Old 04-25-2010, 04:46 PM   #12256
bfong13's Avatar
Trader Rating: 17 (100%+)
Originally Posted by jeff jenkins View Post
what the hell did you do to that poor car??
No doubt.
Please someone put this thing out of its misery.
bfong13 is offline   Reply With Quote
Old 04-25-2010, 06:39 PM   #12257
jwq500rc's Avatar
Looks like it was shot at and missed and sh--t at and hit.
Associated TC5R, TC4FT, 12L3, B4FT, T4FT
Diggity Design XLR8V1
jwq500rc is offline   Reply With Quote
Old 04-25-2010, 07:01 PM   #12258
Damnit Man's Avatar
Send a message via MSN to Damnit Man
I really like the motor mount. I want to see video of it running.
Donovan P.
Damnit Man is offline   Reply With Quote
Old 04-26-2010, 07:25 AM   #12259
miquelmah's Avatar
with a smaller motor..........two months ago......
http://www.youtube.com/watch?v=XbldPlefyNI
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
miquelmah is offline   Reply With Quote
Old 04-27-2010, 04:31 AM   #12260
Trader Rating: 5 (86%+)
Default Wheelbase
how do you shorten the front and rear wheelbase. i have read the directions but there is no real explanation on what goes where...could some one help me out. thanks.
obi wun is offline   Reply With Quote
Old 04-27-2010, 05:24 AM   #12261
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
You can move the spacers in either the front or rear of the a arms to lengthen or shorten the wheelbase. Without the spacers your a arms would move back and forth about 4mm so I assume you already have spacers in now.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 04-27-2010, 12:15 PM   #12262
Hoping someone can offer a little setup help. I have a TC5R with the out of box rubber setup w/ slipper spool on it with the exception of a 1.25 (black) sway bar in front and an addition 1mm shim (2mm total) on the rear hub to angle the link more and free up the back end. Running rubber tires on asphalt. I need more steering everywhere but especially off power and the slower 180s. Like I said I need more everywhere, but more noticeably in those areas. I was thinking 2.5 or even 2 deg of rear toe (down from 3) or playing with ackerman. Any suggestions? Thanks in advance!
g26er is offline   Reply With Quote
Old 04-27-2010, 12:21 PM   #12263
ChadB.'s Avatar
Trader Rating: 21 (100%+)
Is this for asphalt or carpet?
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 04-27-2010, 12:28 PM   #12264
Runner on asphalt. Thanks!
Old 04-27-2010, 12:47 PM   #12265
ChadB.'s Avatar
I would use Rick Howart's set-up from West Coast Rc Raceway. Most of all the recent set-ups from Team Asscociated are all pretty close. But I would start with this set-up and go from there.
Chad Burdick
Old 04-27-2010, 02:23 PM   #12266
The TC5R kit setup has a good amount of steering under most circumstances. If you haven't already, use the o-ring/washer soft mounts for the front of the top deck. Use some blue Loctite on the screws and don't tighten them very tight. Try no bar up front. You can raise the droop in the back, but you might get tail happy. Different tires seem to like different camber, so that's a hard call. HPI Vintage tires like very little camber -- 1° or less. Other tires like up to 3°. I don't know what to tell you there. I'm also not stingy with the tire sauce. The TC5 also seems to dislike hard throttle and brake application. For a long 180, try straight-line braking, maintenance throttle through most of the corner, slow throttle application from about mid-corner on out. Mine gets very loose if I go in too deep or lift in mid corner.
“There’s little point in writing if you can’t annoy somebody.”- Kingsley Amis
jhberger is offline   Reply With Quote
Old 04-27-2010, 04:14 PM   #12267
Thanks! Already did the o-ring/blue countersunk washer thing. I will try no sway bar up front. I've tried sauce and no sauce and it's still pushy. Unlike what you've experienced I can nail the throttle at any point going in, during or coming out of the turn and the rear is flat out planted. I can lift or break hard or peg the throttle at any point during the turn and the rear maintains composure always. Tires were Absolute 32 and ambient temps in the high 80s I'd guess. Very stable but really lacking corner speed.
Old 04-27-2010, 05:05 PM   #12268
g26 -- Sounds like you have an abundance of rear grip. My tendency would be to work on the back to get the front to behave a little better. Raising the rear ride height would get the weight to go forward better under braking. Reducing the rear toe will make the back less stable, but you may pay a price with twitchiness down the straight. That's also a pain to change on the TC5, so maybe I'd try stiffer springs, stiffer bar, or less wing first.
Old 04-27-2010, 06:55 PM   #12269
Thanks I'll keep that in mind. For what it's worth the back tires have almost no wear... just scrubbed the mold line off whereas the front tires show wear for sure though not terrible. On the scales I'm about 10 grams lighter in the front than the rear.
Old 04-28-2010, 06:15 AM   #12270
robsryd's Avatar
Send a message via ICQ to robsryd
Definitely no front sway bar. My suggestion would to work mainly on springs, droop and toe. One thing I learned is that no one set up works for anyone other than the one who set it up. Nobody drives alike, so use anothers set up sheet as a start point ONLY. go from there. Make one change at a time, test than tune, test then tune.
Racing. Because baseball, golf, football, bowling,tennis and soccer only require ONE BALL!
Trains and Lanes Paved and off road tracks (slots too!) Easton, Pa. Race'm if you gotte'm!
robsryd is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
