Old 01-19-2010, 07:05 PM   #11776
ChadB.'s Avatar
Trader Rating: 21 (100%+)
This is good info Rick. I learned a lot just from that post.
ChadB. is offline   Reply With Quote
Old 01-19-2010, 07:24 PM   #11777
Trader Rating: 27 (100%+)
Ok so I have driven my car on carpet a few times now and I am wondering what the routine maintenance is on it. What should you do after every day of running?
C_Money is offline   Reply With Quote
Old 01-19-2010, 07:53 PM   #11778
trerc's Avatar
Trader Rating: 89 (100%+)
Not much, Check the shocks make sure there's no air in them (they will feel smooth if they are good and there will be no signs of obvious leaks). Obviously check to see if anything's bent broken or wore out, bearings especially. Take the universals apart and give them a good cleaning and lubing. Diffs if properly built will usually last a couple months worth of weekly club racing before needing tore down. Other than that keep it clean and visually inspect it, overall it's a pretty tough car that requires minimum care.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-19-2010, 11:08 PM   #11779
Also check the bearings.. When racing on carpet, some fluf gets in the bearing. The best way to get them out the without spending too much time:
1. Hold the bearing with a tool (F.e. the Much More Bearing Remover), or just put it around some pliers. By widening it you can make sure it doesn't fall off without damaging the bearing.
2. When there are parts of the fluf hanging out, just light them with a lighter. (When you can't see anything, but you think there is fluf in it. Spray some brake or motorcleaner over it and light it. )
3. After a few seconds the burning will stop, just let the bearings cool down.
4. Use some ball bearing oil or sewing machine oil to lubricate them again. And you're done.
When you want to take extra good care of them, after step 3 put the bearings in a ultrasonic cleaner. Fill the cleaning device with brakecleaner, put the bearings in them (you can also put the other metal parts like bulkheads in). When the ultrasonic cleaner is finished check if the bearings run freely. If not put them in again.
You'll probably be amazed about how dirty the brakecleaner will become inside the ultrasonic. When everything is cleaned, throw the brakecleaner out, clean the inside of the ultrasonic, put new brakecleaner. And give your bearings and metal parts an extra round in the ultrasonic cleaner. This is to make sure the dustparts coming in because of the dirty brakecleaner get out too.
After that lubricate them like I explained in step 4. And you're done.
Doing this a lot really lengthens the life expectancy of bearings. Racing 1,5 to 2 years with one set of bearings is nothing special. The only bearings I had to replace were broken bearings. Even when racing in the rain.
Rick Thomson is offline   Reply With Quote
Old 01-20-2010, 04:08 AM   #11780
trerc's Avatar
Note I said "especially bearings"
I'll go on a little further here to say go to Avid and buy some replacements, they're a $1 ea. Chances are if your bearings feel gritty they're beyond a good cleaning The bearings in the rear hubs and steering blocks take the most abuse. The bearings in the center line will usually last for a few cleanings. If your racing carpet only you will be fine to replace your bearings will full metal shielded bearings, these are much faster than full rubber shield bearings, Avid also make a Revolution bearing which is metal shield on one side and Rubber on the other. Anyway here's a link to Avid, great bearings, great service.
http://www.avidrc.com/
Old 01-20-2010, 08:31 AM   #11781
defcone's Avatar
Trader Rating: 15 (100%+)
Anyone know if bd5 spools will fit tc5?
defcone is offline   Reply With Quote
Old 01-20-2010, 08:37 AM   #11782
rced1's Avatar
Trader Rating: 17 (100%+)
Great post on bearing care guys. I would like to add a couple more points.
If using rubber shielded bearings use denatured alcohol instead of brake clean. Brake clean can swell seals and some other rubber.
Boca I think, did testing and found Mobil One to perform the best. Most any oil will work and have less resistance over grease of course.
Slow is fast.
rced1 is offline   Reply With Quote
Old 01-20-2010, 09:20 AM   #11783
Jorge G's Avatar
Smile If you dont have a ultrasonic bearing cleaner
If you dont have a ultrasonic bearing cleaner, you can place them inside a container and o top of a fish tank pump it will do the job
TC5R / Tekin RsPro / Epic Duo2
Team Magic G4RS / Novarossi 353 Race Engine
Airtronics M11 / Spektrum
Jorge G is offline   Reply With Quote
Old 01-20-2010, 03:36 PM   #11784
Don't know to be honest, but why should you??
When you don't like the TC5 spool, you'd better go for the spool of Titanium Racing. Their F1 Competition Super Spool is just amazing.
In fact it really is an improvement to the standard spool. Price is a little over 30 dollar (19,99 sterling), and it's very strong and improves the handling of the car.
For more info check the TR website.
Old 01-20-2010, 03:42 PM   #11785
Lol and when you don't have a ultrasonic cleaner or a fish tank, you'd better buy a ultrasonic bearing cleaner. Because the fish tank and the fish are more expensive and need more maintenance
People looking for a ultrasonic bearing cleaner, get info about it from your local optician. And ask if you can buy an ultrasonic cleaner they use for the glasses and lenses, this one is exactly the same as the ones you sometimes see at RC shops. But this one is better priced (normally)
Old 01-20-2010, 03:44 PM   #11786
Hebiki's Avatar
Trader Rating: 26 (100%+)
any word on the inline bulkheads... or just give up hope?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-20-2010, 03:45 PM   #11787
defcone's Avatar
I'm ordering a body from this website, and I saw the Roche spool for bd5, so since it doesnt add to shipping, i was thinking about it as well.
Old 01-20-2010, 05:40 PM   #11788
Trader Rating: 19 (100%+)
King Headz are making some and should be out soon.
zake540 is offline   Reply With Quote
Old 01-20-2010, 05:44 PM   #11789
Hebiki's Avatar
photos?
Hebiki Design Works
Old 01-20-2010, 05:56 PM   #11790
photos?
I'll try to get update this weekend. But check out their alum spur gear hub, very nice piece.
http://www.kingheads.com/index.php?c...2c0783ec53f60e
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
