Old 01-21-2010, 02:54 PM   #11806
Redwood's Avatar
Originally Posted by revo61 View Post
Do run foam or rubber on wood?
Rubber spikes, if you take a look at the pics I posted above, you can see them. It's like an ice racing tyre, the grip is really low, any normal slick tyre is like a drift tyre on asphalt.
Regards
Neal
Redwood is offline   Reply With Quote
Old 01-23-2010, 05:45 PM   #11807
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
hello, where do you guys get the bulkhead that further move the motor inward for better balancing?
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Old 01-25-2010, 02:52 AM   #11808
if anyone wants any of the uprated rear bulkheads or any info on them they can contact me at.
greig76@hotmail.com
anembo-engineering@live.co.uk
thanks greig
leg iron is offline   Reply With Quote
Old 01-25-2010, 03:44 AM   #11809
defcone's Avatar
Trader Rating: 15 (100%+)
greig76@hotmail.com
thanks greig
What's updated on them?
defcone is offline   Reply With Quote
Old 01-25-2010, 05:16 AM   #11810
Trader Rating: 55 (100%+)
Leg Iron sent you an email.
Jamison R is offline   Reply With Quote
Old 01-25-2010, 06:23 AM   #11811
Just an update on my experience with Leg Iron's UK bulkheads. After I damaged the motor mount bulkhead in a horrific crash which also broke my bumper mount and top deck Greig contacted me and offered a free replacement that was superficially blemished that in his opinion was not good enough for sale. I got the replacement last week and in my opinion the blemish was not enough to not sell it as it's not visible when the bulkhead is mounted but Greig clearly has very high standards in his workmanship and stands behind his product. I raced with the bulkheads again yesterday on my very loose and dusty parking lot track which has a lot of hair pin turns. The UK bulkheads allow me to change direction a lot easier now as they've shaved about 85-90g off my overall weight since I no longer need to run a weight tray to balance the car and they use 3 less screws than stock. Before running this time I'd put my car back to almost the base asphalt rubber tire settings in the manual with the only difference that I run my rear diff as low as possible. The diff cams need adjusting to tighten the belts with the lowered layshafts. Currently I'm running a 13.5 with 87/24 48P gears and the car handles amazingly now. There are about 4 other TC5r's at my track and I'm able to keep ahead and pass them with ease. Once I can keep the power under control I can pass all the cars at the track with ease now The Tekin v203 combo helps with that but the handling of my car is significantly better than the other cars now and it's a lot lighter too. I had some crashes yesterday as is usual in TCs and the motor mount bulk head took it all ok, even after I got nudged off the track and snapped a front arm the bulkhead looks ok.
If you've been thinking about getting one of these bulkheads go for it. They work really well and Greig stands behind his product. He's really fast with getting them in the post as well.
spongerX is offline   Reply With Quote
Old 01-25-2010, 07:25 AM   #11812
hi
the bulkheads move the motor into the centre of the car by 5mm and lower the spur gear by 5mm. all in all helping the balance of the car.
thanks greig
Old 01-25-2010, 07:47 AM   #11813
Bryan Kendall's Avatar
Originally Posted by rced1 View Post
I just got a TC5 yesterday and have been going through it. Can someone tell me how to check if belt tension is correct? Or what is too loose?
Everybody is running them as loose as possible to reduce friction. Some are running aftermarket belts that make it even looser
Bryan Kendall is offline   Reply With Quote
Old 01-25-2010, 08:18 AM   #11814
rced1's Avatar
Trader Rating: 17 (100%+)
Thanks Bryan. I read elsewhere on this TC5 topic to run the belt as loose as possible without slipping. That is what prompted my "What is too loose?" question. Rc pete gave me a static method to check belt tension. I will fine tune when I get TC5 on the track.
Slow is fast.
rced1 is offline   Reply With Quote
Old 01-25-2010, 08:21 AM   #11815
Trader Rating: 23 (100%+)
Send a message via AIM to AxiomJacob
Whats the stock rear toe in without any toe washers on the tc5r?
Jacob
Proline Racing
AxiomJacob is offline   Reply With Quote
Old 01-25-2010, 08:38 AM   #11816
defcone's Avatar
If you're running 0 toe hubs, then 0 toe.
Old 01-25-2010, 10:19 AM   #11817
I'm running the stock rear hubs, whatever came with the kit.
Jacob
Proline Racing
Old 01-25-2010, 10:30 AM   #11818
defcone's Avatar
Yeah, 0 degrees of toe.
Old 01-26-2010, 05:11 PM   #11819
Tag
Tag's Avatar
Default Front Droop measurement
hey guys, when you guys measure front droop , you measure at the arm or at the hub carrier ? thanks
Old 01-26-2010, 05:19 PM   #11820
trerc's Avatar
Trader Rating: 89 (100%+)
Bottom of the arm.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
