Old 06-09-2010, 04:31 AM   #12406
How are cars teched for weight? Are they weighed as if they were about to drive (body, tires, battery, electronics, motor)? Or are they weighed with just the chassis, electronics, motor, battery?
Sorry for the newbish question but I've never been to a big event to see how this tech is done.
spongerX is offline   Reply With Quote
Old 06-09-2010, 04:40 AM   #12407
Its with everything you would race, I've got 35grams of lead just to bring my car up to weight.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 06-09-2010, 06:45 AM   #12408
Scooter got it right. A body with a few coats of paint can weigh 150 grams.
“There’s little point in writing if you can’t annoy somebody.”- Kingsley Amis
jhberger is offline   Reply With Quote
Old 06-09-2010, 06:50 AM   #12409
Max 102-105g!!! 150g is like armor!!!
Paint should be like fog
I have nice paint mazda 6 speed (not light weight) and it is 105g with stickers.
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 06-09-2010, 08:09 AM   #12410
Originally Posted by Rick Hohwart View Post
This is what I have. If you have any questions please let me know.
The steering post mounted to the front shock tower hold a body post that is cut so that the body rests on it at the bottom of the windshield. I thought that this might improve down force on the front end but it was inconclusive.
Thanks for your photo.
Are you running the same set up in Reedy race as photo?
What are the F/R spring & weight of oil on your shocks?
How's your feel on your car ? i means is the car tends to over-steel or under-steel or netural......
mos-leung is offline   Reply With Quote
Old 06-09-2010, 08:12 AM   #12411
Rick Hohwart's Avatar
Technically, the car must weight more than the minimum when it is pulled off the track after the race is over. But this can vary from event to event.
Rick Hohwart is offline   Reply With Quote
Old 06-10-2010, 09:11 AM   #12412
racing_jason's Avatar
I was just curious about the picture of Ricks car.
It looks that both front and rear camber links are atatched to the bulk head? And not the normal positions. Why?
Thanks Jason
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 06-10-2010, 10:42 AM   #12413
The picture is of my car straight from the Reedy Race. I was using rear/green, front/silver springs with Losi 57 pistons and 35 weight oil. The car tended to under steer.
Thanks Jason
At AE we refer to these as hillbilly links. When you run them in this position (and raise the outer ball studs 2mm all around) the car tends to be easier to drive and more consistent.
Old 06-10-2010, 10:56 AM   #12414
Kurly's Avatar
Hey Rick, you mentioned the Worlds coming up and maybe seeing something new. Is AE maybe going back into the Nitro scene or were you talking electric still?
L2Kracing, LeisureHours Hobbies & Raceway
Gizmo Racing USA, ARC USA, Motiv RC.
Kurly is offline   Reply With Quote
Old 06-10-2010, 11:06 AM   #12415
Electric 1/12 and TC Worlds. No nitro TC in the works.
Old 06-11-2010, 08:50 AM   #12416
I would really like to hear more on the new car if in fact there might be one. As I was about to pull the trigger on 2 TC5R's for IIC but am hesitant now...I don't need details just maybe something along the lines of a 98% probability etc... Just don't want to make the purchase and then a new ride come out a month or so later. Even a simple Pm with just yes or no would work thanks in advance!
Schuurspeed / Aero-model / Gear One / LG1
www.OHRCR.com
Gitsum is offline   Reply With Quote
Old 06-11-2010, 09:38 AM   #12417
Hey Rick. Just wondering about the hillbilly links. The ballstud looks like it is inline with the bottom hole of the shock tower. Is that right? Also for outer ballstuds you say +2mm is that with silver ball studs?
Thanks.
JoelV is offline   Reply With Quote
Old 06-11-2010, 10:21 AM   #12418
Thanks.
another car with hillbilly link......cut out some metal parts & use the existing lower holes for link.....
Old 06-11-2010, 09:27 PM   #12419
Default Front solid axle or diff ?
Many of racer are using front solid axle due to the car perform better than one way when the car is in brake.
How about using diff in front instead of solid axle ?
What are the dis-adv & adv of using solid axle & diff in front ?
Old 06-12-2010, 06:25 AM   #12420
Thanks.
The inner ball stud is mounted in the lower hole of the shock tower. Use the silver ball studs.
A diff will work the same under braking but under power the spool will pull the car harder out of the turn. The diff can also slip the unloaded inside wheel. The only time a front diff works best is when racing foam tires on carpet.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
