Old 01-12-2010, 09:40 AM   #11716
ABspeed's Avatar
I want to buy the new rear bulkheads that move the motor inboard. I searched a little and couldn't find a link to buy them, can someone steer me towards them please.
Associated, Reedy,
KO the Competition
ABspeed is offline   Reply With Quote
Old 01-12-2010, 10:40 AM   #11717
Contact Greig for the UK bulkheads that move the motor in 5mm. greig76 at hotmail dot com
Workmanship is fantastic and great customer service from him.
Bear in mind you will have to modify your top plate and chassis to get the motor to fit 5 mm closer. Top plate is easy to do but the chassis plate is a bit harder as you have to mill out a few layers of the graphite for the motor to sit low (similar to what is done by AE on the chassis already). A dremel and sanding drum take care of that tho.
spongerX is offline   Reply With Quote
Old 01-12-2010, 04:34 PM   #11718
Default Building my TC5R
[QUOTE=authorjim;6840361]Hello, everyone. I am about to build a TC5R kit. I don't want to go through the agony of building it and finding out later about some significant upgrades or build lessons. I would rather know them first. So please help.
Thanks again to all that have helped.
A few more questions. What are good light, powerful, quick servos for this car?
What about the Brushless setup, ESC and motor, any thoughts?
I have also heard that I need to do something to the composite chassis to finish the edges? What is it that I have to do?
Jim
If there is a thread you can refer me to that would also help.
authorjim is offline   Reply With Quote
Old 01-12-2010, 04:46 PM   #11719
trerc's Avatar
Trader Rating: 89 (100%+)
Jim
I would recommend the Futaba S9550 or S9551 low profile servo.
As far as sealing the chassis edges, round them with a file slightly and just give them a good sanding with some 400-600 grit paper. To seal them simply wet a Q-Tip with blue Loctite and go around the edges, only the lower chassis plate needs this prep work, shock towers and top plate will be fine as is. You can also use CA to seal the chassis but Loctite does the same thing and is much easier to use.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-12-2010, 08:11 PM   #11720
rcmarek's Avatar
Is Loctite« Threadlocker Blue what you mean by blue loctite or is it some other product from their huge range?
Marek | SMA | M03 | TC5R | F104
rcmarek is offline   Reply With Quote
Old 01-12-2010, 08:36 PM   #11721
Glowster21's Avatar
Trader Rating: 114 (100%+)
Pretty sure that's the one!
Glowster21 is offline   Reply With Quote
Old 01-12-2010, 09:01 PM   #11722
trerc's Avatar
Yep, Loctite 242 (BLUE) threadlock
Old 01-12-2010, 10:17 PM   #11723
chrisfrom619's Avatar
Send a message via Yahoo to chrisfrom619
When I installed my exotek chassis there is a note that states after sanding the edges you can use loctite to bring back the deep black color around the edges of the chassis CA glue CAN tweak the chassis.
#1 Sponsor: Wifey
Hpi baja, traxxas e-maxx,slash, AE TC5R, RC18R,SC10, Thunder Tiger EB4 S2, and Futaba 4pk
DHW Raceway San Diego CA.
Novice Class
chrisfrom619 is offline   Reply With Quote
Old 01-13-2010, 02:31 AM   #11724
For these kind of things it's always the same: A dozen people, a dozen opinions. Personally I recommend as a servo either a Sanwa servo (most international topdrivers use Sanwa servo's ) Or when you want to go for a servo that is not as expensive, go for the Sav÷x. It's got equal specs as the Sanwa and Futaba ones, but it's less than half the price.
For the speedo and motor it really depends on what you want to be racing. Since there are more and more speedo's specifically made for a type of racing.
Rick Thomson is offline   Reply With Quote
Old 01-13-2010, 01:09 PM   #11725
Trader Rating: 32 (100%+)
Default tc5 bulkhead
got my inline bulk heads today. fast shipping even from england..
sider662 is offline   Reply With Quote
Old 01-15-2010, 07:07 AM   #11726
Default Internal Ratio
Hi
Has anyone tried lowering the internal ratio of the car?. By my calculations, using a Cyclone TC (170T) front belt and a cyclone (62T) rear belt, as well as using hpi pro3 (36t) diff pulleys, you should lower the ratio. I'm just wondering if the pulleys would fit on the TC5 outdrives, or which 36T pulleys would without changing the balls?
Thanks Ya`All
MoonTrap is offline   Reply With Quote
Old 01-15-2010, 09:21 AM   #11727
Scottmisfits's Avatar
Personally, I use the Futaba 9550. When it dies, if it does, I will go to the newer 9551 or the new BLS551. They are all the low profile servo's.
As for motor and ESC, it's longer a motor war. I can take my first gen LRP motor and be competitive against the new motors with the proper settings on any of the newer ESC's. It's now a matter of figuring out the power band of the motor's and setting the ESC accordingly. It's no longer a motor war as it used to be with the brushed motors, it's now an ESC war. This is where the Tekin and similar ESC's will have the advantage. I have always liked my LRP ESC's but I don't feel they can keep up to the same level anymore. The new LRP SXX stock cpec's is sounding great, this week. But the programmable ESC's will have the edge because in a week, they will come out with even more stuff to help tweak and be even faster.
Scottmisfits is offline   Reply With Quote
Old 01-16-2010, 08:35 PM   #11728
blackdog's Avatar
Thumbs up In need of vta tc5 set asap ...
Hi All
Can anyone post a vta setup for a AE TC5 ,Im running 21.5/lipo or even a thread to one.track is med to large ,changes almost every week were I race and has med to high bit carpet.
Thanks in advance`
Matt
blackdog is offline   Reply With Quote
Old 01-16-2010, 09:11 PM   #11729
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
If anyone is looking to pick up a TC5R in very good condition, check out my for sale thread: TC5R w/ Exotek
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 01-17-2010, 12:00 PM   #11730
ChadB.'s Avatar
Trader Rating: 16 (100%+)
I was wondering if somebody could help me out. I am running 17.5 rubber on carpet with a Tekin Redline motor and an LRP SPX speedo. Now my question is, whenever I let off the gas going into the corner, my car gets really loose. But if I stay on the throttle a little it is not as bad. Is there any way I can tighten up the rear so it is not so loose? The drag brake has been turned all the off, shocks have been rebuilt and new hinge pins have been put in. I am using Josh Heinstien's set-up and it seems to be working pretty good. The only change I made to the set-up was putting gold springs up front, because the front of the car was over rolling to much. I new to carpet racing and any help would great.
Chad Burdick
ChadB. is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
