Old 02-16-2010, 10:38 PM   #11956
Trader Rating: 20 (100%+)
I'm looking for a good bearing set for my TC5, preferably ceramic. Does anyone know of a good set or could point me in the right direction?
1sicls1 is offline   Reply With Quote
Old 02-16-2010, 10:45 PM   #11957
pcar951's Avatar
Trader Rating: 19 (100%+)
Acer, hadem in my TC5, gotem in my T3. The best IMO.
pcar951 is offline   Reply With Quote
Old 02-17-2010, 04:41 AM   #11958
trerc's Avatar
Trader Rating: 89 (100%+)
Just replace the bearings in the center line with ceramics and use metal shields in the blocks and carriers. The outside bearings take too much abuse to replace with ceramics. I buy all my bearings from avid, you could replace all the center with ceramics for $30 ($5ea.) and the rest are a buck a piece.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 02-17-2010, 10:23 AM   #11959
katfish317's Avatar
+1 on not using ceramics all around. Save yourself some money and use the standard metal shielded bearing inthe hubs and you will be fine!!! I use Avid bearing in all my cars and trucks. The price for a ceramic set at Boca is like $95.00 I think for the TC5, it is not wrth that kind of money, one good hit and the bearing is toast anyway!
I usually buy like two dozen bearings for 24 boucka nd that will last two seasons, unless you replace them all the time.
katfish317 is offline   Reply With Quote
Old 02-17-2010, 12:18 PM   #11960
Default Avid
Got a web address or contact for Avid?
jhberger is offline   Reply With Quote
Old 02-17-2010, 12:27 PM   #11961
trerc's Avatar
http://www.avidrc.com/?gclid=CJnk7-6a-p8CFRMhDQod-DKbbQ
Old 02-18-2010, 09:11 AM   #11962
I just got back into racing and i have always been a AE guy, but what is the difference In FT TC5 and the FT TC5R ?
I need help because i can buy a tc5 cheap but want to race rubber
thanks for the help
LBR-Low Budget Racing
travis_g is offline   Reply With Quote
Old 02-18-2010, 09:42 AM   #11963
Hebiki's Avatar
Trader Rating: 26 (100%+)
thanks for the help
several explanations are available on page 797.
Hebiki is offline   Reply With Quote
Old 02-18-2010, 01:49 PM   #11964
What is a good starter servo and ESC for somebody just getting back into racing and i will be doing it on carpet rubber tires
Old 02-18-2010, 01:53 PM   #11965
Regional Moderator
Jon Carlson's Avatar
Trader Rating: 47 (100%+)
Tekin RS and a Futaba 9551. I wouldn't buy cheap electronics because you usually end up buying better stuff later and spending more in the long run.
Jon Carlson
Team Associated, Reedy
Futaba, OS Engines, O'Donnell Racing Fuel
Jon Carlson is offline   Reply With Quote
Old 02-18-2010, 03:13 PM   #11966
So it is good to use the tekin rs and not the rs pro ?
Also so whats are good spec for Tc servo rates for speed and torque?
Old 02-18-2010, 03:25 PM   #11967
Regional Moderator
Unless you are running motors lower than 5.5 you won't need an RS Pro. For a servo... I'd go around .10 for speed and over 100oz of torque.(Make sure you check the 6v specs.) The Futaba is also nice because it's low profile so it doesn't push the weight out to the left more.
Jon Carlson
Old 02-18-2010, 07:13 PM   #11968
hey thanks alot for the info and the help.
Now on to my next question where can i get a good starter setup for 13.5 rubber on carpet or maybe 17.5
Old 02-18-2010, 07:26 PM   #11969
Regional Moderator
The setup sheets can be found in this thread(somewhere in the last 5-10 pages) or at www.rc10.com Try Hebert's 17.5 rubber setup.
Jon Carlson
Old 02-19-2010, 09:15 PM   #11970
Send a message via AIM to carrera0to60
I just picked up a second hand TC5R and so far Ive torn it completely down back to kit form so I could inspect all the parts and clean them while I was at it. Im going to be running in a 13.5 class at the LHS in the parking lot. I figured I would start out with the stock rubber config from the manual and go from there. Anyone have any big changes to that to start out with? Also I want to go with the Mamba Max pro since I mostly own all CC stuff but since there smallest KV motor is 4600 Im kinda at a loss with that portion.
carrera0to60 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
