Team Associated TC5
What gear ratio (spur, pinion, pitch) and FDR would you guys recommend for the following motor:
21.T Brushless
Silver Can
27T Stock
21.T Brushless
Silver Can
27T Stock
Magic number for 21.5T Brushless is around 3.5, was wondering if I can use a 48pitch 69T spur and 38T pinion. Will those two gears mesh together?
I have a little more weight to add to get up to 1450grams. I run the battery forward and the rx on the servo to get some weight on the left side forward also. Where do you think other 40 grams should go?
Check your side to side balance....put the weight on the lighter side, and try to get a balanced chassis.
If you already have it balanced side to side, then put the weight as close to the middle and centerline of the chassis as possible.
All the weight towards the Center, is a good starting point......too much weight towards the back, will likely give it a tendency to oversteer (back end swinging out)....so, towards the front will make it easier to drive.
Suggestions on belt tightness?
I understand that the tension on both belts should be as equal as possible so that both front and back wheels pull as hard, and at the same time, as each other.
I've bought two used TC5's. One came to me with the belts somewhat loose (3/8" up and down on the large one) and the other the belts came very tight. Not guitar strings, but pretty darn tight.
What is considered normal? The manual addresses the mounts, but not really tension that I found.
My spur gear seems to be hitting the upper deck. The gear wobbles quite a bit. I think its time for a new gear adapter. Is the aluminum one worth getting?
I'll tell you next week since I just ordered one today, but I've got to think it is better than the plastic piece. I almost missed a race last night because of the plastic one and my spur gear is wobbling now too.
Hey, I just finished building my new TC5. I'm only just getting back into racing after a long break. This is a brand new original TC5 FT (with front & rear ball diffs and plastic outdrives), but I have used the stock standard "R" rubber tyre setup on the AE website (and not the too hard, foam tyre based kit settings).
Still getting used to painting, so don't laugh at my bodyshell too hard
Does anyone have any suggestions on where to put weight, and how much ? I was thinking perhaps 10grams each in front and in the rear of the battery ?
I will be ordering the AE lipo battery holder, and perhaps the front spool asap.
Cheers
Cheers
