Old 12-14-2009, 02:49 PM   #11551
CL
CL's Avatar
Trader Rating: 32 (100%+)
I think that when the lipo retainer is too wide, it will hit the ground when the car leans taking away traction.
Originally Posted by M.Abramowicz View Post
Yes, I have this one, is very OK, when I drill new holes for my LIFE pack 4600
but is BAD for my LIPOZ. I must put about 50-60g on accu side, and
my weight go over 1400g when my limit is 1350g.
Regards!
m.
Believe in yourself!
CL is offline   Reply With Quote
Old 12-14-2009, 03:07 PM   #11552
i1justin's Avatar
Trader Rating: 20 (100%+)
thanks guys, braking is minimal not enough room to get up any real speed I Like the one-way feel just wondered if I was putting myself at a disadvantage, may have to throw a spool in there to see how lap times compare, just wanted to see if it was even worth it, sounds like it might be but not tight enough for a diff
Justin Wilde
AE - Reedy - JConcepts - Airtronics
Irony- Racing Nitro requires more Batteries than Racing Electric.
www.NCTracing.com
i1justin is offline   Reply With Quote
Old 12-14-2009, 05:03 PM   #11553
Kevin Boyle's Avatar
Originally Posted by leg iron View Post
just to let people know im down to the last few sets of uprated bulkheads. so if anyone wants some just drop me an email to the address below.
iv sold loads of sets from this batch with great feedback. its great to hear the positive comments and nearly all the team drivers are using them now.
greig76@hotmail.com
thanks greig
You have mail Sir
TTYL
Kevin Boyle
JConcepts-Team Associated
Winning Edge Designs/wedjim.com
RC10B4.2-BJ4W.E.
Kevin Boyle is offline   Reply With Quote
Old 12-14-2009, 11:50 PM   #11554
Thumbs up
Good!
My try is moved up for 2.5mm and is tight should be fine, but 1st race is
in January 2010 ... if my Wife let me go
With moved outside asso tray for abiout 8mm, I don't saw that lipo tray bind
to ground.
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 12-15-2009, 03:27 PM   #11555
Jsaves's Avatar
I noticed the racing at KO in cali on red rc.
Did anyone get pics of the TC5s of Kevin, Rick and Josh?
Any new bits and pieces?
Inquiring minds want to know
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 12-15-2009, 03:49 PM   #11556
trerc's Avatar
Trader Rating: 89 (100%+)
Yea, anymore on the elusive new motor mount/bulkhead design???
trerc is offline   Reply With Quote
Old 12-15-2009, 04:48 PM   #11557
hi,im new with electric i need a FDR for my tc5 with 17.5t trinity pulse,lrp sphere tc and 5000mah intellect lipo and 8 to 10 minutes of race,any suggestion.thanks apreciated
Schumasher CAT K1 AERO/HobbyWing V3.1 ESC/HobbyWing V10 6.5T Motor/IP Batteries
WWW.SPEEDLINEHOBBY.COM "A HOBBY STORE FOR RC RACERS"
IVAN RM is offline   Reply With Quote
Old 12-15-2009, 05:19 PM   #11558
trerc's Avatar
Safe to start around 5.0 and check your temps and adjust from there.
Old 12-15-2009, 06:11 PM   #11559
I personally would start 4.0 when I ran a LRP TC Spec Sphere I was at 3.5 for 5min races and never had a problem with temp. But then again it does depend on what track you're using.
I recommand talking to other people at you're local running 17.5 as they should give a better idea where to start.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 12-16-2009, 04:39 AM   #11560
Jamesalex's Avatar
On hotbodies usa I found these, not very close but does look like new parts
Team Associated TC5-dsc04059.jpg   Team Associated TC5-dsc04061.jpg   Team Associated TC5-dsc04062.jpg
Jamesalex is offline   Reply With Quote
Old 12-16-2009, 06:08 AM   #11561
Suspended
The parts are not new at all!!
Those are the bulkheads from Greig in England!
Bobby Ball is offline   Reply With Quote
Old 12-16-2009, 07:36 AM   #11562
trerc's Avatar
Yes they are.
Old 12-16-2009, 08:28 AM   #11563
Rick Hohwart's Avatar
Yes they are.
Yes these are the bulkheads from Greig. Keven and I ran them on our modified cars.
Rick Hohwart is offline   Reply With Quote
Old 12-16-2009, 09:05 AM   #11564
Rick, can you feel a difference with the new bulkheads? If so, what?
Thx
DOTMAN is offline   Reply With Quote
Old 12-16-2009, 10:42 AM   #11565
Thx
Well, I have been running a modified factory motor mount/bulkhead that moves the motor in and removed the front leg of the motor mount so changing to the UK bulkheads was not as big a difference to me as it would be to someone with stock parts.
I could not tell a difference lowering the layshaft but I think visually the cars look better this way and in theory the lower CG (even if small difference) should be better. The only problem I encountered was the fact that when you run the front diff at full low (which I do) the belt if very close to hitting the chassis. In fact I can see that it did hit the chassis at time but I think this was not something that would happen under normal circumstances.
But I would recommend enlarging the opening at the front of the car and/or bevel the chassis slightly so that the belt has more space. If you never run the diffs full low, it is unnecessary. i think the bulkheads are a good hop-up. Plus once I contacted Greig and made the purchase and had the parts within a few days.
With the AE LiPo retainer I am easily able to balance the car left to right and be under the 1425g minimum.
The other new thing I was using which is not such a bid deal is aluminum screws from the 12r%.1 screw kit. I used these on the top deck, bearing caps, and shock tower mounts. These scews will be avaialble seperately shortly. I also used one other new item that I can't mention but they will be released in the next week or so although this part does not really make a highe difference in performance. It is more of a durability/bling part.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
