Old 02-23-2010, 05:02 PM   #11986
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
Hey guys. Been away from touring cars a while and had a few questions. The
TC5R is for rubber but can you really get it stiff enough in high traction events? I've always liked the real stiff chassis in the past. I was leaning towards the
TC5F just because it has the thicker chassis.. Thanks..
Trinity / Team Epic / ReVtech Batteries / TRC / F-Bomb Graphix
DHMOTORSPORTS is offline   Reply With Quote
Old 02-23-2010, 05:20 PM   #11987
MikeR's Avatar
Trader Rating: 14 (100%+)
All trends have gone to a more flexible chassis for rubber tires. All current top level designs have gone to great lengths to bring back more flex in fact. Just works better
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 02-23-2010, 06:01 PM   #11988
6 years ago the flex was for asphalt.lol It was un heard of for carpet. The old cars I remeber that were flexi would hold a tweek sometimes. But that was then and this is now...
Old 02-23-2010, 06:22 PM   #11989
Warren Weaver's Avatar
Trader Rating: 43 (100%+)
I run the tcfs on carpet and asphalt its all in the setup me and donny lia ran the cars at jackson with the carpet chassis and they were wicked fast i almost won the 17.5 class at the xray challenge with it.Flex adds to figuring your geometry out and is inconsistent a stiff chassis is very consistent.
R1 WURKS-AWESOMATIX USA-LRP-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 02-23-2010, 06:26 PM   #11990
bvoltz's Avatar
Trader Rating: 44 (100%+)
Stiff is for carpet / foam (HIGH traction)
Flex is for rubber...
bvoltz is offline   Reply With Quote
Old 02-23-2010, 06:46 PM   #11991
Thank you Warren. Thats a better way of what i was thinking and or trying to say..
Old 02-23-2010, 07:06 PM   #11992
Hey I have a couple of stupid questions. building my first touring car in about 10 years and I went with the tc5r.1. when setting droop what is the best way to do this? 2. when setting toe in the back with shims if the setup calls for 3 deg and I put 3deg worth of shims per side do I have 3 deg total or 6 deg total. I've read a couple different answers on this so not real sure. Any info would be great. Thanks!
blownova65 is offline   Reply With Quote
Old 02-23-2010, 11:40 PM   #11993
Send a message via AIM to carrera0to60
Assuming that you have the 0* rear hubs and 3* of shims you would have 3* total. You do not add the two sides together. For setting the droop look at the TC5 documents section on the AE site. I would post a link but I dont have enough posts yet.
carrera0to60 is offline   Reply With Quote
Old 02-24-2010, 08:37 AM   #11994
no problem if you need some setup help let me know i have a dialed setup for it.
warren
Old 02-24-2010, 08:56 AM   #11995
rced1's Avatar
Trader Rating: 17 (100%+)
The best way to set droop is whichever method works best for you. I know this is not the answer you was looking for.
Here is the link I think carrera0to60 mentioned:click here.
Here is a picture of the droop gauge in use: click here.
Slow is fast.
rced1 is offline   Reply With Quote
Old 02-24-2010, 11:47 AM   #11996
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
warren
Hey Warren does this setup happen to work at Frederick on their asphalt? I seen your car worked pretty good at Jackson last year. I hope to run a race or two at Jackson this year.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 02-24-2010, 12:05 PM   #11997
should work awesome there i think the bite is high at that track so iwould say a slightly stiffer front spring over what i normaly run should work great.
Old 02-24-2010, 01:31 PM   #11998
wyd
Tech Legend
wyd's Avatar
Cool. I would be interested in a rough setup if you have something you think will work. Never actually had any luck with a TC5R other than outdoors at Trains and Lanes but other than that never had the car work that well for me. I hope this time around with an almost brand new car things will be better for me. Short on cash and can't afford to do the touring car of the week thing. Its this car or bust for me so I need to make it work at fairly decent. Don't need to win but just something thats drivable and reasonably consistant.
Old 02-25-2010, 07:21 AM   #11999
Here is the set up sorry for delay busy at work
ride height 5mm f and r
2degrees of camber front 1.5 rear
6 degree caster
rear hub toe 0 degree
0 degree front toe
rear total toe 3 degrees
hex spacing .5 front and rear
2 mm wheel base f and r
1 and b steering link
2.5 mm bumpsteer
front shock position 1
rear shock position 2
camber links f and r 3
outer ball shims 0 f and 2.5 rear
arm mounts 3 f and r b
droop 6 and 5
1.5 mm roll bar f and r
25 wt oil f and r with losi 56 and full rebound
blue springs f and r
spool front/diff rear loose
let me know if i left any thing out
warren
this is the setup except i changed to a thin bar in the front and none in the rear and the shock positions were in the 1 hole on the tower front and rear.
hope this helps
warren
Old 02-25-2010, 12:27 PM   #12000
wyd
Tech Legend
wyd's Avatar
hope this helps
warren
Thankyou. This is a big help. Anything is better than i had in the past.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
