Old 05-07-2010, 09:15 PM   #12301
Originally Posted by blanks596 View Post
well, I ended up getting the new diggity designs lipo tray and it totally allowed me to reduce my weight by 114g and completely balanced at 1390-no brace, just tape.
I farted around with weights and tape until I got the Diggity piece. It's a lot of dough for not much, but it does the job. Mine balances perfectly with an epic 5000 at about 1300 grams. I have a zippy 4000 and an Orion 3800 and they are about 50 grams lighter, so I'd have to throw some weight on to get it up to weight and to balance it. My body weighs 150, so I'm close to on the money.
“There’s little point in writing if you can’t annoy somebody.”- Kingsley Amis
jhberger is offline   Reply With Quote
Old 05-08-2010, 02:43 PM   #12302
Is this right for rear toe... small clip + med clip + 0 deg. rear hubs = 2.5 deg. total toe???
What are you supposed to use for hub spacing?
g26er is offline   Reply With Quote
Old 05-08-2010, 08:20 PM   #12303
mr crum's Avatar
Send a message via Yahoo to mr crum
that would be 3 per side total of 6 across the back if you want a good hint for the rear mount get rid of those plastic shims get longer screws and use the aluminum shims they dont crush when u tighten the screw if you are on low traction track dont be afraid to go 3.5 per side or 7.0 total you will be surprised wat a half a mm makes
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 05-09-2010, 06:29 AM   #12304
Default Rear toe shims
I didnt like using the plastic toe shims so i ended up using the front bulkhead sims off the RC12r5.1 (part No #4617) these are alloy blue and different thickness and dont compress.
Now back to those stupid front bone blades.
POPPYD is offline   Reply With Quote
Old 05-09-2010, 06:37 AM   #12305
bfong13's Avatar
Trader Rating: 17 (100%+)
Yeah, don't use the plastic shims. I use the blue 1mm and 2mm aluminum shims and even the small king pin shims from the 12r5 to get the exact rear toe I need.
bfong13 is offline   Reply With Quote
Old 05-09-2010, 06:44 AM   #12306
Trader Rating: 55 (100%+)
T.O.P. makes a solid steel spool for the TC5 that doesnt need the plastic blades.
Jamison R is offline   Reply With Quote
Old 05-09-2010, 06:52 AM   #12307
pakk's Avatar
Trader Rating: 79 (100%+)
I have used that solid steel top spool, I don't like it. It wears out very fast.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 05-09-2010, 07:32 AM   #12308
Try the slipper spool, since using it I haven't had a problem with the bone blades in the front. I was doing 1-2 blades a meet at one stage, but no longer.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 05-09-2010, 11:49 AM   #12309
jeff jenkins's Avatar
Trader Rating: 75 (100%+)
i wasjust wondering if anyone has a dialed mod parking lot set-up for the tc5. the outdoor tracks here are in parking lots with good traction but was wondering what the hot set-up others are using. i am running the exotek chassis and topdeck also milled inline bulkhead and milled front bulkheads . at the moment i am running the 2008 bangkok worlds set-up. and the tires are sweep 36's that i am using .
Maclan Racing Products-RC US Imports - Sworkz USA - Bellgate Distributions
jeff jenkins is offline   Reply With Quote
Old 05-10-2010, 01:58 AM   #12310
Hi!
And question is what problem you have with chassis
under or oversteer?
I usually have same setup on asphalt and only change front drop (downstop
value) if I want more grip at front or less.
Regards!
m
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 05-10-2010, 11:08 AM   #12311
i am running juho's bangkok set-up and the front end feels nervous at turn in and the rear end needs more grip as it tends to wash out when turning on power.
Old 05-10-2010, 02:37 PM   #12312
bfong13's Avatar
Hmmm, you have +1 deg toe-out and the front end feels nervous...weird. Usually a little toe-out settles the front end down and makes it track nice and straight.
Sounds like you either have 1) too much steering or 2) a loose back end. You'll want to concentrate on either the front end or the rear end and not both at the same time.
To calm the front end down, try shimming the front end out on both side by 1mm. That may take a little of the bite out of the front end.
To get more traction in the rear, try -3 deg toe-in. The more toe-in you have in the rear, the more traction you will have.
There are alot of things you can do. Try one thing at a time. And, I'm sure you know but, just know that a setup that a driver uses on one track doesn't necessarily mean that it will work for another driver on a different track.
Old 05-10-2010, 03:33 PM   #12313
geeunit1014's Avatar
You have that backwards. Toe out makes the car aggresive on turn in, Toe in makes the car more stable on turn in
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 05-10-2010, 04:20 PM   #12314
bfong13's Avatar
Your right, my bad. I'm just always used to driving with it either at zero toe or toe out that I've gotten used to it.
Old 05-10-2010, 05:48 PM   #12315
I forgot to mention that I am running -3 deg of rear toe.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
