Old 11-16-2010, 12:20 PM   #12676
Originally Posted by wcalaker View Post
For rubber on carpet you need a spool or slipper spool.
Sorry, noob here - thought spool/slipper spool was for asphalt? I had a diff in my TC5R initially (rubber on asphalt track), then switched to the slipper spool based in what I'd read elsewhere, and honestly, it doesn't handle nearly as well now - at least the way I drive. I don't have near as much steering as I did before and I can't tell a noticeable difference in acceleration. I'm not planning on racing a class where weight savings will be a factor, and I'm considering going back to the diff... ?
Associated TC5
TAorama is offline   Reply With Quote
Old 11-16-2010, 12:59 PM   #12677
Buckaroo's Avatar
Try everything, run what works best for YOU.
Tom Keith
Tekin & Sweep, thanks for all that you do for you know who!
Associated/T.O.P./Mugen/Fantom/Spektrum/Savox
Buckaroo is offline   Reply With Quote
Old 11-16-2010, 01:27 PM   #12678
Use what works best for you. It took me a little getting used to the front spool/slipper spool at first but almost everyone runs this setup for carpet with rubber tires.
Good luck
wcalaker is offline   Reply With Quote
Old 11-17-2010, 05:11 AM   #12679
robsryd's Avatar
Send a message via ICQ to robsryd
Hey guys,
Got two TC5R's up for sale, complete all boxes, paperwork and hop ups, check out the for sale forum. $450
http://www.rctech.net/forum/r-c-item...-450-tc5r.html
Racing. Because baseball, golf, football, bowling,tennis and soccer only require ONE BALL!
Trains and Lanes Paved and off road tracks (slots too!) Easton, Pa. Race'm if you gotte'm!
robsryd is offline   Reply With Quote
Old 11-17-2010, 04:09 PM   #12680
Trader Rating: 27 (100%+)
anyone know a good gearing for a TC5 on carpet running 17.5 with timing and boost and what not?
I am running 64P gears and am at 45/108 right now.
Still have some programming on the ESC to do.
C_Money is offline   Reply With Quote
Old 11-17-2010, 04:10 PM   #12681
Buckaroo's Avatar
We need to know the size of the track (L & W) and wether it's open, technical, mixed, etc.
Tom Keith
Old 11-17-2010, 05:17 PM   #12682
it no more than 80x40, right now its fairly technical, long straight in back other than that just turning a lot.
Old 11-18-2010, 06:01 AM   #12683
Tbizz's Avatar
Send a message via AIM to Tbizz
Good luck
Coming from the gas offroad scene I found the spool setup to be interesting. It did take me a bit of getting used to. Once I realized that you can often turn better while holding and staying smooth on the throttle on the through the turns. As opposed to slowing down significantly before the turns, which I was used to.
-Tony
Tbizz is offline   Reply With Quote
Old 11-18-2010, 06:16 AM   #12684
After installing the slipper spool, the car now exhibits a LOT of understeer. The only thing I changed was the diff for the spool. I can't power through the turns as described or it will just push the car further to the outside of the turn. Once I'm past the apex of the turn, I can power on and pull OUT of the corner just fine, but it's not near as tight in the corners as it was with the diff.
What am I doing wrong?
Associated TC5
Old 11-18-2010, 07:19 AM   #12685
Tbizz's Avatar
I gotta admit, I haven't run a diff in on-road racing so my comparison may not be fair. I just find that you don't need to brake as much on turn-in because the spool generally slows you enough, then you can power-out of the turn as you mentioned.
Old 11-18-2010, 07:29 AM   #12686
Tbizz's Avatar
Try the setup below.
What I'm running now (setup below) is a vast improvement over what I had. I run RCGT-carpet.
http://www.teamassociated.com/pdf/ca...t_iic_2009.pdf
Another setup to consider, I haven't tried it yet though.
http://img718.imageshack.us/img718/594/setuprt.jpg
Old 11-18-2010, 08:25 AM   #12687
I'll give 'em a shot. I'm running an outdoor asphalt, med to low traction track, but it's a start.
Associated TC5
Old 11-20-2010, 08:18 AM   #12688
anyone else?? I posted the track like a post down from this
Old 11-22-2010, 07:58 AM   #12689
SkarTisu's Avatar
Send a message via AIM to SkarTisu Send a message via Yahoo to SkarTisu
I'm running 40/96 in mine right now with the following setup:
- LRP X-12 17.5
- Tekin RS
- Reedy 2S LiPo
- Boost @ 40
- Turbo @ 10
- Turbo Ramp @ 1
- CRC foam tires @ 56.5mm diameter
People are asking me how my car is so fast.
Marshall Skare
Team Associated - Reedy Powered - JConcepts - LiveRC.com
SkarTisu is offline   Reply With Quote
Old 11-23-2010, 05:19 AM   #12690
MENTAL DENTAL's Avatar
Default Cam position
Can anyone tell me what's the difference in performance when the cam position height is changed.
MENTAL DENTAL is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
