4 height adjustments for the diffs
Old 01-11-2007, 08:48 PM   #1386
Regional Moderator
FroBoy's Avatar
Walter, e-mail me when you get the chance,
tpqlfyer@cox.net
Alex Sturgeon
Team Losi Racing, Spektrum, Dynamite, Thunder Power, HobbyTown USA Hobbyplex
Proud member of the Scale Hobby Interest Team!
www.hobbyplexraceway.com
FroBoy is offline   Reply With Quote
Old 01-11-2007, 10:54 PM   #1387
Rick Hohwart's Avatar
Originally Posted by stuey
hey rick is there any reason on that peak motor the older style end bell is used not the v2 is it beter on the 19t motor also has it got the laydown or standup brush cant remeber if it was the orion element or the peak dynasty with the laydown brushes
I am confident that the V2 endbell is better. But I did not use it for a couple of reasons. First it was not legal for this race. Second, there are fewer brush compound choices. I still think I never geared the motor correctly. It was fast, but not fast enough.
We do have a new 19T motor whioch has been sold in Europe the last month or so. We will have it in the States in about 60 days. Look for Komodo-ish performance.
Surprisingly, Trinity was able to introduce a new non-legal (per Scotty's rules) motor at this race by offering it to the general public through the on-site hobby shop. Had I known about this allowance, I could have had some new Dynasty versions flown in from Europe and sold them in the store. And run one myself.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 01-11-2007, 11:23 PM   #1388
rocketron's Avatar
Trader Rating: 16 (100%+)
a very quick motor this new version
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 01-12-2007, 06:28 AM   #1389
ttso's Avatar
I'm SUPER GLAD TC5 is using metric system. Just for that, I WILL BUY ONE!!
But please remember to release asphalt spec for non-US players. I don't want to dremel the chassis to make it flex for asphalt.
Started with TC3FK 3yrs ago, going to back on AE TC5.
ttso is offline   Reply With Quote
Old 01-12-2007, 06:33 AM   #1390
ttso,
I think they wil produce the car with asphalt in mind and have the hop ups for the US drivers. That would the best way to market the car. The US drivers normaly race carpet in the winter. but there have been some indoor tracks that race carpet all year round.
Later
Kevin Boyle
Old 01-12-2007, 06:43 AM   #1391
Just wondering, is it possible that AE actually outsource production of the car to some asian or european vendors ? hence, it is using metric system. I seriously doubt anything made in US will be metric.
ongbenghui is offline   Reply With Quote
Old 01-12-2007, 06:49 AM   #1392
ttso's Avatar
Just in case you don't know, even NASA decide to use metric system on mission to send human back to moon.
It's not a matter of where it made. Factory in non-US territory would do imperial system if design ask for.
Old 01-12-2007, 07:02 AM   #1393
Asian is more likely.
Team BSR
Team Power Push
Protoform Race Bodies
KSKT Racing - #1 in SK Racing Chassis
Darkside Motorsports - "WE ARE WHAT'S NEXT." - www.darksidems.com
THE DARKSIDE is offline   Reply With Quote
Old 01-12-2007, 07:11 AM   #1394
OK Guys,
Let get things straight TTR did purchase AE a while back but did not change the way AE developes their cars and their day to day operations. The big impact was how the cars are being produced. TTR is producing the parts for the TC5 and they are overseas. I believe (correct me if I am wrong) but they use metric in their kits, hence the TC5 using metric screws and bearings. Hope that answers the questions.
Tony or Brent please correct me if I am wrong.
Later
Kevin Boyle
Old 01-12-2007, 07:18 AM   #1395
STLNLST's Avatar
Trader Rating: 17 (100%+)
You got a PM
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
