Old 07-05-2010, 03:41 PM   #12481
Suspended
Originally Posted by BlueEagle View Post
I was wondering if any team drivers knew whether the new TC6 bulkheads were remotely close to production and/or whether they'd be a direct fit for the TC5.
I'm assuming that they'll be very similar to the current "UK" bulkheads being used on the TC5, but I'm assuming that a "mass-produced" part would cost less and be less hassle to obtain than the UK ones even if we didn't include the cost of labor.
I managed to bend my stock motor mount the last time I was out there. Since I need to replace something anyway, I'm trying to decide if I want to try and mod a stock motor mount/bulk head like someone did earlier in this thread, buy new bulkheads, or just buy another stock motor mount and run with it, as-is.
not even close TC6 to TC5. The newer bulkheads are universal on the front and back, while the TC5 has four different parts for the same, let alone the other things (motor mount, and those two alum braces for the rear)
TC6 has none of that, and will not fit on a TC5 chassis. Sorry
Oh bye the way - once you bend machined aluminum, throw it out. The metal just lost around an astonishing 60% of its strength.
Tamiya Frog from 1985 - Kyosho Outlaw Ultima ST - AE RC10T (cow hide LOL) - Tamiya M03-L Mini Cooper - Tamiya 1/24 Tamtech Posche 962C - Tamiya 1/24 Tamtech Ferrari Testarossa - Tamiya TA05-R - AE TC5FT
dragnse7en is offline   Reply With Quote
Old 07-05-2010, 05:28 PM   #12482
None of what you said, really has anything to do with whether the bulkheads will be a direct fit on the rear of a TC5. I appreciate the thought, but I'm looking for official word from a team driver or someone who has seen one up close and compared them.
Ultima RB5-SP2/HB D4 WCE/AE TC5R/AE 18R/Traxxas Blue Eagle
Sponsoring Futaba/Tekin/Thunder Power with my hard earned cash.
BlueEagle is offline   Reply With Quote
Old 07-05-2010, 05:33 PM   #12483
Suspended
Yeah but if you read the article it said that the chassis is 13mm skinnier - we might be able to fit the TC6 bulkheads on the TC5 but how would the diff fit right then? I dunno. I doubt it but I'm not holding my breath. They just may have the exact same pilot holes for it and I will sit with TC5 diff spare going "duh"
Old 07-05-2010, 05:36 PM   #12484
LMRacing's Avatar
Trader Rating: 27 (100%+)
Everything he said has to do with your question. Merely from an engenearing standpoint the bulkheads wont be compatable with the current design. There designed to be closer togeather and use a different diff since the current diff wont be narrow enough to fit between the narrower bulkheads. They also will use a different shock tower that if you widen the stance of the bulkheads to fit on the TC5 will not fit as it will itself be narower where it mounts.
Could you make it work? Sure, if you spent enough time working your own parts, shock tower, diff cams. But by then its just cheaper and easier to sell the TC5 and buy a TC6
LMRacing is offline   Reply With Quote
Old 07-05-2010, 05:43 PM   #12485
Suspended
true true - buying parts vs a kit. I hope its worth it b/c I'm already pursing money away for it. Only b/c I can't afford a TRF416 or X version even
Good point hoss - I thought about that too.
I think that the chassis screw holes would be the same to fit TC6 bulkheads, but then I would have to try my best to make it a TC6 drivetrain - which I bet would involve a dremel tool once or twice.
Again, good point. I'll wait for the kit and wait to see what TC5 parts fit AFTER I get the new kit.
Old 07-05-2010, 06:34 PM   #12486
bvoltz's Avatar
Trader Rating: 44 (100%+)
Can someone explain to me what RWD Mount Shims are and were do they go? I do not understand what this is.
bvoltz is offline   Reply With Quote
Old 07-05-2010, 06:50 PM   #12487
Suspended
They're different from the front shims. Use two medium size shims for the far end IIRC thats what the manual said if u wanna go w/ factory settings. Dble check but I know the shim spacers go wider in the back
Old 07-05-2010, 06:51 PM   #12488
Suspended
Oh - all the shims sit behind the arm mounts.
Old 07-06-2010, 05:24 AM   #12489
They're thin plastic pieces in 3 different thicknesses with a C opening on one end that snap onto the Arm Mount bolt between the bulkhead and arm mount. They're used for setting rear toe or widening the track width of the car.
Default rubber tire kit settings are 3 degrees of rear toe so you need to put the thinnest (1 degree) and thickest (2 degrees) arm mount shims on the 2 rear RWD arm mount bolts if you're using a 0 degree hub carrier in the rear. The RWD bolts are the ones closest to the back of the car.
If you're missing the TC5R/TC5F manual you can download it from here:
http://aedownloads.com/downloads/man...c5r_manual.pdf
The setup sheet at the end of the document has pictures of the shims and shows which locations are FWD and RWD.
Other miscellaneous TC5 downloads here:
http://67.199.85.166/resources/resou...?modelname=TC5
spongerX is offline   Reply With Quote
Old 07-06-2010, 08:41 AM   #12490
Rick Hohwart's Avatar
The new TC6 bulkheads will not fit the TC5.
Rick Hohwart is offline   Reply With Quote
Old 07-06-2010, 02:18 PM   #12491
mr crum's Avatar
Send a message via Yahoo to mr crum
i seen pics on redrc.net they narrowed the driveline moved bulkheads in so the wont fit but the thing is sweet i like the fact that there is a drive belt on either side of the spur and that the bulkheads are abdectrious u can use same bulkhead on all four corners i will get one in october when they are released
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 07-06-2010, 03:05 PM   #12492
bvoltz's Avatar
Ok all this is the shims for rear toe in. But on the setup sheets, it shows rear toe in at a total of 3.5 deg, and 3 deg with the shims, so how are you getting the other .5 deg with 0 deg caster blocks? in the rear...
Old 07-06-2010, 03:13 PM   #12493
The car is very well balanced. It should not be a problem for those with a 1350g minimum weight to reach this and still be balanced left to right.
Old 07-06-2010, 06:32 PM   #12494
vikingen's Avatar
just wondering if anyone could confirm that these ball cups will be a good/correct size replacement for a tc5 ?
RPM Heavy Duty 4-40 Rod Ends [RPM73372]
vikingen is offline   Reply With Quote
Old 07-06-2010, 09:28 PM   #12495
Yes they're great. Much more robust than the stock ones. I've got the blue ones on my TC5.
blanchjd is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
