Old 11-24-2011, 08:46 AM   #12991
Ffejdat's Avatar
I know some people in Minnesota are using Spec-R gear diffs in their TC5's, not sure which one they are using, I will find out. I think they are just shimming up the TC6 diffs...
Ahhhh, I could'a got a falcon!
Ffejdat is offline   Reply With Quote
Old 11-24-2011, 08:53 AM   #12992
Originally Posted by Gyr0 View Post
Anyone know if the spec-r tc6 gear diff will fit the tc5? or if spec-r make one for the tc5.
If you could find one that is wide enough (TC6 can in theory fit in) but you will need longer bones and TC6 is using belts (one on each side of spur) rather than next to each others like on TC5.
So you need a new gear diff to fit on the outside belt and the original spool to fit on the inside belt.This means that the long belt needs to be back to the original place and not outside to help move electronics inboard.
Hope I am clear, I had a look at it but now my TC5 is gone.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-24-2011, 07:10 PM   #12993
Hexonox's Avatar
In theory, parts like diffs and cva's from the yokomo db5 should fit; since both chassis are very similar in design and appearance. I e-mailed spec-r and got a response of "We cannot confirm proper fitment of db5 parts to the tc5 and do not have any way of comparing the parts in question". I currently do not have the funds to justify ordering parts from spec-r to experiment. I would really like to know if their double jointed cv shafts will fit. So if anybody out there has any info on this topic it would be greatly appreciated.
Team F.T.N.S.
Kyosho MP9e TK I, XRAY XB4 2015, TD DEX210, TD DESC210, TD DETC410, Tamiya TA06 PRO, Tamiya M05/06, Serpent S100
Hexonox is offline   Reply With Quote
Old 11-24-2011, 07:56 PM   #12994
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
How much narrower are the TC6 bulkheads? can you measure the inner width olly?
I dont see the problem with fitting the tc6 dif with shims. worst case, im sure could could shim a few mm on the outdrives too.
valk is offline   Reply With Quote
Old 11-25-2011, 09:49 AM   #12995
there is actually a good bit, the thing is that the TC6 diff is going to end up more on one side than the other (because of diff/spur pulleys placement) but shimmed it will defenitely work.
then the issue is going to be the lengh of dogbones/CVA, one could end up too short or just catching.
If you move to yok diff and CVA ou have to change the bearings and wheel clamps (this is done on TC6) and I guess the CVA lengh is shorter than AE cause you have to dremel the Yok outdrives to fit the TC5/6.
I have fitted a Sakura zero gear diff to my TC6, but the teeth are just ok at rear but not good for the front. then I use Kyosho RRR V1 outdrives, but cannot use blades (too wide). There is a possibility to use the Sakura's outdrives with the width of TC5 (do not work on TC6, the CVA bones goes too deep)
If you are interested to try all this, I can sell you all the Sakura parts I have as I will be getting the new TC6 gear diff soon.
I hope my explanations are clear enough, I nearly got lost myself
Old 11-25-2011, 10:15 AM   #12996
IndyHobbies.com's Avatar
I've been driving TC3's for a couple of years and now have a almost new TC5. I've been really surprised by how different it drives. With the locked front spool, it pulls out of turns like a mule, but it seems like my backend fishtails much easier than what I was used to with a TC3. Same tires and traction compound on the TC5 as the TC3's
So is a looser backend normal would most of you agree for a TC5? Maybe I just need to get more laps and get used to it? Or, do I need to work on the set-up a little?
I checked the set up and its per the owner's manual. Rechecked too. I'm running it in USGT with a 21.5 and Solaris mediums.
Just looking for some suggestions.
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 11-25-2011, 10:53 AM   #12997
Owners setup was for Nimh batteries not Lipo, it does have a tendency a bit tail happy, if you never use a spool on front either it take a little getting use to.
They are some things to do to the the car for Lipo if you have not done it yet, reverse front/rear belts to move your electrics closer to the centre line will be the first.
Use softer springs than the original red/copper, silver front green rear is good with piston 2 and 40/35 oil or 40/40 (front/rear)
That is to start, see how you get on with this.
Old 11-25-2011, 10:56 AM   #12998
valk's Avatar
Try one of rick howarts outdoor setups. Found them to work quite well for the most part.
I set my car up starting with his 13.5 superstock setup and tweak. You
Might just need more rear droop. Made a vig difference for me with low traction carpet.
Old 11-26-2011, 11:51 AM   #12999
Thanks for the advice guys. Just what I hoped for. I've printed this page and will try your suggestions.
Scott
USVTA #144
Old 11-26-2011, 02:35 PM   #13000
sideways88's Avatar
Trader Rating: 34 (100%+)
Does any one know If the tc6 Blue screw kit will work on the tc5. I know I won't be able to use All of them but I like the blue a lot lol. And I need new screws on my car.
sideways88 is offline   Reply With Quote
Old 11-26-2011, 05:29 PM   #13001
Yes they should, most of them are the same, metric size.
Old 11-26-2011, 07:39 PM   #13002
sideways88's Avatar
cool i think i might pick a set up.
Old 11-27-2011, 12:18 PM   #13003
Default tc5
will the tc6 arms fit the tc5?
and would the new tc6.1 work?
the ? would be will they work on the 5??
J Blaze is offline   Reply With Quote
Old 11-27-2011, 04:16 PM   #13004
What's up everyone. I have quick question about the TC5 setup sheet. I've already read about 100+ pages of this forum (I gained alot of knowledge) and I still don't seem to find what I'm looking for. What do the FWD Arm Mount - RWD Mount Shims settings (under the suspension geometry settings) exactly refer to on the front and rear diagram? Examples: 2A, 3A. I understand just about everything else. Definitely a new builder of kits but I tend to become extremely methodical and careful when it comes to my hobbies haha. All of the members here have all been great to read about. Thanks
AETC5RDED is offline   Reply With Quote
Old 11-27-2011, 04:16 PM   #13005
What's up everyone. I have a quick question about the TC5 setup sheet. I've already read about 100+ pages of this forum (I gained alot of knowledge) and I still don't seem to find what I'm looking for. What do the FWD Arm Mount - RWD Mount Shims settings (under the suspension geometry settings) exactly refer to on the front and rear diagram? Examples: 2A, 3A. I understand just about everything else. Definitely a new builder of kits but I tend to become extremely methodical and careful when it comes to my hobbies haha. All of the members here have all been great to read about. Thanks
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
