Old 05-11-2012, 07:45 PM   #13111
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
same ones. there is only one losi lcd. they $40 though. might be worth getting a set as they are quite popular to use on a number of cars.
rather than spend money, i learned to drive around the chatter. slow in, turn, gently pull it out of the turn.
if my car was sounding like a pos, i probably took the corner too fast on too much throttle and wasn't going any faster than if i just slowed and turned in, off power.
valk is offline   Reply With Quote
Old 05-12-2012, 09:47 PM   #13112
maN you been a big help thanks again!!
cool i got a set on my tc4...do i have to ream out the c-hub like on the tc4 so they would fit
starrx is offline   Reply With Quote
Old 05-13-2012, 05:25 PM   #13113
valk's Avatar
im sure the c hubs are very similar, so ill say probably. glad if i can be of help. I wont be racing my tc5 as much this year, but if we do a modified class i might..
dont let the bashing get to you. pretty common for people to chime in on how the tc5 was a great car in its day blah blah blah. tc6 isnt really THAT different though. properly setup and driven, this car will last you a good long while.
survived my first year of noobness with no broken parts even =)
Old 05-13-2012, 08:57 PM   #13114
IL_AudiRacer's Avatar
Trader Rating: 58 (100%+)
Selling the last of my TC5 parts if anyone's interested great deal
http://www.rctech.net/forum/r-c-item...c5r-parts.html
FS-Samsung-galaxy-tab-3g-verizon
**PLEASE CHECK MY OTHER ADDS LOTS FOR SALE**
Garage: ITS ALL FOR SALE LOADED Tamiya M03R,LOADED AE TC5R (VTA), LOADED Duratrax Vendetta ST
IL_AudiRacer is offline   Reply With Quote
Old 05-13-2012, 09:13 PM   #13115
i do pretty good with my tc5..im in the top 5 @ my track & i make the A @ local big races...but i do think i can get more out of the car as far as corner speed..but since i fix my cvd's ill see if my lap times will go down alil bit more
Old 05-13-2012, 10:08 PM   #13116
Another thing to consider when using cvd's up front, is that all the binding in the turns will cause a slight drainage of battery power, and therefore less speed ! Switching to lcd type drives can potentially reduce your laptimes....
bertrandsv87 is offline   Reply With Quote
Old 05-13-2012, 11:11 PM   #13117
valk's Avatar
your prob better than i am then. our amain is pretty locktite. always the same crew, but they been doing it for years and years. im just happy to be BUMPING to the amain in my first year ha.
those lcds wouldn't be a bad thing to pick up if i keep this tc5 around too. checking out team magic for the moment though, so as far as our club goes, my 8Turn tc5 is a basher ha.
Old 05-23-2012, 07:32 PM   #13118
rcwanaB's Avatar
Trader Rating: 14 (100%+)
Default Bearing upgrade
I'm VTA racing a TC5R. Class runs single cell lipo and 17.5 motors so trying to get the most out of my driveline. Problem is i'm too cheap to go ceramic bearings. Is there a bearing kit somewhere between the $10 factory kit and the $90+ ceramic kits? I found a Boca econo/sport metal shielded bearing kit for $20. Are they going to be any better than the Assoc. factory kit? What do you guys think.
rcwanaB is offline   Reply With Quote
Old 05-23-2012, 07:56 PM   #13119
valk's Avatar
I just run protek bearings in mine honestly. just lightly oil them or replace them as needed.
good luck getting even the oem kit for $10 though. last i checked, AE wanted $50 for em. i got a tube of Protek metal shielded dif bearings and wheel bearings for $20 and just chuck em out if they go bad.
i dont think ceramic bearings are really worth it unless racing at a big event in mod. though, i do have a set of ceramic dif balls for my 12th scale so maybe shouldnt talk?
Old 05-23-2012, 08:24 PM   #13120
rcwanaB's Avatar
Yeah your rite. Not sure what assoc. bearing kit i was looking at cause now i'm seeing the cheapest factory team kit is $43 plus shipping. I forgot to mention i got my car second hand almost 2 years ago and have only had to replace a couple bearings over that time. Just thinking it may be a good idea to replace them all.
Old 05-23-2012, 10:34 PM   #13121
Try Avid:
http://www.avidrc.com/flexkit/?kit=396&kitname=TC5
Ultima RB5-SP2/HB D4 WCE/AE TC5R/AE 18R/Traxxas Blue Eagle
Sponsoring Futaba/Tekin/Thunder Power with my hard earned cash.
BlueEagle is offline   Reply With Quote
Old 05-29-2012, 08:59 PM   #13122
DoubleRJef's Avatar
Trader Rating: 56 (100%+)
Ive tried to search the thread and scrolled through some of the pages but havent seen any chatter. Would the Exotek TC5X chassis be a good choice for 17.5 Blinky? I purchased the AE lipo tray for my TC5 and had the lipo move 3 times during racing. Pinned the front belt up against the servo horn and put a groove in it as well as the lipo case.
Futaba
AKA
Race'Em RC and Hobbies
MIP
CBs Custom RC
DoubleRJef is offline   Reply With Quote
Old 05-29-2012, 09:26 PM   #13123
When I built my TC5, I drilled new holes in the chassis, to move the lipo out to balance the car. To keep the battery from moving inwards, I mounted 2 servo mounts on the stock inboard battery holder locations, and added some foam blocks to shim up the space. Worked great for me, never had any issues.
red7fifty is offline   Reply With Quote
Old 05-29-2012, 09:31 PM   #13124
TC5 lipo tray
I also cut the tab off, as well as drilled 2 new holes in the chassis.
Old 05-30-2012, 03:41 PM   #13125
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Ive run into the same problem with both of my TC5s. I solved it by mounting some small weights on the inside of the battery to the chassis. They are far enough back to not interfere with the belt or servo horn, but are able to keep the lipo from sliding into them. I just mounted it with some double sided tape and has worked great for both my 17.5 blinky and VTA setups. More weight can also be added further back and act as a way of tuning the car.
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
