Old 01-26-2010, 08:02 PM   #11821
Trader Rating: 23 (100%+)
Send a message via AIM to AxiomJacob
What is the purpose of running the belts on the opposite side as the manual says from rear to spur then spur to front?
Jacob
Proline Racing
AxiomJacob is offline   Reply With Quote
Old 01-26-2010, 08:13 PM   #11822
trerc's Avatar
Trader Rating: 89 (100%+)
For one it's much easier to change the pinion.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-27-2010, 01:47 AM   #11823
Robert_K's Avatar
Now your spool wears on the other side
It's about balance. Lipo's are less wide then Nimh's because of the battery bars they don't have. And Lipo's are lighter. Now it's possible to flip you belt's. This creat's more room for the elec's to be placed further inward... With High grip you want to have everything as much inward as possible. Lowgrip, you want all more "outward". Normally the grip is high ;-), sow everything more inward.... Also the car is better balanced when the elec's are placed more inwards.
I've converted my TC5X to a Losi front end, with LCD axles. But I didn’t order the Losi Clamp Types. The Assocaited ones don't fit. What brand clamp types are you guy's using? (or, which one's are 5mm inner diameter)
Best Regards
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 01-27-2010, 02:15 AM   #11824
defcone's Avatar
Trader Rating: 15 (100%+)
How do you guys take away steering slop.
defcone is offline   Reply With Quote
Old 01-27-2010, 02:50 AM   #11825
fathead's Avatar
I've converted my TC5X to a Losi front end, with LCD axles. But I didnít order the Losi Clamp Types. The Assocaited ones don't fit. What brand clamp types are you guy's using? (or, which one's are 5mm inner diameter)
Best Regards
Robert
TC4 aluminium clamping wheel hex's, it is what I used when I put Losi LCD on my car.
Slavich Design
fathead is offline   Reply With Quote
Old 01-28-2010, 10:01 AM   #11826
Does anyone run the tc5 lipo craddle that AE offers? How does it fit with Thunder Power 5000s?
Thanks.
Jacob
Proline Racing
Old 01-28-2010, 10:38 AM   #11827
Rick Hohwart's Avatar
Best Regards
Robert
This should work or you can use the Losi plastic nopn-clamping style hexes (what I use)
You can take away the slop in the ball studs by placing a small piece of plastic bag inside the cup before uou pop it on to the ball. You will have to play with plastic thickness but it has to be thin. You can tighten up all ball cups this way.
Thanks.
The cradle will fit with a ROAR or EFRA legal battery. It should fit perfectly.
Rick Hohwart is offline   Reply With Quote
Old 01-28-2010, 10:48 AM   #11828
It fits the older 20c reedy 3200s well...
5p3ktrum is offline   Reply With Quote
Old 01-29-2010, 10:29 AM   #11829
gre
how are the experience with the exotek TC5X lipo chassis on tarmac?
gre is offline   Reply With Quote
Old 01-29-2010, 01:30 PM   #11830
Jorge G's Avatar
Thanks.
It fits perfect, but you still need to add weight on the outside to balance the car.
TC5R / Tekin RsPro / Epic Duo2
Team Magic G4RS / Novarossi 353 Race Engine
Airtronics M11 / Spektrum
Jorge G is offline   Reply With Quote
Old 01-29-2010, 02:02 PM   #11831
rc pete's Avatar
+1. I also mounted the lipo battery retainer about 1/4" to 1/2" further to the right (edge of my lipo lines up with the right edge of the chassis), instead of in the standard location. You have to drill and counter-sink a couple of holes, and elongate the tape slots on the chassis. Just be sure to round off any sharp edges and finish the carbon fiber work with the CA/Qtip method.
That allows you to balance the car left/right without very much added weight. I have about 50 grams on top of the battery retainer (right side of the battery) and I'm balanced at 1388g ready to run (standard bulkheads and all).
Moving the battery to the right also gives you more room to put a strip of weight along the center of the chassis, in order to make minimum weight.
I've seen a couple of guys move the battery even further right, but you might have to cut the battery tape slot a little too far over on the chassis, which is why I ended up where I did.
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 01-29-2010, 03:12 PM   #11832
Jorge G's Avatar
How do you drill the holes?? Can you post pictures?? Thanks!
Old 01-29-2010, 03:43 PM   #11833
Tag
Tag's Avatar
Trader Rating: 30 (100%+)
Default Droop / Downstop
i noticed on the AE setup sheets most racers run a really high droop value like 6 front 5 rear ) are these meant to be dropdown value ? misprint ?
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 01-29-2010, 03:49 PM   #11834
Andy63's Avatar
6mm front and 5mm rear is probalby basic. i have it on all of my cars.
www.andrefossto.wordpress.com
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |MIBOSPORT.COM |
Andy63 is offline   Reply With Quote
Old 01-29-2010, 04:24 PM   #11835
Tag
Tag's Avatar
6mm front and 5mm of what ? droop or downstop ? i can understand if you mean downstop value but for droop isnt a little too much ?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
