Old 04-15-2010, 09:10 AM   #12211
Rick Hohwart's Avatar
Originally Posted by blanks596 View Post
How do you fellas get rid slop in the steering? Has anyone tried using other manufactures linkage and steering systems? ie-ball studs, pivot balls, etc...
I am some of the other AE drivers cut a small square piece (approx 3.5mm square) of plastic bag (thin gauge tire bags work well) and place it inside the ball cup. Then you pop the cup back on and the slop should be reduced but the movement will still be free (it is better to be too loose than too tight).
Some servos can have some play so make sure this is not where the problem is. Also, the bearings can be loose inside the steering system. You can tighten these by taking the back side of an Xacto blade and making a couple of "cuts" to the aluminum so that the bearing will fit in tightly.
Rick Hohwart is offline   Reply With Quote
Old 04-15-2010, 03:55 PM   #12212
xtrememadness's Avatar
Send a message via AIM to xtrememadness
hey rick when you run the rc8 servo horn with the servo in standard position do you have the steering linkage straight or at an angle. i run a futaba 9452 with the ball in middle hole and in front on short side of horn but its at a slight angle. thanx
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 04-16-2010, 12:21 AM   #12213
blanks596's Avatar
Trader Rating: 14 (100%+)
thanks fellas! I put the plastic between the cups after drilling the holes in them. It took away enough slop to keep my car from drifting on the straight at West Coast last night- Now I just have to spend a bit more time playing w/different setups
Serpent/Desoto Racing
Max S
blanks596 is offline   Reply With Quote
Old 04-16-2010, 04:31 AM   #12214
robsryd's Avatar
Send a message via ICQ to robsryd
I used X Ray steering ends on my TC5, works great. The links on the bell crank will need a little sanding to stop binding, but once you do this, its like no other. This set up can't be beat, bullet proof! ZERO slop!!!
Racing. Because baseball, golf, football, bowling,tennis and soccer only require ONE BALL!
Trains and Lanes Paved and off road tracks (slots too!) Easton, Pa. Race'm if you gotte'm!
robsryd is offline   Reply With Quote
Old 04-16-2010, 04:54 AM   #12215
robsryd's Avatar
Originally Posted by jeremy mac View Post
Hi guys, i saw a few posts back Ackermann was mentioned. Could anyone please give me some info on how to adjust this, and what the adjustments do?
We are running foams (35shore) on mid grip asphalt here in NZ for mod if that makes a difference.
Thanks,
Jeremy
Ackerman is the amount of over steer the tire turning in will have. For example, when you turn the steering to the right, the left wheel will turn, lets say 45 deg. and the right wheel will turn 50 deg, giving your car a little more steering. This can slow you down a bit, being the two tires are turning at different angles and driving at the same time. I use Integy's steering knuckles that have 4 holes for adjustment and it turned my TC5 into an infield battle wagon! It now turns on a dime.
Check out Xtreme RC cars magazine, March 2010, for a complete explanation of Ackerman
Old 04-16-2010, 09:32 AM   #12216
Good find on that article. Explained Ackerman nice and simply and the effects of different positions.
Have you had any problems with the Integy Al steering knuckles? Do they increase C hub breakage? Is the bearing size the same as stock?
spongerX is offline   Reply With Quote
Old 04-16-2010, 09:40 AM   #12217
Mine is slightly angled.
Old 04-16-2010, 04:45 PM   #12218
BrowniesHobbies's Avatar
[QUOTE=Rick Hohwart;7280393]Mine is slightly angled.[/QUO
John Brown
Brownies Pro & Sport Hobbies www.brownieshobbies.com www.letshelpgreg.com
Winner Innaugrial SJCCR Slowbirds Nationals "VINTAGE CHAMPION" thanks Greg
Winner 2015 VTA SJCCR Slowbirds Nationals
SIRCCC (Staten Island Radio Control Car Club)
BrowniesHobbies is offline   Reply With Quote
Old 04-16-2010, 06:32 PM   #12219
dragont's Avatar
Yes, the bearing is the same as the stock.
HOY BAKLA!!!! U DA BU LA'IA!!!!!!
dragont is offline   Reply With Quote
Old 04-16-2010, 07:50 PM   #12220
thanx rick just making sure
Old 04-17-2010, 11:26 PM   #12221
pakk's Avatar
Trader Rating: 79 (100%+)
That is where I ended up after racing tonight. Night and day difference. It is so much better. I won't lie though. I could always use more steering. The car handles very well on every part of the track except for high speed on power steering. If I can manage to get more, I would be very pleased. If not, I will just get used to driving it the way it is.
Any suggestions? I'm going to the track again in 6 hours.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 04-18-2010, 04:55 AM   #12222
bfong13's Avatar
Trader Rating: 17 (100%+)
See, I told you so...
Try thicker front oil.
bfong13 is offline   Reply With Quote
Old 04-18-2010, 05:10 AM   #12223
pakk's Avatar
Ok, will do. Will I get the same effect from just moving the shocks in more vertical?
*Photon* *SC10 4x4*
RCRD
Old 04-18-2010, 05:21 AM   #12224
bfong13's Avatar
It won't have the same effect.
Also, do you have an extra ball diff for the front? I know you said that you didn't want to use the 1-way, but do you have an extra diff to try in the front? A front diff may give you the effect you want.
My setup is almost the same as yours except I'm running 40wt all around, 6deg caster, black sway bars all around, and a front 1-way. I have incredible on and off power steering.
Old 04-18-2010, 06:25 AM   #12225
pakk's Avatar
I really want to put my 1 way back in, but there is a big race coming up and they won't allow 1 ways!
I do have a ball diff. I'll see if I can get it together. I tried black sway bars, but it made my car feel like it was on ice. I don't know why they wont work for me. Everyone else seems to like them.
Today, I'm going to try 40 wt oil and 6degree caster blocks. I'll report back later today.
*Photon* *SC10 4x4*
RCRD
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
