Old 02-10-2010, 10:42 AM   #11926
katfish317's Avatar
Protoform Mazda 6 or speed 6, LTC RF-9, all 190mm bodies will work
katfish317 is offline   Reply With Quote
Old 02-10-2010, 10:43 AM   #11927
Thank you!
Now i can order a body
Traxxas Slash 4x4, 3s/2s lipo's----Losi Mini T with MMP 8000kv, 3s lipo----Losi Comp Crawler, 3s lipo--Clod Crawler----RC8TE with MMM 2200kv, 4s lipo----TC5R with Xcelorin 3.5, 2s lipo----B44 with Havoc Pro 5.5,2s lipo----Traxxas Slash 1/16 brushless, 2s lipo----TC4 with sidewider 4600kv,2s lipo----Ve8 Tekin T8 2050kv, Maxamps 4s lipo
flatlander13 is offline   Reply With Quote
Old 02-10-2010, 11:10 AM   #11928
What's a good gear ratio to run in the TC5 for street driving?
Erik
Old 02-10-2010, 11:18 AM   #11929
revo61's Avatar
Trader Rating: 18 (95%+)
What motor will you be running? Are you racing or bashing?
Erik
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 02-10-2010, 11:34 AM   #11930
I will be running a Losi Xcelerion 3.5t sensored. I will be bashing a lil but mostly racing.
Old 02-10-2010, 12:02 PM   #11931
Trader Rating: 23 (100%+)
Send a message via AIM to AxiomJacob
Whats the best way to get more turn in out of the car? I've running the IIC 2009 setup and having it push in and little loose off. On the straight the inside rear will spin before the car takes off.
Jacob
Proline Racing
AxiomJacob is offline   Reply With Quote
Old 02-10-2010, 12:02 PM   #11932
BadSign's Avatar
Trader Rating: 15 (100%+)
Depends on your class. 190mm for the standard touring classes. Things change if you decide to run VTA or RCGT.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 02-10-2010, 04:49 PM   #11933
Airflow's Avatar
After street racing last night with my tc5r, I cleaned it and noticed a
thin long twig got caught between the steering block and the aluminum
hex hub. The curled twig damaged the bearing seal. And I dont have a
spare, I just cleaned it and flipped it. Will take weeks for our LHS to have
replacement axle bearing.
Can I use a metal shielded axle bearing from any Tamiya RC kits?
Some hobby shop carry more Tamiya stuff so that is my option
Thanks in advance
Airflow is offline   Reply With Quote
Old 02-10-2010, 05:01 PM   #11934
xtraman122's Avatar
Trader Rating: 42 (100%+)
Anything Tamiya will probably be metric, so it won't fit, but if something does then go for it.
xtraman122 is offline   Reply With Quote
Old 02-10-2010, 05:24 PM   #11935
Airflow's Avatar
I have the TC5R which uses metric screws and totally different from what
my TC4 is using (well except for the 3-32 diff balls). In the manual it says
6x10 bearings. I believe that's metric. Any Tamiya counterpart axle bearing?
Old 02-10-2010, 05:33 PM   #11936
trerc's Avatar
Trader Rating: 89 (100%+)
A 6x10 bearing is a 6x10 bearing, doesn't matter if it's made for a roller skate, if its 6x10 it'll work. I don't know for sure if Tamiya will have one that works for you but the size is common and most shops sell bearings individually. I buy mine from http://www.avidrc.com/
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 02-10-2010, 06:47 PM   #11937
Airflow's Avatar
Found it, thanks
Old 02-11-2010, 05:24 AM   #11938
revo61's Avatar
Ask some of the guys at the track you will be racing at, but you can try 9 or 10 fdr. Do a few laps and check temps. www.gearchart.com
Old 02-11-2010, 12:26 PM   #11939
miquelmah's Avatar
this is my "suicide tc5":
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
miquelmah is offline   Reply With Quote
Old 02-12-2010, 07:10 AM   #11940
I'm having some problems getting the rebound set right on 2 of my TC5r shocks. I changed the weight of the oil and now I can't get 2 of the shocks to rebound evenly. I've got small holes drilled in the caps already. I've never had this problem before.
The procedure I use is as follows:
1) fill the shocks with oil, move pistons up and down to get the air bubbles out. Let sit for a while then top up with oil so that oil is level with the top of the shock.
2) Fit bladder into shock cap (with no foam above).
3) Push shock shaft right into the shock slowly so that the ball stud is flush with the bottom of the shock body. There is very little oil above the shock piston but no air bubbles if done slowly.
4) screw on shock cap and displace oil.
This worked fine for 2 shocks but the other 2 I can't get to not rebound. They don't even rebound at the same rate. This procedure has worked fine for me in the past but for some reason I'm having no end of trouble this time around.
Do I need to drill bigger holes in the caps? I used a really small drill to do it last time but the hole is not blocked by anything.
Any ideas on how I can get these shocks to not rebound or at least to rebound evenly would be great.
spongerX is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
