Old 05-13-2010, 08:46 PM   #12331
Suspended
Trader Rating: 18 (100%+)
Originally Posted by Surrey View Post
Talk to someonethat has a CNC and a water jet how much they would charge. The price isn't in the aluminum but the time to program the CNC and the Water jet
LOL.. With prices like that you wont sell 1, I dont care how much you have invested in the equipment and programming.. Good luck though..
Are you a division of Maxamps and AMB?? [/sarcasm]
bag of doritos is offline   Reply With Quote
Old 05-13-2010, 09:01 PM   #12332
Suspended
Originally Posted by jeff jenkins View Post
This is the email for the guy rc@nktv.mk.ua..
I could care less if they are titanium if someone is willing to pay that much for 4 shocktower mounts then they are retarded . Not trying to be an ass but that's how I see it. Also why hasn't associated made any of the parts everyone is after? I want them to come out with the inline motor side bulkhead. By the way they sell that for $40 same people from the email above.
Just emailed him.. Thanks for the info!
Old 05-14-2010, 03:29 AM   #12333
trerc's Avatar
Trader Rating: 89 (100%+)
Yeah but he's not even in the ballpark, maybe he's in the wrong market. I mean they are priced at 1/3rd the cost of the whole kit. I wish him luck.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 05-16-2010, 08:02 PM   #12334
Send a message via AIM to justxroro
hi all,
i am helping a buddy setup his TC5, but i am as much a newbie as he is. we both bought our TC5s (original version, not the "R" or "F") used, but his has a torque steer problem and mine doesn't. ive tried running my electronics in his car on the far fetched possibility that it was due to electronics, but that didn't solve the the torque steer problem either. anyone know where i should start?
here's what we've done already:
rebuild diffs
rebuild shocks
set diff "looser"
lowered "punch" on the esc
thanks for any help!
justxroro is offline   Reply With Quote
Old 05-16-2010, 08:13 PM   #12335
SpidarX's Avatar
Originally Posted by justxroro View Post
hi all,
rebuild diffs
rebuild shocks
set diff "looser"
I can't imagine that it's torque steer. Have you gone through and checked all the bearings? Sometimes a bad bearing will make a car pull under acceleration.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 05-16-2010, 08:22 PM   #12336
bfong13's Avatar
Trader Rating: 17 (100%+)
hi all,
rebuild diffs
rebuild shocks
set diff "looser"
Check tweak.
Check droop.
Check camber.
Check toe.
Check balance.
Check that there's nothing binding and everything spins freely.
Check tire wear.
bfong13 is offline   Reply With Quote
Old 05-16-2010, 08:25 PM   #12337
Tubaboy's Avatar
tweak??
Unhook the shocks, loosen screws holding the decks together and make sure the chassis is flat. Then re-tighten the screws in a star configuration.
Good luck,
Paul
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 05-16-2010, 10:00 PM   #12338
thanks guys, i'll start working down the list... he left his car at my place as well as a case of beer (i guess not the best idea).
i just noticed that it always pulls left under hard acceleration and under hard braking its almost spinning out left as well.
thanks again, i'll post my findings.
Old 05-17-2010, 01:54 AM   #12339
sounds like droop or shock lengths to me.
Edwin Pibal is offline   Reply With Quote
Old 05-17-2010, 07:24 AM   #12340
I too have this issue of my TC5r pulling to the left under acceleration. It tracks straight when coasting and stops in a straight line but under acceleration it veers left.
My droop is even on both sides front to rear, tires lift off the ground at the same time when checking each end.
I have about 0.5mm tweak in my chassis no matter how many times I put the top deck on when pressing on a flat surface. I adjust for tweak using a Hudy tweak station. Toe is +1 front and -2.5 rear.
I find this veering to the left worse on low traction where the wheels are spinning more. I've tried different sets of tires and it does the same thing. Brand new bearings installed as well.
It's been fairly frustrating as the car used to track straight. Really not too sure why this has started.
spongerX is offline   Reply With Quote
Old 05-17-2010, 09:06 AM   #12341
Double check all of your arm mounts. I had this problem once when I accidentally grabbed one wrong mount. They're marked with 1-3 dots for height.
Also double check all of your wheelbase spacers and rear toe shims.
Ultima RB5-SP2/HB D4 WCE/AE TC5R/AE 18R/Traxxas Blue Eagle
Sponsoring Futaba/Tekin/Thunder Power with my hard earned cash.
BlueEagle is offline   Reply With Quote
Old 05-17-2010, 12:57 PM   #12342
trerc's Avatar
+1
Definitely double check these. If the the rear toe is not equal it will no doubt cause the car to track weird on power.
Old 05-17-2010, 02:38 PM   #12343
jwq500rc's Avatar
The chassis might also be tweaked. loosen all the screws in the top and bottom of the chassis and upper deck and re-tighten. Do the bottom first then set the chassis on a flat surface and tighten the top deck.
Associated TC5R, TC4FT, 12L3, B4FT, T4FT
Diggity Design XLR8V1
jwq500rc is offline   Reply With Quote
Old 05-17-2010, 06:16 PM   #12344
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Be sure to check the battery strap that comes with car. It was making my chassis all twisted. Put your car on flat and true surface and see if the chassis is twisted. If it is, loosen up the bolts on the strap.
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 05-17-2010, 08:28 PM   #12345
i found a bad bearing in one of the rear hubs... i'll replace it tomorrow and see if it does the trick.
side note: anyone have any good tricks to help break loose a screw that seems to have had a lil too much loctite put on it? i just stripped my "Factory Team" hex driver (POS) trying to take a couple off.
thanks again for all the help, you guys rock!!!
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
