Old 03-16-2011, 07:46 AM   #12796
Bmr4life's Avatar
Trader Rating: 50 (100%+)
Originally Posted by Marius13 View Post
Too many RC's to list.
Bmr4life is offline   Reply With Quote
Old 03-16-2011, 12:54 PM   #12797
19_mustang_96's Avatar
Trader Rating: 99 (100%+)
Originally Posted by Buckaroo View Post
Boosted/non-boost? Rubber/foam? Indoor asphalt or carpet? Outdoor? ESC brand? Motor brand? Size of track?
Nonboosted. indoor carpet. novak gtb2 novak 17.5. medium to small
Kyosho Rb6
Kyosho Rt6
Sandpit RC Washtenaw RC Raceway Ithaca RC Raceway Hardwoods RC
19_mustang_96 is offline   Reply With Quote
Old 03-18-2011, 08:58 PM   #12798
Trader Rating: 82 (100%+)
What's a good gearing starting point with tekin rs and 17.5 fantom ion 2
Running on outdoor asphalt track
RsDrake77 is offline   Reply With Quote
Old 03-18-2011, 09:01 PM   #12799
pakk's Avatar
Trader Rating: 79 (100%+)
At Ripon I always ran 4.0ish NR and 6.6ish ramping.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 03-24-2011, 10:29 AM   #12800
poochy's Avatar
do they make a gear diff for the tc5?
poochy is offline   Reply With Quote
Old 03-26-2011, 08:15 AM   #12801
Nope.
But you can put spec-r or yokomo 40T.
Some pages ago I post picture what it have to be done
Just you must go back.
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 03-27-2011, 11:03 AM   #12802
I fixed my traction issue now I have a push. Any ideas?
Kyosho Rb6
Kyosho Rt6
Old 03-27-2011, 11:47 AM   #12803
bagged69chevy's Avatar
Trader Rating: 19 (100%+)
What changed did you make to fix your rear traction issues?
can you post up your setup ?
Nick George
www.localrcracing.com
bagged69chevy is offline   Reply With Quote
Old 03-28-2011, 12:24 AM   #12804
If you have push try add more drop, I mean for example from 7.0 to 6.0,
it should add some more up travel (more front work range).
It mean when you enter corner and start slowing down, then more weight
will be transwered to front end (more grip).
Or try detach sway bar at front, or one step softer spring.
Michal Abramowicz
Old 03-28-2011, 07:08 PM   #12805
EL BILLU's Avatar
Send a message via MSN to EL BILLU
Default ??
this car tc5 is good good cars for carpet.. track is small agressive ???
EL BILLU is offline   Reply With Quote
Old 03-29-2011, 12:15 PM   #12806
JRXS_chris's Avatar
Hi guys, just purchased a second hand TC5 for use in the wet. Included in the package were a couple of white main belts. I'm guessing these aren't standard right? Any of you guys know about them at all, any performance advantages?
JRXS_chris is offline   Reply With Quote
Old 03-29-2011, 12:36 PM   #12807
Trader Rating: 14 (100%+)
They are Team Bomber belts for Yokomo. They were used in the TC5 to free the drivetrain up a bit.
thunderbt3 is offline   Reply With Quote
Old 04-04-2011, 04:53 PM   #12808
I've got a bit of a loose rear end when I'm off power turning in to a corner. What are a couple things I could try to keep that rear end planted?
2SiX is offline   Reply With Quote
Old 04-05-2011, 02:53 AM   #12809
wtcc's Avatar
Reduce the droop in front (higher number) or give more droop for the rear wishbones.
wtcc is offline   Reply With Quote
Old 04-05-2011, 07:44 AM   #12810
Default cv shaft
front use AE spool, is it OK without mod?
spec-r for BD
mos-leung is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
