Old 01-29-2010, 04:37 PM   #11836
fathead's Avatar
Originally Posted by Tag View Post
i noticed on the AE setup sheets most racers run a really high droop value like 6 front 5 rear ) are these meant to be dropdown value ? misprint ?
Those are the AE droop gauge values not mm.
Slavich Design
fathead is offline   Reply With Quote
Old 01-29-2010, 04:56 PM   #11837
Tag
Tag's Avatar
Trader Rating: 30 (100%+)
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 01-29-2010, 09:10 PM   #11838
chrisfrom619's Avatar
Send a message via Yahoo to chrisfrom619
Default TC5 Belts
I have a question about swapping the belts location for those of you that did it. Do you have to swap the location of the T-nut from left to right or vice versa? I know on some cars if you install the t-nut on the opposite side the diff will loosen by itself while driving.
#1 Sponsor: Wifey
Hpi baja, traxxas e-maxx,slash, AE TC5R, RC18R,SC10, Thunder Tiger EB4 S2, and Futaba 4pk
DHW Raceway San Diego CA.
Novice Class
chrisfrom619 is offline   Reply With Quote
Old 01-29-2010, 09:26 PM   #11839
MetalShield's Avatar
Shot this video of my buddy's TC5 during some practice and captured him hitting the wall at high speed... Epic fail! check it out. 48sec.
http://www.youtube.com/watch?v=KyuLsvJPJXM
Calvin Mercer - MSPvideos
HobbyHobby Racing Team / XXXmain Inc.
MetalShield is offline   Reply With Quote
Old 01-30-2010, 01:37 PM   #11840
Trader Rating: 27 (100%+)
That video is pretty funny..
I have a question, right now I have a one-way in my car and I am racing carpet.. Would it be better to change to a spool? Such as the titanium racing one?
C_Money is offline   Reply With Quote
Old 01-30-2010, 05:24 PM   #11841
rced1's Avatar
Trader Rating: 17 (100%+)
Try reading this topic. It explains the different characteristics of each: one way vs diff vs spool for the front?
Slow is fast.
rced1 is offline   Reply With Quote
Old 01-30-2010, 05:33 PM   #11842
Andy63's Avatar
i would get a spool, even if you raced stock. You need the brake, and those speeds stock are racing these days, you really need a spool to brake.
one way is just for easier front turning and roll through corners really, and no brake in front = hard braking with touring car! not much more.
Hope it helped
www.andrefossto.wordpress.com
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |MIBOSPORT.COM |
Andy63 is offline   Reply With Quote
Old 01-30-2010, 05:39 PM   #11843
trerc's Avatar
Trader Rating: 89 (100%+)
A one way is fast on an open track that doesn't require much braking just take some brakes out of the car when using one so you don't upset the car if you do brake hard. for smaller tight track the spool is the way to go.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-30-2010, 05:40 PM   #11844
Tag
Tag's Avatar
Default diff locknut
hello guys, i was rebuilding my rear diff and i tripped the diff locknut ( associated part number 31166 ) just wondering if i can be able to get those separately instead of getting the whole diff rebuild set ?
i found this one from amain hobbies is this it ?
http://www.amainhobbies.com/product_...Associated-TC5
Old 01-30-2010, 05:47 PM   #11845
trerc's Avatar
Use this, you'll never have that problem again.
http://www3.towerhobbies.com/cgi-bin...?&I=LX2869&P=7
Old 01-30-2010, 05:54 PM   #11846
damage's Avatar
Hi,
You'll be much better off getting ride of it and going back to the t-nut setup used in the TC3. Lots of TC5 owners replace this immediatly as it is a very weak point in the diff and will strip very easily.
http://www.amainhobbies.com/product_...tial-Screw-Kit
http://tinyurl.com/Wiocr
Tamiya Hornet, Airtronics XL2P, Novak 4, 1200 SC Stage III batteries,
Navcom 10 peak, 12 volt lead acid power source
damage is offline   Reply With Quote
Old 01-30-2010, 05:56 PM   #11847
trerc's Avatar
Here's another option,
http://www.amainhobbies.com/product_...Duty-T-Nut-Set
To be used with the Tamiya caged thrust bearing.
http://cgi.ebay.com/49300-AO5016-Tam...item5636c902c1
Old 01-30-2010, 05:58 PM   #11848
Tag
Tag's Avatar
hum..isnt this for rc10s ? yeh i have been having major problem with my tc5 diff , it's really a pain to rebuild , anything that can ease the process is certainly help..
Old 01-30-2010, 06:02 PM   #11849
trerc's Avatar
Not Specifically, It's Associateds generic diff screw, they've used it in many of their vehicles. It's MUCH better than the stock TC5 diff screw and nut.
Here's another link to it from Associateds site
http://67.199.85.166/main/productdet...ory=3045.tc3xx
Old 01-30-2010, 07:02 PM   #11850
Tag
Tag's Avatar
hey much appreciated for all the helps guys i am going to get some tomrrow and hope it will end my diff rebuilding nightmare
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
