Team Associated TC5
thanks so much thats excatly what i wanted...much appreaciated. can someone please give me some pointers on installing the sway bars? i bought the car as a roller and they were never installed. i put the rear one on and it rocks back and forth not being pinched at all by the black hold downs on the bulkhead. thanks.
Check for the number of dots on the top of the swaybar holder. 1 dot is the smallest holder, 2 is a step larger, etc.
Hey Guys,
I was having issues with my carpet set up on the TC5R, so I decided to try the last race set up by Keven Hebert. The change was dramatically better and brought the car to the front. Very impressed with Keven's set up.
God Bless
http://http://www.teamassociated.com...t_iic_2009.pdf
God Bless
does anyone know if or where I can buy a tamiya blue screw kit for the tc5?
If I'm not mistaken, the TC5 uses ASE hardware and all Tamiyas are metric. Also the Tamiya blue is a little lighter than the Associated blue. You can probably find a blue screw kit for the Factory Team edition.
TC5 has metric hardware. I got my blue screws from http://www.fastener-express.com
They're as close as you'll get to AE blue for metric screws.
Does any one make a servo save that work for a tc5. I raced last night and broke two servo.
Thanks for the info. I just bought the car used last wednesday. I didnt even think to check that. Im was use to the TC3/4 setup. It was locked down.
Steering vibration at full turn
Just a quick question. My TC5 steering vibrates like hell at full turn. I checked the CVD and its all straight, no binding and the wheels clear the suspension arm too. No vibration whatsoever if the front tires are straight though.
Has anybody experienced this?
TIA.
TIA.
Reduce the steering using the EPA on your radio. The chatter is caused by the joints in the CVs being turned too far.
I'm running indoor carpet track with a 17.5. its a VTA styled class with hpi vintage tires. I need more rear traction. Should I add weight to help this??
Have you already tried everything like reducing droop in the rear or adding it in front, or lighter oil, softer springs, laying down the shocks, more toe-in or steeper shorter camber links?
TC5.....VTA
I just got a steal of a deal on a like new TC5R. Does anyone have a VTA setup for carpet.. We are running 21.5 motors and 1450 min. weight. I am going to start with the stock rubber kit set up for now. The TC4 is going to the shelf for now!!!!!!!
TJ
TJ
