Old 05-17-2010, 09:29 PM   #12346
olhipster1's Avatar
Trader Rating: 89 (100%+)
Send a message via Yahoo to olhipster1
Default things to check for tweak
had a few TC5s and all had the same problem when new but alway got rid of the problem.
a few things I found can bind up the and make the car feel out of tweak.
-make sure the cvds don't touch the inner side of the spool diff. I found this happened with the stock slipper spool. usually space my car out 1mm on the font end.
-check side to side balance
-I used rubber bands on the turnbuckles to the steering knuckles to eliminate the play
-check outdrive bearings
-do not use the include battery strap, if screwed on too tight it will tweak chassis slightly
-make sure shim the spur layshaft correctly, if there is too much play or too tight it will make the car shift during braking or hard acceleration.
-check arm mounts for excessive play they have stretched with a hit.
I always checked this stuff and very seldom got the jerk effect on my previous Tc5s.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Old 05-17-2010, 09:49 PM   #12347
Originally Posted by justxroro View Post
anyone have any good tricks to help break loose a screw that seems to have had a lil too much loctite put on it?
Make sure the hex head is clean of debris that would prevent the driver from going all the way into the socket.
If that fails, buy MIP Thorp drivers. They don't come in pretty multicolored aluminum or a nice pouch, but they're solid and well worth it.
Ultima RB5-SP2/HB D4 WCE/AE TC5R/AE 18R/Traxxas Blue Eagle
Sponsoring Futaba/Tekin/Thunder Power with my hard earned cash.
BlueEagle is offline   Reply With Quote
Old 05-17-2010, 10:46 PM   #12348
ChadB.'s Avatar
Trader Rating: 16 (100%+)
side note: anyone have any good tricks to help break loose a screw that seems to have had a lil too much loctite put on it ?
I have always used a heat gun. It's always worked well for me.
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 05-20-2010, 08:52 AM   #12349
Send a message via AIM to justxroro
Heat gun worked like a charm!!!
Too bad I can't replace the factory team stuff with mip tips... Thanks for the tips nonetheless.
justxroro is offline   Reply With Quote
Old 05-20-2010, 01:42 PM   #12350
ChadB.'s Avatar
Your welcome.
Chad Burdick
Old 05-21-2010, 06:59 AM   #12351
gentleman81's Avatar
Default TC5 X chassis mods
im looking at getting a tc5 and i am seein all these TC5"X" cars. what ae the X mod chassis and parts supposed to do for the car. i will be running out door and probably foam.
MTX4R/PICCO(Trophy Taker) - SERP 950/SIRIO(Board Breaker)
PHI '08 - to be announced.....
www.vorra.org - ironbridgesportspark.com - 301raceway*4LIFE*.com
gentleman81 is offline   Reply With Quote
Old 05-21-2010, 10:25 AM   #12352
bfong13's Avatar
Trader Rating: 17 (100%+)
Exotek chassis http://www.exotekracing.com/EXOTEK_N...6/29_TC5X.html for better chassis balance and flex when using lipo batteries and rubber tires.
-Brian Fong
2014 Texas EOS 17.5 Sedan Champion
2012 ROAR Region 9 Nitro Sedan Champion
1996 ROAR Nationals Electric Touring Car A-Main Finalist
Xray T4'14, Xray XB4'16 Xray XB2'16
bfong13 is offline   Reply With Quote
Old 05-21-2010, 10:42 AM   #12353
Interesting, I wonder if this is how I sporadically break/lose bone blades. Did you do this by placing an equal amount of spacers under the arm mounts the same way that we set toe in the rear? I also noticed one difference I've always had between my car and the setup sheets I find online is that most of those sheets recommend shimming out the front hexes by 1mm which I was never entirely sure how to go about doing.
My spur seems shimmed properly, but the pulleys on the layshaft definitely rock back/forth. Is there a solution for this other than replacing the pulleys or gluing them?
Old 05-21-2010, 11:56 AM   #12354
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
mine did the same thing so i put an o-ring between the spur adapter and pulley and then one more in front of that pulley so the outer pulley squishes up against it and it got rid of all my play. but the biggest problem is that the shaft needs to be re-drilled with bigger holes to fit bigger pins as the stock pins are smaller dia. so the pulley rocks back and forth on it.
Serpent project 4x
jeff jenkins is offline   Reply With Quote
Old 05-21-2010, 01:06 PM   #12355
i do want to run lipos, but i have tons of used foams i want to use up, so should i go with the original tc5 or F chassis? i might run inside once out of a season, and thats a maybe, so most of the time it will be on sprayed pavement
Old 05-21-2010, 01:18 PM   #12356
bfong13's Avatar
Don't bother with the original TC5, as it lacks many of the aluminum and chassis upgardes the R and F versions have. The TC5F would be fine if all you run is foam and carpet. However, many drivers just use the R version for both asphalt and carpet. The R and F versions are essentially the same car except the F version has stiffer springs, caster blocks, hard plastic parts, etc.
-Brian Fong
Old 05-21-2010, 01:57 PM   #12357
Rick Hohwart's Avatar
...I also noticed one difference I've always had between my car and the setup sheets I find online is that most of those sheets recommend shimming out the front hexes by 1mm which I was never entirely sure how to go about doing...
This is done by placing a spacer on the axle between the hex and the wheel.
Rick Hohwart is offline   Reply With Quote
Old 05-21-2010, 02:15 PM   #12358
ChadB.'s Avatar
I have the original TC5 that I bought used a while back. Which alluminum parts are updated?
Rick, are you using just normal washers to put on the axles or are you using special hexigon washers? I've been wondering about this myself.
Chad Burdick
Old 05-21-2010, 04:20 PM   #12359
bfong13's Avatar
A couple of things the R and F versons have that the original TC5 doesn't have are aluminum diff outdrives and an improved top deck that allows for more flex.
Regarding shimming the front end out, I use tamiya shims. Sorry I don't have part numbers.
-Brian Fong
Old 05-21-2010, 05:55 PM   #12360
mr crum's Avatar
Send a message via Yahoo to mr crum
i just replace them go thru about 2 sets a year in florida so we run year round
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
