Old 02-19-2010, 09:23 PM   #11971
geeunit1014's Avatar
Originally Posted by carrera0to60 View Post
I just picked up a second hand TC5R and so far Ive torn it completely down back to kit form so I could inspect all the parts and clean them while I was at it. Im going to be running in a 13.5 class at the LHS in the parking lot. I figured I would start out with the stock rubber config from the manual and go from there. Anyone have any big changes to that to start out with? Also I want to go with the Mamba Max pro since I mostly own all CC stuff but since there smallest KV motor is 4600 Im kinda at a loss with that portion.
The 4600 will be around a 10.5 or so. Castle motors are not approved for spec classes, but they are legal for open mod. For 13.5, popular choices for motor are the Duo line (1 & 2), and the novak ballistic
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 02-19-2010, 10:35 PM   #11972
Send a message via AIM to carrera0to60
Thanks for the suggestions. After doing some research I think Ill go for the Novak motor. Any thoughts on the HPI x-pattern tires vs the normal jaco or similar slicks. Im thinking on a partially prepped parking lot (swept only) that the slicks wont do all that well since theres going to be small amounts of sand and pebbles left behind.
carrera0to60 is offline   Reply With Quote
Old 02-20-2010, 05:26 AM   #11973
Im new to the TC5R. I have no clue what a one way means? I have one installed in the front on my car.
Traxxas Slash 4x4, 3s/2s lipo's----Losi Mini T with MMP 8000kv, 3s lipo----Losi Comp Crawler, 3s lipo--Clod Crawler----RC8TE with MMM 2200kv, 4s lipo----TC5R with Xcelorin 3.5, 2s lipo----B44 with Havoc Pro 5.5,2s lipo----Traxxas Slash 1/16 brushless, 2s lipo----TC4 with sidewider 4600kv,2s lipo----Ve8 Tekin T8 2050kv, Maxamps 4s lipo
flatlander13 is offline   Reply With Quote
Old 02-20-2010, 07:43 AM   #11974
rced1's Avatar
Trader Rating: 17 (100%+)
A oneway is basically a locked differential. Grab one of your front wheels and try turning it forward and backwards. See the way the other tire on the front can only turn in one direction and not the other? Now try it on the rear with the diff. The other tire turns in the opposite direction.
When going around a corner the outside wheel covers more distance than the inside wheel. The dif allows the wheels to turn at different speeds.
Advantages of a oneway can be more corner speed with high traction.
A disadvantange is if you need to do heaving braking.
Slow is fast.
rced1 is offline   Reply With Quote
Old 02-20-2010, 03:07 PM   #11975
Trader Rating: 5 (86%+)
Default smc 4100
I have a smc 4100.....2s lipo and I was wondering would it hold up in a race....or would it fall completly off...17.5 is the class
obi wun is offline   Reply With Quote
Old 02-20-2010, 03:43 PM   #11976
rced1's Avatar
A SMC 4100 should hold up fine. I run SMC 3200 28c in spec class with no problems.
Slow is fast.
Old 02-22-2010, 08:13 AM   #11977
hi
iv just finished machining another batch of uprated bulkheads if anyones after a set.
[email protected]
[email protected]
thanks greig
leg iron is offline   Reply With Quote
Old 02-22-2010, 12:23 PM   #11978
I am going to be purchasing a tc5r, and was wondering what all breaks on the car so I can have a few spares. Also what springs to use and if they are the same springs from the tc3?
jiggamacdaddy is offline   Reply With Quote
Old 02-22-2010, 12:30 PM   #11979
trerc's Avatar
Trader Rating: 89 (100%+)
Yep, same springs. Be sure to buy a Parma hard bumper to protect the caster/steering blocks, other than that it's pretty tough.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 02-22-2010, 01:25 PM   #11980
does the tc5r kit come with the lipo batter holder or do i need to get that seperate?
Old 02-22-2010, 01:57 PM   #11981
bfong13's Avatar
You need to purchase an aftermarket lipo tray such as the Associated or Diggity Designs trays.
bfong13 is offline   Reply With Quote
Old 02-22-2010, 01:58 PM   #11982
bfong13's Avatar
+1 on the Parma Bumper...I haven't broken anything since I bought one.
Also, get the B4/T4 diff nut for the front spool and rear diff.
Old 02-22-2010, 02:30 PM   #11983
You're not likely to use more than 1500 mAh in a heat. 4100 should be plenty.
jhberger is offline   Reply With Quote
Old 02-22-2010, 09:17 PM   #11984
Trader Rating: 20 (100%+)
Just replace the bearings in the center line with ceramics and use metal shields in the blocks and carriers. The outside bearings take too much abuse to replace with ceramics. I buy all my bearings from avid, you could replace all the center with ceramics for $30 ($5ea.) and the rest are a buck a piece.
Ok that sounds like a better cheaper idea.. I bought my car used any idea what size I need for the center line bearings? Heres what I have let me know if Im correct please : 5x8x2.5 x2, 10x15x4 x2 and 8x4x3 x2. Also I'm guessing just need 8 6x10x4 for the outside metal shielded is that correct?
1sicls1 is offline   Reply With Quote
Old 02-23-2010, 03:52 PM   #11985
Bruce Grembowski's Avatar
I've been running a TC5 for about 3 years. I used to break a lot of arms/c-hubs and a few rear hub carriers (I had a *lot* of "board meetings"). I replaced them with aluminum versions from Integy; since then, I've broken a few arms or arm mounts.
I've also had problems with the steering servo saver and horns. Again, this is most likely due to board meetings.
I also switched to RPM ball cups to tighten up the steering.
HTH,
Grem
Bruce Grembowski, ROAR #11-115675
Rose City Scale Racing (http://www.rosecityscaleracing.com)
Bruce Grembowski is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
