Old 07-22-2011, 07:11 PM   #12856
Default Price versus value
I found TC5r's for sale for $199 shipping & tax included..... is this older car worth buying for that price? I would like to get into on road asphault
hilllbillly is offline   Reply With Quote
Old 07-23-2011, 05:36 AM   #12857
Buckaroo's Avatar
After having raced two TC5 chassis for 1 1/2 seasons in two different classes, and then changing to the TC6 and a Photon for this outdoor season...the answer to your question is "depends".
If you're going brushless and lipo to compete in a Touring Car class against other modern chassis, 110% "NO". By the time that you've applied all the fixes to the configuration to get it up to 90% of where a TC6 is out of the box, you're going to spend as much as a new TC6 and still not have the performance or tuning options. Been there, done that x2. Not happy!
If you're going mild RCGT or VTA, apply all of the brushless/lipo fixes, spring it light, and you'll be doing just fine.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 07-23-2011, 05:53 AM   #12858
Buckaroo's Avatar
Originally Posted by ptorlax18 View Post
I just searched through this massive thread for a 1/2 hour looking the info i wanted. But i couldnt find what i needed so ill ask. Can anyone give me a good starting point for gearing for rcgt with a 17.5 in 64 pitch. both the pinion and spur. thanks alot in advance
Depends on which motor you're using, but anything around a 4.0 for 17.5 blinky. Use a heatsink/fan and don't be afraid to gear it hot!
Tom Keith
Old 07-23-2011, 07:41 AM   #12859
koopesv's Avatar
Trader Rating: 18 (95%+)
I still run a TC5 and still have good results but I can see the difference compared to more updated cars. The car is fast but the infield is where it counts and its not up to par.
I wouldnt say dont get it just depends on what you want it for, Compete NO, racing here and there YES.
Durango - Speed Passion - Trinity
Gforce Hobbies Raceway
Urban Heat Racing
koopesv is offline   Reply With Quote
Old 07-23-2011, 09:15 PM   #12860
im just getting started in VTA on Carpet,
17.5 motor with a spec rubber tire rule.
whats the better chassis,,,
TC5R / TC5F / new TC6
toggle is offline   Reply With Quote
Old 07-24-2011, 05:36 AM   #12861
Chief's Avatar
Trader Rating: 14 (100%+)
What is the best "lipo fix"? I seen there are a few options?
Chief is offline   Reply With Quote
Old 07-24-2011, 07:31 AM   #12862
I made my own in carbon fiber, I moved the cell out (so that the female connector is outside of top deck for chassis balance) I thin down the top deck for flex, switch belts and spool/diff around so that the long belt is now running on the right side of servo saver post, that way I can fit my electronics closer to the center of chassis for balance.I use tape to hold the battery not to tweak the chassis with the battery bar.
This is the minimum to put your TC5 to Lipo spec.
Then you can get a motor mount that will bring your motor closer to the center line and cut the bottom parts of the front metal diff holders for more flex.
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 07-25-2011, 03:30 AM   #12863
Something like that:
lipo bar is for tc5, don't remember number, it is moved (new holes)
my car but it is now in other hands
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 07-25-2011, 05:02 AM   #12864
Buckaroo's Avatar
Yep, I did something similar...moved the stock lipo tray over 1/4 inch, flipped the belts, and changed motor mounts. In the end, the Exotech chassis turned out to be way more consistent and easier to drive.
Tom Keith
Old 07-25-2011, 05:10 AM   #12865
Yes I like the option Exotek for TC5, makes life easier and closer to TC6 setup
Old 07-25-2011, 07:20 AM   #12866
my lipo TC5R....
mos-leung is offline   Reply With Quote
Old 07-25-2011, 12:25 PM   #12867
I imagine that your chassis is not balanced with the lipo so close to the middle and the extra weights of electrics.
Did you check this?
Old 07-25-2011, 03:55 PM   #12868
My car was balanced.
But when I switch to TC6 my problems died
Regards!
Michal Abramowicz
Old 07-26-2011, 12:13 AM   #12869
Hi Michal
I was not talking about your car but Mos-Leung, he has the picture (small) on his post under yours.
regards,
Old 07-26-2011, 02:58 AM   #12870
Originally Posted by olly986 View Post
Hi Michal
regards,
No problem olly986
I found that for me in stock racing, unbalanced car (lighter side of lipo) about 15g max gives no difference
Regards!
Michal Abramowicz
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
