Old 03-06-2011, 07:42 AM   #12781
I just got a TC5 and am wanting to race the local 17.5 class.
I've only ran the car once and it was really loose in the rear end. A guy that was at the track had noticed that my car was really loose on the rear and told me I need to tighten down the front diff as it was loose. I'm about 60% sure it has a slipper spool in the front. Is this the best option for asphalt racing? Or should I look into a solid front end?
2SiX is offline   Reply With Quote
Old 03-06-2011, 07:59 AM   #12782
Also, how are most people holding the battery in? With just the top strap anytime I slap a board the battery falls out. The shop had these little plastic pieces that screw in but they don't really work for my batteries. I just got a new dremel so I figured I could make something happen. Or would it be better to just maybe throw some velcro on the bottom of the top strap and the top of my battery, that way the strap velcros to the battery as well as holding the battery tight against the chassis?
Old 03-06-2011, 11:30 AM   #12783
wtcc's Avatar
I think the slipper spool is the best solution for asphalt.
For the battery I used Lipos with little bumps to fit in the battery slots. For flat batteries I made some steel plates with the form of the slots and glued them underneath. This gives the battery some extra support in case of a crash. The tape the does the rest.
Or you use some composite material and do custom made lipo braces...
wtcc is offline   Reply With Quote
Old 03-06-2011, 02:44 PM   #12784
So you are taping the battery in? Are you using the battery strap at all?
Old 03-06-2011, 04:57 PM   #12785
Trader Rating: 88 (100%+)
Default Battery holder
To resolve the issue of your battery falling out I'd recommend getting an Exotek chassis with the steel battery holders. I had a TC5 with and one without the Exotek chassis and I never had issues with the battery sliding out with the Exotek. The TC5 without on the other hand had a few races cut short because the battery decided to go it's own way after an impact. You could also use a velcro strap with that chassis. Or there's the option of trading up to a TC6.
tcdrvr2 is offline   Reply With Quote
Old 03-06-2011, 07:55 PM   #12786
I'm not looking to put any money into this car. I plan on racing it a couple times and If I really like this on road thing I'll build a TC6 or something comparable.
Home Depot had small sheets of lexan for $4.50 and I'm basically going to make something that looks like one that has been mentioned in this thread a ways back. It's only .093 thick but I think it will be enough to keep the battery from falling out or jamming into the belts.
Old 03-07-2011, 11:26 PM   #12787
I tried a whole bunch of ways to get the stock battery strap to work and it never really did. Save your self the time that I wasted and just buy some strapping tape. Works like a charm and is cheap to boot.
Ultima RB5-SP2/HB D4 WCE/AE TC5R/AE 18R/Traxxas Blue Eagle
Sponsoring Futaba/Tekin/Thunder Power with my hard earned cash.
BlueEagle is offline   Reply With Quote
Old 03-08-2011, 07:55 AM   #12788
Trader Rating: 99 (99%+)
Questions?? what is a good start for gearing?
I'm setting up my sons tc5 we just picked up used, with a 21.5 spec motor and using a XP SC450-BL esc borrowed from his T4.1 RTR. I added a 25t pinion and used 86t spur the car came with and the car seems extremely slow. I do not want to over gear the car, I want to make it fast enough for him to enjoy. Could someone give me a decent starting point.
We are both new to our tc5's so any help would be appreciated.
RC8.2e - B5M - B44.3
isarctard is offline   Reply With Quote
Old 03-08-2011, 08:34 AM   #12789
Chaz955i's Avatar
You are geared way too low. Not sure of the internal ratio of the TC5 but you might want to gear to a 3.9-4.0 overall final drive ratio, check temps, and if the motor is cool gear up from there. The internal ratio should be in the manual or you can simply divide the pulley teeth by the number of teeth on the layshaft pulley. Then multiply this by the result of the spur divided by the pinion. So assuming a 2.0 internal ratio your current final drive ratio is a 6.88. Going to a 43 pinion would get you to a 4.0. Again assuming a 2.0 internal ratio which you need to verify.
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 03-08-2011, 09:24 AM   #12790
Thanks for the explination and what final gear ratio to shoot for.
We did not get the manual with his tc5, I will have to get it from online
Old 03-08-2011, 09:50 AM   #12791
Chaz955i's Avatar
It is easy enough to figure without the manual but it is a good idea to print one up anyway. These cars aren't super complicated but if you got them used it is helpful to know how they should go together if the previous owner botched the build. Good luck.
At The Gate Bizzos
Old 03-08-2011, 01:05 PM   #12792
shoe's Avatar
I run 21.5 w/ no timing esc. A 56 pinnion in 64 pitch is the largest that will fit. I run 56p x 94s = 3.24fdr, 56x88=3.14, 56x100=3.45. Or use this
http://www.gearchart.com/index.cfm?f...n=chart.create
shoe is offline   Reply With Quote
Old 03-15-2011, 01:23 PM   #12793
Bmr4life's Avatar
Trader Rating: 50 (100%+)
Where are you all buying your 64p spur gears from? Which ones fit?
Also, where can I get a 90t 48p spur?
Thank you
Too many RC's to list.
Bmr4life is offline   Reply With Quote
Old 03-16-2011, 06:52 AM   #12794
19_mustang_96's Avatar
Trader Rating: 99 (100%+)
What the best gearing for a 17.5??
Kyosho Rb6
Kyosho Rt6
Sandpit RC Washtenaw RC Raceway Ithaca RC Raceway Hardwoods RC
19_mustang_96 is offline   Reply With Quote
Old 03-16-2011, 07:08 AM   #12795
Buckaroo's Avatar
Boosted/non-boost? Rubber/foam? Indoor asphalt or carpet? Outdoor? ESC brand? Motor brand? Size of track?
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
