Old 01-11-2010, 09:56 AM   #11701
trerc's Avatar
Trader Rating: 89 (100%+)
Originally Posted by C.Andersson View Post
Chassis and topdeck are from Exotek racing. I have modified the front bulkheads, To get more flex to the front end. Shock towers are original only camholders (shocktower mounts) are changed to get new adjustment for the links.
The rear customized bulkheads (motor more towards the centerline) are only for because weightlimit is 1350g to get all electrics as close as possible to centerline and still get the car balanced.
I was racing in rebellion race - Indoor Ec warmup (weight limit was 1400) with original b-heads 'motor out'.. I like the original bulkheads more because they make the car more smooth..
I will be answering here if you have anything to ask about the car.
Awesome!! 1st congrats on your podium finish.
Thanks for clearing up a few of the things on the car, as far as the front driveshafts are concerned... are those the Xray ECS dirveshafts? If not what are they and where there any other modifications necessary to make them work?
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-11-2010, 11:45 AM   #11702
C.Andersson's Avatar
Thank you!
Yes, I am running Xray double universals front. That is just for less vibration and lilbit more steering when entering the corners.. Im using BD5 steerings hubs to fit them (fits straight to AE caster blocks), also you need to make some space for the ESC's to caster block because xray ones moves in vertical axle so they wont get in contact with caster block. For the spool you need Drill the outdrives first with 6mm drill and then with 7mm to fit the xray ones perfectly.
Keven Hebert uses Losi double universals front with losi parts, I think those are more easier to fit in than Xray.
But i dont see this very necessary. The car is more easy with Associated's own cvd's and sometimes even faster. Just remember to grease them.
Christer
C.Andersson is offline   Reply With Quote
Old 01-11-2010, 11:45 AM   #11703
BigP's Avatar
Hello Christer
Congratulations, great job
The bulkheads are the UK-Version?
Are the Bearing Cup front and rear of the bulkheads self-made or from UK or Associated Prototyps?
Shock oil and pistons used?
Which arm mounts?
Or better a setup sheet...
Thank's. Philippe
BigP is offline   Reply With Quote
Old 01-11-2010, 12:50 PM   #11704
Originally Posted by BigP View Post
Hello Christer
Which arm mounts?
Thank's. Philippe
Thank you!
Bulks are UK made, and Cam holders are made in Finland.
You can see the setup from pdf. (:
gigasize.com/get.php?d=o8h8lxy5k3b <--- I think this works better
rapidshare.com/files/333823481/Christer_DHI_2010_setup.pdf.html?
Christer
Old 01-11-2010, 01:42 PM   #11705
defcone's Avatar
Trader Rating: 15 (100%+)
Can we order the cam holders out of finland?
defcone is offline   Reply With Quote
Old 01-11-2010, 01:53 PM   #11706
Thank you!
Hi!
you got pm!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 01-11-2010, 02:02 PM   #11707
Default C.Andersson setup
Should be easy to download
m.
Michal Abramowicz
Old 01-11-2010, 03:20 PM   #11708
MikeR's Avatar
Hi Christer,
Again, congrats on the nice results and the new contract with Associated. You have a great future and I'm looking forward to working with you further!
Best Always,
Mike
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 01-11-2010, 03:30 PM   #11709
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by MikeR View Post
Hi Christer,
Best Always,
Mike
Mike, i think its time to design some new top bulkheads for the TC5
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 01-11-2010, 08:13 PM   #11710
Default TC5R kit New at this please help.
Hello, everyone. I am about to build a TC5R kit. I don't want to go through the agony of building it and finding out later about some significant upgrades or build lessons. I would rather know them first. So please help.
If there is a thread you can refer me to that would also help.
Jim
authorjim is offline   Reply With Quote
Old 01-11-2010, 11:45 PM   #11711
Hebiki's Avatar
Jim
use the diff nut from the B4/T4 for your diff and spool.
Hebiki Design Works
Old 01-12-2010, 04:39 AM   #11712
You can also swap the belts and mount the esc closer to the center.
____________________
www.RCActionPics.com
Rojna is offline   Reply With Quote
Old 01-12-2010, 06:53 AM   #11713
chrisfrom619's Avatar
Send a message via Yahoo to chrisfrom619
Jim
If you are going to use lipo battery Exotek Chassis is the way to go. Best upgrade I have ever done in my TC5 and I would not go back to stock chassis not unless I need to use NIMH battery.
#1 Sponsor: Wifey
Hpi baja, traxxas e-maxx,slash, AE TC5R, RC18R,SC10, Thunder Tiger EB4 S2, and Futaba 4pk
DHW Raceway San Diego CA.
Novice Class
chrisfrom619 is offline   Reply With Quote
Old 01-12-2010, 06:59 AM   #11714
Default Building a TC5R kit
Jim
thanks to all the suggestions so far. I will search for the Exotek chassis and the B4 nuts for the diff. I am not sure what is meant by swapping the belts. Swapping them how?
Anything else I should be careful about or change?
jim
Old 01-12-2010, 07:06 AM   #11715
Redwood's Avatar
jim
Be care ful when building the shocks, do not trim the black retainer, even though it does not appear to fit. Use the shock tool to push it into the shock body and it will go eventually. If you trim them, your shocks will leak. Happened to me, since I replaced the black retainers the shocks have been perfect.
Flipping the belts means to change the order of the belts so that the belt going to the rear is on the spur side, and the front belt is on the battery side. It lets you sit your electronics closer to the centre line but can be problematic unless you get a good lipo retainer.
regards
Neal
Redwood is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
