Old 01-31-2010, 08:47 PM   #11866
trerc's Avatar
Trader Rating: 89 (100%+)
Originally Posted by Jsaves View Post
Had a great time racing the TC5R this Sunday. The car worked great and was really hooked up on a med to low traction carpet.
All stock parts except for the PPD lipo set up.
Great CAR
Yep, I have the Exotek chassis- top plate but I love the TC5. It's durable and if you do break it parts are everywhere and dirt cheap. The car is also easy to set up and quite forgiving.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 02-02-2010, 11:22 AM   #11867
Suspended
Hi, whats needed to fit xray ecs driveshafts into a tc5 using a titanium racing spool, thanks.
PinkFloyd is offline   Reply With Quote
Old 02-02-2010, 11:27 AM   #11868
trerc's Avatar
Look back a little in this thread, Christer Andersson answered this question, Also you can cheap oout a little and save about 50% on a set of the knock off Atomics unless you already have the Xrays
Old 02-02-2010, 09:43 PM   #11869
Trader Rating: 27 (100%+)
Ok so today at practice I am driving down the straight with a 13.5 motor pinned and all the 17.5 motors are even with me.. I didnt have my LRP speedo programmed to 8 so I changed that and I didnt notice a difference.. The guys said I should be smoking them with the gearing I have.
I dont know what gives.
C_Money is offline   Reply With Quote
Old 02-02-2010, 11:27 PM   #11870
Hi
What affect does small tires have on roll center compared to larger tires, like 58mm foam vs 56mm or 64mm rubber vs 63mm rubber
Thanks Ya`All
MoonTrap is offline   Reply With Quote
Old 02-03-2010, 05:17 AM   #11871
trerc's Avatar
They are likely running the new Tekin software
Old 02-03-2010, 12:38 PM   #11872
OI didnt have my LRP speedo programmed to 8 so I changed that and I didnt notice a difference.. T
Which one LRP? There is a lot of them, maybe you have LRP without
advanced timing (new one) and there is your problem.
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 02-03-2010, 05:26 PM   #11873
m.
I have the LRP Sphere TC Spec...
Old 02-03-2010, 05:30 PM   #11874
So basically with the Sphere TC Spec at 8 I am still going to get the run around from the Tekin? And will be even slower with the 17.5 cause I am running 13.5 now and the 17.5's are way fast?
Also next question.. As for gearing with a 17.5, what do you guys suggest? I know a lot of guys play with gearing but I dont have a ton of money to throw around with it. I know it depends on track size and stuff... My track is semi small 7 to 8 turns and a straight that is over 50'..
Old 02-03-2010, 05:38 PM   #11875
It also depends on the ESC, software and motor. Gear it at 6 and start going down till you get to around 160F
If you want to be fast, get a TEKIN RS with the Vegas soft ...
____________________
www.RCActionPics.com
Rojna is offline   Reply With Quote
Old 02-03-2010, 05:52 PM   #11876
trerc's Avatar
The Sphere TC Spec is at a definite disadvantage in comparison to the newer ESC's and technology as you are seeing. The 17.5 now runs like yesterdays 13.5
Old 02-03-2010, 08:46 PM   #11877
So which LRP is the best choice now?? and will it be as fast as the others? The motor has nothing to do with it does it?
I know there is a stock spec and a competition one.. I don't think I would get the stock one cause what if I wanted to switch motors? Or is the stock one a good choice?
Old 02-03-2010, 09:15 PM   #11878
If you are running stock, then TEKIN RS is your best choice, the LRP's cant do it in stock classes ...
Old 02-03-2010, 09:15 PM   #11879
trerc's Avatar
I prefer the Tekin RS that way I don't need to buy the newest LRP to replace my outdated LRP, I can just update my current ESC.
Old 02-03-2010, 10:26 PM   #11880
really? with the tekin thats all it takes is a update? No need to buy a new one?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
