Old 01-08-2007, 07:52 PM   #1336
RCpurplecow's Avatar
I just want to get the tc5 so I can have a trilogy of ae tc's. that and it's gonna be the fastest car ever
when's the next big race for the tc5?
TEAM SRU
FT TC5
NoVak
rematch batteries
RCpurplecow is offline   Reply With Quote
Old 01-08-2007, 07:55 PM   #1337
Super Moderator
Kraig's Avatar
Trader Rating: 69 (100%+)
My guess is the Snowbird's race unless a few are going up to Canada. Oh wait, isn't there a race overseas coming up soon? Maybe Juho and Craig will be at that one?
Ok, maybe I should have said I don't really know for sure.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-08-2007, 08:01 PM   #1338
Are the shock bodies and ballcups really the only parts that carry over? What about the VCS2 shock caps, shock springs, hub bearings and 4-40 hardware?
I still race a TC3, my parts box is full of this stuff.
chance is offline   Reply With Quote
Old 01-08-2007, 08:03 PM   #1339
Mark G's Avatar
Send a message via AIM to Mark G
I think Scotty is going to Canada for the magma race in a few weeks
but Iam not sure if he has the tc5, I could be mistaken though
Mark G is offline   Reply With Quote
Old 01-08-2007, 10:06 PM   #1340
51
51's Avatar
Yes there are a few other parts that carry over, but the major ones are the shock bodies, VCS2, Springs, Ballcups, Tierods, Diff Hardware, Ballstuds, Body Posts...I'm sure I'm still missing a few small items. Most of the screws will be 2mm metric threads. Your 5/64 (2mm) wrench will fit most screws in the car. The bearings will also be all metric spec.
Brent Thielke - Associated Team Manager
** AE Forum - www.aeforums.co.uk **
51 is offline   Reply With Quote
Old 01-08-2007, 10:08 PM   #1341
51
51's Avatar
Yes, the DHI Cup is this coming weekend. Craig Drescher, Juho Levanen, Christer Andersson and our new team member Joel Myrberg will all be using the prototype car at the race.
Old 01-08-2007, 10:13 PM   #1342
Kyew's Avatar
Originally Posted by 51
Most of the screws will be 2mm metric threads. The bearings will also be all metric spec.
that shld help a bit in boosting it's sales in the asian markets..........
all we have to decide is what to do with the time that is given to us.......
Kyew is offline   Reply With Quote
Old 01-08-2007, 10:27 PM   #1343
RoachRacing's Avatar
Send a message via ICQ to RoachRacing Send a message via AIM to RoachRacing Send a message via Yahoo to RoachRacing
Brent - You going to give us a date?
We need this before 3/20 which is the new date for a certain other car.
RoachRacing is offline   Reply With Quote
Old 01-09-2007, 02:06 AM   #1344
Patriiick's Avatar
what ? a new xray, again ?? !
Patriiick is offline   Reply With Quote
Old 01-09-2007, 03:22 AM   #1345
Hi all,
im lucky about that AE will use all in Metric, thats the right way when u Build a Car for the World Market.
Bye,
Marcel
BlueSilver is offline   Reply With Quote
Old 01-09-2007, 06:13 AM   #1346
Big Daddy Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to Big Daddy Boomer
Scotty will be sporting the TC4 in Canada. He placed 4th in the Brushless "A" main at the Novak.
How about Fred Kellner (local racer) Holding TQ in Stock Rubber until the final round with a TC3! WOW he had that thing dialed!
Big Daddy Boomer is offline   Reply With Quote
Old 01-09-2007, 08:40 AM   #1347
Trader Rating: 28 (100%+)
I sure hope so, every one they release is a step or two better than the last one......
Mdoc is offline   Reply With Quote
Old 01-10-2007, 08:58 AM   #1348
Rick Hohwart's Avatar
Originally Posted by Kevin Boyle
Rick ,
I think you said there was good base set up that was being tested how did that go?
Later
Kevin Boyle
The set-up was pretty good as a starting set-up. Due to the high traction conditions, I made some big and small changes but ended up pretty close to what I used in Cleveland. The biggest difference was a rear roll-center change. Smaller change included slightly heavier oil and springs in the front. And slightly softer springsin the rear.
The race was a bit of a disaster for me. I started with servo and radio problems. Intermittent glitching at the transponder loop caused problems at the fastest part of the track just as you entered the sweeper at the end of the straight. And a non-centering servo was finally changed one I realized that it was a problem (rather than a chassis issue as I thought it was).
Unfortunately I did not drive very well in modified. I could turn copmpetitive lap times and continuallyimproved the car diring qualifying. But I could not string a full run together. My best run was actually an A-main run until I crashed two laps in a row near the end of the heat. The car was perfect and I ended up throwing it away
The car was even better in the main but a mistake on my part sent me into a wall and out of the race.
My first 19-turn race went OK. I did not have enough tires to run new (better) ones in this class so I ran chunked re-runs etc. The idea was to use this as a practice class and for something to do. Next time I will be prepared to give it 100%.
All in all, the car was very good. It is a shame that the results were not as good as they could have been.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 01-10-2007, 09:13 AM   #1349
Kevin Boyle's Avatar
Rick,
Thanks for the update, we all have had races like that. Good to hear the car is coming along and the ability to tune the car in for those type of track conditions. Looks like the TC5 will be more tunable then the TC4. I thought the TC4 was good step forward from the TC3 and the FT TC4 even better. Look out for the TC5.
Later
Kevin Boyle
Kevin Boyle is offline   Reply With Quote
Old 01-10-2007, 10:08 AM   #1350
MleedM's Avatar
Default ball cups
Is it possible for AE to use the ball cups that are on the X-Ray ... where you can unbolt the ball without having to remove the cup? I don't know the technical name for them, but they are slick.
MleedM is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
