Old 11-05-2011, 12:46 PM   #12976
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
very clean body, i like. my ntc3 came with the same one i think but 200mm. quite sharp.
I wish we ran gt. wanna run scale bodies.
valk is offline   Reply With Quote
Old 11-05-2011, 03:33 PM   #12977
Well, I had a very good look while I took my TC6 and TC5 appart at the same time, the idea was to see how to move the TC5 motor inboard using TC6 parts, by cutting the bulkhead part holding the spur gear/bearing assembly, it is possible to replace this with the new TC6 spur gear holders and motor mount.
New holes will have to be drilled.
There is then the issue of differentials to sort out, I do believe now that we could fit a geardiff in the rear and front, because of the spur gear being in the middle between the small 20 teeth gears, with shims there is enough space to make it fit as needed, right or left, but I need to look into this again to see if a TC6 diff is a better fit than TC5's.
Is someone interested in this mod or not? If you are I will carry on to investigate the possibility.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 11-05-2011, 06:26 PM   #12978
transplantlife's Avatar
Trader Rating: 43 (98%+)
Originally Posted by IndyHobbies.com View Post
Here's my new body I just airbrushed last night. Its an HPI Nissan 350Z. 190mm version. Turned out nice.
Faskolor metallic blue with a fake carbon fiber hood. Neon red perimeter stripe. Fits the TC5 chassis and front foam bumper really well. I will run it in USGT with a 21.5 at my local track R/CAR Association. www.RCARIndy.com
looks great!!
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 11-05-2011, 06:28 PM   #12979
Anyone have a good base set-up for VTA for the tc5r?
Old 11-05-2011, 11:54 PM   #12980
valk's Avatar
took the tc5 out tonight for some practice laps and DAMN that carpet is slippery.
gonna need some advice on setting the car up for low-medium traction carpet.
pretty much running rick howarts iic 2009 setup but the car was very slick. im sure the tires were too firm, cs32s, but we will be running jako blues for our big race which im told aren't much softer.
Old 11-07-2011, 04:44 AM   #12981
IndyHobbies.com's Avatar
I am putting a 21.5 Ballistic in my Associated TC5. Can anyone suggest a good starting point for pinion and spur?
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 11-07-2011, 04:18 PM   #12982
cherokee95's Avatar
Lots of variables in that question. Size of track being very important. Best way would be to ask some locals what they're running for FDR then look here. Hope that helps.
cherokee95 is offline   Reply With Quote
Old 11-08-2011, 03:08 AM   #12983
Thanks for the link and advice.
USVTA #144
Old 11-10-2011, 01:03 PM   #12984
I ended up with an 86 spur and 41 pinion. That puts me at an FDR of 4.29. Guess that's good enough to start with but some at my track are down around 3.5 with fans. I'll get some track time shortly to know if it was a good choice.
USVTA #144
Old 11-16-2011, 11:42 PM   #12985
Default Fix TC5 Slop for $4.00
I have (2) TC5 cars, and even when they were new, the ball cups were sloppy!
Just changed all the ends to the newer TC6 cups, and all slop is gone!
Part # 31305 Turnbuckle Eyelet, One pack, enough for the entire car.
In fact, they are so snug, I put a drop of shock oil on each. They will still need a break in period...so if you have a cheap servo, you might have centering issues....in which case, change out only a few at a time, otherwise, your steering might be too tight.
red7fifty is offline   Reply With Quote
Old 11-17-2011, 12:41 AM   #12986
Not a good idea, oil, it keeps dirt in ballcups and gets gritty, the way to loose the TC6 cups is to press gently on all side with a pliers when ballcup is on ball.
or
sacrifice a metal ball, with a cutting (wire/cable) pliers make two grooves in the ball (vertically) then put ball on drill and run your ballcups through it, this is the way I do.
Old 11-20-2011, 06:35 AM   #12987
I'm down to a 3.75 FDR now and still temps are only at 115-120...so more to go.
This a body I painted a while ago, but never mounted. Just now got it mounted on the Associated TC5 carpet beast. Its HPI's "Stiletto" body. Faskolor Key Lime Green with faux carbon fibre airbrushed on.
I can put 6mm offsets to pull out the rear tires in the wells a little, but I like that they are tucked under for racing. Running this one at www.RCARIndy.com in our USGT class.
Team Associated TC5-stilettotc5complete-001r.jpg   Team Associated TC5-stilettotc5complete-002r.jpg   Team Associated TC5-stilettotc5complete-003r.jpg
USVTA #144
Old 11-22-2011, 06:33 AM   #12988
frenchchris's Avatar
Default tc6
here some pictures
frenchchris is offline   Reply With Quote
Old 11-23-2011, 09:36 PM   #12989
Trader Rating: 20 (100%+)
Default Spec-R gear Diff.
Anyone know if the spec-r tc6 gear diff will fit the tc5? or if spec-r make one for the tc5.
Gyr0 is offline   Reply With Quote
Old 11-24-2011, 06:05 AM   #12990
Buckaroo's Avatar
Different width's between the bulkheads.
The TC5 is now 2 kits old with the TC6 having replaced it and the TC6.1 having replaced both of them. Chances of anyone investing R&D and production $ for new parts in a chassis that was always a marginal performer in the TC world and now so completely outdated is slim, at best.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
