Old 10-01-2010, 01:16 AM   #12616
Originally Posted by Scooter79rs View Post
Tonight AE got a bit of air time on Australian TV
The in-car footage was taken using my car and it got a nice view of the AE logo, the car at 2:31 is also the same car, different body.
I have hope that you save your club and track
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 10-01-2010, 04:56 AM   #12617
m.
I hope so too, its an awesome track which I've been one of the pace setters at it. But due to the up roar from everyone to sale of the facility has been put on hold. So I'm hoping the facility isn't sold of and the track stays.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 10-03-2010, 07:07 AM   #12618
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
I just installed the spec-r bd5 gear diff in my tc5 had to use extra shims but it fit and looks like it will fit the tc6 since the new diffs are narrow.
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 10-03-2010, 11:29 PM   #12619
Post the pics
m.
Michal Abramowicz
Old 10-04-2010, 03:17 AM   #12620
Murdock's Avatar
MY bad, but.. What are the differences between the TC5 and TC6?
When is the TC6 coming out?
★ MST: MS-01D Pro
★ Tamiya: TA05VDF, Gold TA05VDF, DF03RA
★ HPI-HB: Pro-D, TC-FD, TCX, Cyclone S
★ Team Magic: E4FS ★ Academy: STR-4 Pro II
★ Yokomo: Hyper SSG DRB, BDM, SD SSG, DP Type B
Murdock is offline   Reply With Quote
Old 10-04-2010, 03:18 AM   #12621
Murdock's Avatar
Has anyone used a TC5 Chassis for drifting?
★ MST: MS-01D Pro
Old 10-04-2010, 04:29 PM   #12622
Post the pics
m.
here is the pics i will be testing it this weekend it might end up in the rear.
bd5 spec r gear diff
Team Associated TC5-101_0353.jpg   Team Associated TC5-101_0354.jpg   Team Associated TC5-101_0355.jpg
Old 10-04-2010, 07:42 PM   #12623
ZiG-87's Avatar
Okay, just got my TC5R and had my first club race with it. I loved it. I have two basic questions though:
1. I noticed there is some side-side play in the rear diff. None in the front, but the rear can move side to side a couple mm. Is this normal?
2. My belts were way tighter than anyone else. I got the car second hand from one of the top drivers so I hesitate to question his setup, but everyone at the track was telling me too lower the tension a bit. What's the deal?
Thanks.
ZiG-87 is offline   Reply With Quote
Old 10-04-2010, 08:50 PM   #12624
Thanks.
1. Is it the pulley or the whole diff? All of my diff's have some side-to-side movement on the pully.
2. How easy do they flex if you press down on them with your finger?
Old 10-04-2010, 09:48 PM   #12625
ZiG-87's Avatar
The whole diff moves. I was going to just shim it more, but there's already one shim on each side, just like the manual calls for. It just strikes me as odd that only the rear diff has this play.
As for belt tension, I can push on the front belt and get it to touch the top deck with moderate pressure, but on everyone else's cars, it took probably half or a third as much pressure to do the same.
Old 10-05-2010, 04:34 AM   #12626
May i know the size of extra shims?
mos-leung is offline   Reply With Quote
Old 10-05-2010, 05:12 AM   #12627
My diffs have a bit of play with the recommended 1 shim per side as well. Not as much as 1mm though.
As for the tight belts did the previous owner run mod? They might have been tight to stop the belts skipping with a high power motor. If you're running a higher turn motor just adjust the cams so the belt is looser. I run mine fairly loose with a 13.5.
spongerX is offline   Reply With Quote
Old 10-05-2010, 06:51 AM   #12628
I just used the standard diff shims i think it was 4 on each side.
Old 10-05-2010, 11:49 AM   #12629
seth556's Avatar
Trader Rating: 37 (100%+)
How free should the drive train be? Without the belts everything seems super free but with the belts on it's a lot less free. If I take out the motor and spin a tire fast and let go it will only continue to spin for 3/4 a turn or so. The belts aren't very tight at all and it just seems odd.
seth556 is offline   Reply With Quote
Old 10-05-2010, 11:53 AM   #12630
wtcc's Avatar
That is normal, not nice but normal. If you use the original AE belt you should change to Yokomo belts they are better in this case.
wtcc is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
