Old 01-18-2010, 01:58 AM   #11746
Redwood's Avatar
Originally Posted by ChadB. View Post
http://www.rctech.net/forum/attachme...tein-setup.pdf
This is the set up I am using. I am using it to the "T", only with the gold springs up front because the front of the car was over rolling and making the car hard to drive.
When you mean adding droop, you mean by going from say 5 to 6? What are you guys using to measure your droop? I am using Hudy blocks with a Hudy droop gauge. Should I be using something else? And yes, I am using a slipper spool.
Im am not cetain but I would guess that the Hudy numbering is different to the Associated numbering. The factory guys normally state their droop as the number on the Associated gauge, and measure to the arm, not the C-hub.
So check which droop you are running by using the Associated gauge that comes with the kit, and you can later work out how to convert the Hudy numbers to the Associated numbers, if they are different at all.
regards
Neal
Redwood is offline   Reply With Quote
Old 01-18-2010, 03:22 AM   #11747
The HUDY numbering is equal to the Asso numbering.
Also remember when setting up your droop, first detach your anti roll bar and your shocks.
Rick Thomson is offline   Reply With Quote
Old 01-18-2010, 04:02 AM   #11748
Redwood's Avatar
Thanks for the clarification, my bad.
Regards
Neal
Old 01-18-2010, 04:27 AM   #11749
trerc's Avatar
Trader Rating: 89 (100%+)
When setting your down stops you detach your anti roll bar and shocks
When checking droop they should both be attached.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-18-2010, 09:02 AM   #11750
OI82lose's Avatar
Default Fixing on Throttle rear end looseness.
I have been running at WEST Coast RC raceway and my TC is loose out of the corners on throttle.
I am running a 17.5 motor and Tekin RS. Sorex 32 rubbers. Blue spring front, silver rear.
35 wt shock oil front, 30 rear.
I have tried about everything I know and can't seem it get the to hold on throttle, Played with the droop, no help. rebuilt shocks, no help. made front belt tighter, worse.
Check front slipper spool tight, rear diff set correctly (1/8 turn loose).
Not sure where to go from here, but frustration is setting in.....
OI82lose is offline   Reply With Quote
Old 01-18-2010, 09:04 AM   #11751
pakk's Avatar
Trader Rating: 79 (100%+)
is the rear diff smoooooothe?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 01-18-2010, 09:23 AM   #11752
OI82lose's Avatar
Yes rebuilt it about 2 runs ago.
Old 01-18-2010, 09:26 AM   #11753
Yup srry true
Old 01-18-2010, 01:54 PM   #11754
Trader Rating: 27 (100%+)
any companies make white ball cups for this car?
C_Money is offline   Reply With Quote
Old 01-18-2010, 01:55 PM   #11755
OI82lose's Avatar
Rpm maybe?
Old 01-18-2010, 01:59 PM   #11756
trerc's Avatar
Originally Posted by OI82lose View Post
Rpm maybe?
Yep
http://www.amainhobbies.com/product_...=Product-Feeds
Old 01-18-2010, 02:06 PM   #11757
trerc's Avatar
Old 01-18-2010, 02:09 PM   #11758
using those wont require shorter turnbuckles or anything?
Old 01-18-2010, 02:18 PM   #11759
i just finish building my tc5 i going to run 17.5 but i cant get the gearing right i am trying to get it at around 4.0 can someone help me out and tell me what spur and pion and pitch thank you
corally rdx ta01 thru ta05 m03 trf416 cyclone s tc3 yokomo sd
some offroad vehicles
a special thanks to dennis lyman and bitter and also grandpa for all the help
always looking for old tc's like old tc3 and tamiyas etc
service most generator rv and portables kipors briggs & stratton generac etc.
dongenserv is offline   Reply With Quote
Old 01-18-2010, 03:25 PM   #11760
trerc's Avatar
94/47 64p
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
