Old 11-17-2012, 03:38 PM   #13156
Originally Posted by DOTHOPPER View Post
How about the shocks ? have you guys upgraded them ?
Upgrade them why? I find no issues with the stock shocks.
We use Losi pistons in them instead of the AE ones and drill a small hole in the plastic cap to achieve zero rebound.
Jeff Cohen
www.rcgears.net, www.carcar.ca, www.trukz.ca
Thanks to my Sponsor: Shred-A-Can Metal Recyclers LTD
www.shredacan.com
chongo is offline   Reply With Quote
Old 11-17-2012, 05:05 PM   #13157
can you take a photo of where the holes are drilled
DOTHOPPER is offline   Reply With Quote
Old 11-17-2012, 05:59 PM   #13158
Turn the cap over you will see a small 1/2 drilled hole on the outter edge. Drill it out fully. 1/32 or 3/64, around 1mm.
Don't use the blue rebound foams when you rebuild the shocks.
FYI everything I type is in this thread with a search.
Jeff Cohen
www.shredacan.com
Old 12-04-2012, 10:02 PM   #13159
Smile Re...TC5
Hey guys, I just traded for 2 TC5s, One is new assembled but never run, The other set up for rubber on carpet, it is in very good shape. The guy I got them from can't find the spare arm mounts, arm mount shims, or wheel base shims. I have been able to find all these parts on Ebay except the arm mounts, I did find TC6 arm mounts are they the same as the TC5. Thanks.
TJ
THEBIGBULL is offline   Reply With Quote
Old 12-05-2012, 04:54 PM   #13160
TJ
If you mean ASC31195 Arm mounts, I asked a team driver and he thinks the plastics are the same except the tc6 (asc31321) has a new 0 offset and the tc6.1 ones have an offset variety, so you can space them 2mm less.....his words not mine.
For ASC31197 which is the arm mount nut.
The tc5 mount nuts are threaded the tc6 (asc31122) are not.
To use the tc6 mount bushing you will need longer screws and 3mm lock nuts.
Jeff Cohen
www.shredacan.com
Old 01-11-2013, 07:58 PM   #13161
So when drilling out your shock caps you leave the blue foams out and just use the bladder?
Associatedkid is offline   Reply With Quote
Old 01-11-2013, 10:30 PM   #13162
Jdtl15's Avatar
Trader Rating: 23 (100%+)
Yes, don't use any of the foam. That will give you no rebound.
Jdtl15 is offline   Reply With Quote
Old 01-12-2013, 11:46 AM   #13163
IndyHobbies.com's Avatar
I've got two TC5's. One I have set up for VTA. Its great. Does dandy with plenty of grip all around.
The other TC5 is for my 17.5 TC racer. I've got it set up per the manual for the TC5R page. In the rear, I have 2 degrees of negative camber and about 3 degrees of toe like the set up sheet suggests. Tires are sweeps and/or JACO Blues.
I just can't seem to get very good rear traction. Seems like it needs weight in the back, but that its the proper way to solve the problem I'm sure. I'm running blue springs up front and greens in the back. Arm mounts are #1's.
Any suggestions?
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 01-12-2013, 07:56 PM   #13164
Any suggestions?
What section of the turn are you giving up rear traction, going into the turn, through the center or on exit?
cegpcola is offline   Reply With Quote
Old 01-13-2013, 07:27 AM   #13165
Seems to be mostly when I'm going into the turn. The rear breaks loose at that point and if I feather the throttle I usually fish tail a little. If I brake, often I spin out.
USVTA #144
Old 01-13-2013, 12:28 PM   #13166
You might want to add 1 degree of anti-dive up front to keep a little of the weight from transferring under breaking. I would start with keeping the 2A rear mount and change the forward mount to 1A assuming that you are running the Base runbber setup. Might also try to drop the rear ride height to 4.5mm from 5.0mm. It sounds like the car is transferring to much weight under breaking or when the car starts to roll entering a turn. If you can limit that weight transfer to the front in these conditions, you will keep a little more weight over the rear of the car which will keep a bit more traction at the rear tires. This would be a starting point to get the car to calm down a little.
Kurtis
Old 01-14-2013, 11:27 AM   #13167
Kurtis
Good suggestions. Thank you. I will print this and give it a shot this weekend. I can't drop my ride height for competition, but for club racing I can. 5mm is the minimum during races.
USVTA #144
Old 01-14-2013, 12:40 PM   #13168
SS LS1's Avatar
Indy, loose rear on corner entry has been a common problem with several TC5 cars at our track. You can try reducing the amount of droop in the rear suspension. Less rear droop will reduce the amount of weight transferring to the front when off power and will keep more weight on the rear tires increasing rear grip. As a test try only 1mm over rear ride height and see how that feels. If the rear is too planted then try 1.5mm over ride height and see if that frees the car back up. Droop changes of only 1/2mm can be pretty noticeable IMO.
SS LS1 is offline   Reply With Quote
Old 01-14-2013, 02:22 PM   #13169
Thanks SS. Like I say, my VTA version works great. Its just the one set up like a normal TC that's loose. Of course, I imagine much of that is the tires. I purchased both of them used, but in nice shape. I took them apart and followed AE's manual set up initially.
USVTA #144
Old 01-14-2013, 03:40 PM   #13170
The droop change is also a good place to look at limiting weight transfer. Good suggestion as well.
Kurtis
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
