Old 08-17-2010, 07:50 PM   #12571
seth556's Avatar
Trader Rating: 37 (100%+)
I have a used tc5 in the mail and it should be here in a few days. I'm planning on racing it down at my LHS (superior hobbies) and was looking for an asphalt setup and wondered if there was any must have upgrades for the car or anything I need to do to make it raceable?
seth556 is offline   Reply With Quote
Old 08-18-2010, 08:54 AM   #12572
rc pete's Avatar
Chiming in on the body choice, as well...
I carry only two body types to every race: Mazdaspeed 6 and LTC-R
Speed has a nice balance in low-to-medium traction conditions, whereas the LTC-R is a little on the loose side. Once you get a groove on the track the speed tends to be a little too planted. Then I run to the LTC-R, which is more responsive.
I used to also carry the original Mazda 6 and the Stratus 3.0, but they simply aren't on pace under most conditions.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 08-18-2010, 05:49 PM   #12573
xtrememadness's Avatar
Send a message via AIM to xtrememadness
Originally Posted by spongerX View Post
I'm partial to the LTC-R these days. Protoform Stratus 3.0 feels really slow. Gotta cut down the rear wing a lot. MazdaSpeed 6 felt too loose to me.
LTC-R is a nice compromise of rear down force and good top speed.
speed 6 for rubber carpet. ltc-r for asphalt.
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 08-18-2010, 06:26 PM   #12574
Trader Rating: 15 (94%+)
Send a message via AIM to W.E.D.Jim
Some sedan bodies done recently I thought might brighten up this thread.
...Jim
W.E.D.
www.wedjim.com
www.wedjim.com ...Closed down due to heavy work load I couldn't keep up with and maintain my primary job. But I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 08-19-2010, 03:05 AM   #12575
georgec's Avatar
Wow, sweet looking lids! Would like to have one of those, when I get to where I don't hit the boards hard and often =)
georgec is offline   Reply With Quote
Old 08-25-2010, 06:32 AM   #12576
Default tc5 shock bladder became bigger then new one ...
Hi!
In my new tc5r shock bladder became bigger ...
I mean rubber is little bigger and I can't rebuild shocks ... is too big now.
I use GM silicon oils ... but same shit came true with my 2y old shocks where was AE oil ...
Now I put bladder from Hot Bodies .. because I only have this one free at my home
Any driver get this problem with bladders like me?
Regards!
m
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 08-25-2010, 07:04 AM   #12577
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
Originally Posted by M.Abramowicz View Post
Hi!
Regards!
m
if you used a motor spray to clean the shocks out and the bladders that would make them expand.
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 08-25-2010, 07:17 AM   #12578
I never use it I know this from another car. With my tc5 for almost last 3y I don't made this stupid mistake
Regards!
m.
Michal Abramowicz
Old 08-25-2010, 11:37 AM   #12579
The AE Bladder do swell up after a little while, I used the hotbodies bladder as well so no problem there !
Keven Hebert
AE / Reedy / ApexRCproshop
Futaba / BSR tires / Protoform / CR Graphics / Total-RC / ProSpec / Leespeed / 2mm designs
Keven H is offline   Reply With Quote
Old 08-26-2010, 05:38 PM   #12580
georgec's Avatar
Anyone tried to buy anything from Exotek lately? I have been on their site several times lately wanting to buy some of the graphite pieces that you thread tape trough to hold the battery in place but their store seems to be closed! Oh well, I think I may have enough scrap pieces laying around to make my own =)
Old 08-26-2010, 05:54 PM   #12581
I had the same problem with the AE bladders, I never cleaned mine with motor spray either. I installed Tamiya bladders and never had a problem since. I think it's been two years.
Hi!
Regards!
m
outlandr91 is offline   Reply With Quote
Old 08-27-2010, 12:41 AM   #12582
Default Need Help for my TC5R
Guys,
I've got a problem with my newly required TC5R. whenever I'm applying a brake on stretch she keep on turning right without steering input. Check already the ride hide, droop it is all ok. I don't know how why she keep on turning right. Your help is highly appreciated.
Thank you Guys
Shock
Shockflyer is offline   Reply With Quote
Old 08-27-2010, 01:37 AM   #12583
scoyle's Avatar
Originally Posted by Shockflyer View Post
Guys,
Thank you Guys
Shock
Have you checked you diff/diffs to make sure they are still tight and rotating ok? Under braking it may not be reacting the same on both sides and causing it to veer to the right?
scoyle is offline   Reply With Quote
Old 08-27-2010, 03:32 AM   #12584
Guys,
Thank you Guys
Shock
I've had this happen a few times. Very frustrating to work out.
Here are some things you can try:
Check your front spool and make sure it is still tight. Mine goes through phases where it will start to slip a lot. Usually mid race and then braking gets really interesting.
Check left to right balance of the car using the balancing holes in the chassis.
Check for chassis tweak.
Check that all the suspension components are mounted in the same holes left to right.
spongerX is offline   Reply With Quote
Old 08-28-2010, 01:06 PM   #12585
Scoyle and Sponger x
Thank you guys for the help. Now my TC5R is running fine. I do hope to catch up coz we will have our nationals race within 2 weeks.
Shock
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
