Old 05-21-2010, 04:58 PM   #12361
mr crum's Avatar
Send a message via Yahoo to mr crum
Originally Posted by bfong13 View Post
Don't bother with the original TC5, as it lacks many of the aluminum and chassis upgardes the R and F versions have. The TC5F would be fine if all you run is foam and carpet. However, many drivers just use the R version for both asphalt and carpet. The R and F versions are essentially the same car except the F version has stiffer springs, caster blocks, hard plastic parts, etc.
the f is for foam tire r is for rubber the factory team was originally designed for foam mod racing it has thicker chassis as well as the parts bfong mentioned i run exotek chassis with ft top deck but i modified it cut brace out and split it down the middle works like a champ
can post pics later if anyone is interested
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 05-21-2010, 06:43 PM   #12362
ChadB.'s Avatar
Trader Rating: 21 (100%+)
A couple of things the R and F versons have that the original TC5 doesn't have are aluminum diff outdrives and an improved top deck that allows for more flex.
Regarding shimming the front end out, I use tamiya shims. Sorry I don't have part numbers.
I've already upgraded the outdrives and just went with the Exotec chassis. Just wasn't sure if there was anything else to that nature.Thanks anyways.
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 05-21-2010, 07:30 PM   #12363
Rick Hohwart's Avatar
Originally Posted by ChadB. View Post
Rick, are you using just normal washers to put on the axles or are you using special hexigon washers? I've been wondering about this myself.
The washer are round and made specifically for this application. I think every TC manufacturer makes them except AE. Generally they are available in .5, 1, and 2 mm thickness.
Hex spacing is one of the best fine tuning adjustments you can make.
Rick Hohwart is offline   Reply With Quote
Old 05-22-2010, 02:18 PM   #12364
miquelmah's Avatar
my new motor for the tc5......
http://www.youtube.com/watch?v=DCVzmRGPL-s
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
miquelmah is offline   Reply With Quote
Old 05-23-2010, 08:18 AM   #12365
Originally Posted by spongerX View Post
I too have this issue of my TC5r pulling to the left under acceleration. It tracks straight when coasting and stops in a straight line but under acceleration it veers left.
My droop is even on both sides front to rear, tires lift off the ground at the same time when checking each end.
I have about 0.5mm tweak in my chassis no matter how many times I put the top deck on when pressing on a flat surface. I adjust for tweak using a Hudy tweak station. Toe is +1 front and -2.5 rear.
I find this veering to the left worse on low traction where the wheels are spinning more. I've tried different sets of tires and it does the same thing. Brand new bearings installed as well.
It's been fairly frustrating as the car used to track straight. Really not too sure why this has started.
Found the problem in my rear hub bearings. Noticed that if I jammed the front of the car against a wall and gently accelerated on a very low traction surface like tiles (to minimize the strain on everythng) the right side rear wheel would spin way before the left side. Left side bearings did not spin as freely as the right side when I disconnected everything. All brand new so flushed out the stock grease they came with and lubed with Hudy Bearing oil and the car seems to be tracking a lot better now. Gotta flush out the rest of my new bearings and lube with Hudy oil now. I run my rear diff quite loose so this probably made the extra friction of the left side bearings more noticeable
spongerX is offline   Reply With Quote
Old 05-23-2010, 11:59 PM   #12366
Is this what I'm looking for?
Tamiya: Tamiya (#53646) - Tamiya Wheel Spacer Blue
Xray: Alu Wheel Shim Offset 0.75mm (2)
Ultima RB5-SP2/HB D4 WCE/AE TC5R/AE 18R/Traxxas Blue Eagle
Sponsoring Futaba/Tekin/Thunder Power with my hard earned cash.
BlueEagle is offline   Reply With Quote
Old 05-24-2010, 08:32 AM   #12367
Originally Posted by BlueEagle View Post
Yes.
Old 05-24-2010, 09:44 PM   #12368
blanks596's Avatar
Trader Rating: 14 (100%+)
can someone give me a good starting FDR for 17.5 lrp x11 and tekin rs
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 05-24-2010, 11:14 PM   #12369
bfong13's Avatar
Trader Rating: 17 (100%+)
You're not giving people very much information to work with when you post a question like this. FDR really depends upon many factors such as ESC settings, car setup, driving style, track size, temp, etc, but here goes nothing...between 6.0 and 7.0.
bfong13 is offline   Reply With Quote
Old 05-25-2010, 06:38 PM   #12370
blanks596's Avatar
well, sparing patrons from too much info, i'm trying to get a base line set up without the esc tweaks I'm running on a straight between 90 - 120 ft. with a tight infield. I drive on throttle through most corners- I'm just trying to get a ball-park figure here as I don't want to purchase gears I won't be needing-
Max S
Old 05-25-2010, 07:01 PM   #12371
gentleman81's Avatar
yea give me any info u can, i want to hit the track with the best car for me, if the F or R or TEAM ver, is better, let me know. like i said i have a ton of used foams to use. i do see all the other elec guys running rubber at my track though.
can on car be turned into the other easily?
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 05-25-2010, 08:24 PM   #12372
mr crum's Avatar
ok in my opinion if you want to run foam and switch back to rubber.
you should get the r and a ft top deck run ft topdeck with foam and r topdeck with rubber thats probably the best if you want to use it for both
TEAM B.R. RACING
Old 05-25-2010, 08:41 PM   #12373
ed517's Avatar
AE has a deal on the F right now. Go to their web store 275.00+ tax shipped. then order the Exotec chassis and top deck. thats what i did. dont forget the layshaft bearing holders they free up the front belt and lower the gear 1.25mm.
ed517 is offline   Reply With Quote
Old 05-25-2010, 10:22 PM   #12374
What firmware are you running on the Tekin? Because when I was v200 with the x11 17.5 I was at 3.5FDR. With v203 with a 17.5 Duo2 I'm at 8.0FDR.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 05-25-2010, 10:44 PM   #12375
blanks596's Avatar
wow, what a big difference-i'm using v200-I haven't ran the 17.5 yet so I don't have a current fdr, or temp trends
Max S
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
