Old 12-18-2009, 10:34 AM   #11596
Rick Hohwart's Avatar
Originally Posted by M.Abramowicz View Post
Thank you Rick for replay.
About Herbert modification, I think this is this part:
http://www.hbeurope.com/piw.php?partNo=67699&lang=en
If I remember from my old cyclone-S, for front bearing was about 5x10,
so we need this bearing: 5x10 x3mm
Hm, I think, AE should do some mods for tc5 as "new option kit" and/or release
new chassis Shorter way -> new option kit
Regards and again thanks for help!
M.
These are the ones he uses. You can also use X-Ray type.
With the Losi shafts, you can use TC3 bearings but you must use the Losi steering blocks. With the HB or Xray parts, you will still need the Sperpent bearing to make everything fit. The HB or Xray bearings will not fit in the AE steering blocks.
I'll see if I can find the correct bearing size. It is an unusual size and not very easy to find.
Rick Hohwart is offline   Reply With Quote
Old 12-18-2009, 10:37 AM   #11597
pakk's Avatar
Trader Rating: 79 (100%+)
at what point are you guys finding that you need/should do these upgrades to the steering throw?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 12-18-2009, 02:13 PM   #11598
tom_chang79's Avatar
Originally Posted by Rick Hohwart View Post
Here are the pics of my KO cars.
Rick, is this the car you ran at WCRC for the KO race?
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 12-18-2009, 02:29 PM   #11599
If you use the stock driveshafts and steering parts, you may encounter binding at full steering thorw. You can test this by setting the car with the wheels off the ground and giving the car a little bit of continuous throttle. While the drivetrain is moving, turn the wheels all the way in each direction to determine if the driveshafts are binding. They most likely are.
I always limit the steering throw using a 1deg shim. This limits steering throw to about 80% which is more than enough for 13.5 and 17.5. If your driveshafts are binding, any more throw than this will not give you more steering.
if you are changing bearings or the driveshafts anyway, it is a good time to upgrade. Otherwise, shim the steering.
yes
Old 12-18-2009, 02:35 PM   #11600
Hebiki's Avatar
Trader Rating: 26 (100%+)
where do you put the shim?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-18-2009, 02:55 PM   #11601
Korey Harbke's Avatar
Probably on the steering knuckle, where the arm touches the C hub under full lock.
-Korey
Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 12-18-2009, 02:58 PM   #11602
You glue it to the back side of the steering block so that when the wheels are turned the shim hits the caster block.
Old 12-18-2009, 03:21 PM   #11603
Hey Rick,
What should i gear my TC5RF for a 10.5 X-12?
Avarage size carpet track.
Dale
Dale.0 is offline   Reply With Quote
Old 12-18-2009, 03:24 PM   #11604
Hebiki's Avatar
-Korey
sweeet... thanks
Hebiki Design Works
Old 12-18-2009, 06:30 PM   #11605
xtrememadness's Avatar
Send a message via AIM to xtrememadness
i smell a tc6 coming soon
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 12-18-2009, 06:46 PM   #11606
trerc's Avatar
Trader Rating: 89 (100%+)
Nah, not Associated style, the car still does pretty well. They will keep it around and just let other companies produce the aftermarket parts to fix it's faults.
trerc is offline   Reply With Quote
Old 12-18-2009, 06:50 PM   #11607
5X10X3 ,Try any general Hobby store that also stock E SKY Heli parts.
Number 000371 ,way cheaper than the Serpent bearings and readily available. 4 per packet.If you have no luck i have also got some from BOCA
With the HB shafts you will also need another wheel hex and pin.HB or XRAY will do the trick,and slightly open the the caster block(dremel) and the bone blade(re drill as the pin in the HB shaft is larger)
HPI - HB - KYOSHO - TEAM DURANGO - LRP - GENSACE - JCONCEPTS - ABSIMA - ALPHA - HOBBIES AUSTRALIA
DAZC is offline   Reply With Quote
Old 12-18-2009, 08:03 PM   #11608
pakk's Avatar
yes
good info.
So my next question is, why not just limit the steering throw with your radio?
*Photon* *SC10 4x4*
RCRD
Old 12-19-2009, 01:14 AM   #11609
bfong13's Avatar
Trader Rating: 17 (100%+)
good info.
Probably because if you just limit the steering throw with your radio, any bumps the car encounters could still force the steering block farther into throw. With the shim glued to the steering block, there is something solid in place to limit the actual physical throw.
bfong13 is offline   Reply With Quote
Old 12-19-2009, 08:22 AM   #11610
Thumbs up
Hi!
Hm, I wonder how much are you using D/R on TX.
In my case, I set EPA L/R for max, I mean, block touch c-hub, and
values on setup station is about 26deg (if I remember, +/- 1 deg),
then at track start driving, and I found that for me, D/R is about 61 on my 3PK. With 60, it turn not enough, with 62 too much and oversteer,
start driving nervous ...
Maybe I should play with bigger D/R and try turn into corner harder and
0.5m latter then with 61 ?
I'm ready for story
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
