Team Associated TC5
Hey all, just picked up a used FT TC5 for my son and am looking at the Exotek Lipo Chassis conversion with the extra flex top deck. We're running rubber tire carpet and I've been out of the Touring game for a while. I did some digging in the thread regarding the Exotek chassis, is it worth it?
set-ups
thks rick for posting your set-ups on the AE website . i noticed that chris Jarosz,s wasn't listed though
For the UK bulkheads, you will not have to drill any new holes anywhere.The motor mount section floats above the chassis so the only holes used to mount the whole thing are the same holes that mount the stock bulkhead. The only thing you will have to do is enlarge the opening for the motor so that it can mount to the new motor mount position. I suggest opening the hole completely rather than grinding the thickness of the chassis down as is done by the factory on the outside edge.
Why do you enlarge the opening rather than grinding the thickness when using the inline bulkheads?, wont opening the motor hole leave very little meat between the motor opening and that pinion slot?
I guess you could do it either way but I think grinding the thickness evenly would be difficult. There is very little meat meat between the motor hole and pinion slot but this does not matter.
hey guys i got the exotek chassis for xmas and the instructions say to not use ca glue on the edges of the chassis so should i use ca or just not prep it at all the instruction say to use blue loctite instead of ca glue
I take a Dremel and a sanding drum and clean the edges up a bit and use blue loctite to seal it up with. Blue loctite does the same thing and is more forgiving than CA. I just soak a Q-Tip and apply loctite to the prepped edge and let it dry overnight, works great.
Santa brought the inline motor mount?
Did Santa bring us pictures yet of the inline motor mount?
I have a nice TC5R for sale with inline motor mounts and Exotek chassis if anyone is interested.
http://www.rctech.net/forum/r-c-item...k-chassis.html
I'll be going back to my standard bulk heads and PPD billet battery weight tray now
