Old 12-03-2009, 04:24 PM   #11476
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by DAZC View Post
Guys,i have one of Pauls pre production motor centralizing mounts,no need for redrilling of the chassis,just some minor dremaling needed on the top plate.
Existing AE bulkheads are retained!
Its a really simple and effective solution to making the motor mount inline,and does improve the cars performance.
When you actually see it you will wonder why someone has not come up with this system earlier.
Watch this space as i am sure Paul (aka Pablo Diablo)with have more info to follow.
pictures man! pictures!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-03-2009, 04:37 PM   #11477
trerc's Avatar
Trader Rating: 89 (100%+)
Well I'm excited!
trerc is offline   Reply With Quote
Old 12-03-2009, 07:46 PM   #11478
Suspended
How do these compare to the after market bulkheads which are sold by a guy on here?, as i know the material used on the standard bulkheads is not exactly the strongest stuff lol.
PickenStir is offline   Reply With Quote
Old 12-03-2009, 09:43 PM   #11479
Pablo Diablo's Avatar
Send a message via Skype™ to Pablo Diablo
I will post pics as soon as production is done. Don't want to give away too much
Main difference is my design is just a motor mount. The advantage will be a much lower cost and ease of removing the layshaft. Motor will be moved 5mm closer to center, in-line with the bulkhead.
Paul H
Losi Type R | Xray T3 | CRC Gen XL | CRC Gen X 10 ME(Messiah Edition) | Black Diamond
www.FlyingFoxRC.com | Advanced Electronics | Team CRC | Factory Messiah
Pablo Diablo is offline   Reply With Quote
Old 12-03-2009, 11:42 PM   #11480
Thumbs up
Hi Pablo!
Can you ship it to Poland, Europe when you done ?
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 12-04-2009, 01:38 AM   #11481
Hebiki's Avatar
Pablo - i call dibs on the first one! i sent you a PM. let me know.
Hebiki Design Works
Old 12-05-2009, 09:24 AM   #11482
What is the reason for moving the motor in 5mm?
RoyU is offline   Reply With Quote
Old 12-05-2009, 09:29 AM   #11483
Trader Rating: 38 (100%+)
better / easier balance left to right.
or8ital is offline   Reply With Quote
Old 12-05-2009, 10:06 AM   #11484
hi all
i know what this modification is as iv done some for the team drivers in the uk and it isnt much good. you still have the problem of the bulkheads bending with a hard impact and unlike my bulkheads the spur gear is still to far up in the air and they need to be the 5mm lower which helps the centre of gravity. ask any of the team drivers who are using my bulkheads.
regards greig
anembo-engineering@live.co.uk
leg iron is offline   Reply With Quote
Old 12-05-2009, 10:10 AM   #11485
Originally Posted by leg iron View Post
hi all
regards greig
bashing on other items is no way of advertising your own product
rcspeed.usa is offline   Reply With Quote
Old 12-05-2009, 10:18 AM   #11486
im not bashing any other product! far from it, im just saying it how it is. this is a cheap solution but it wont fully cure the problem. i dont want to get into arguements on here thats why i dont bother coming on here very often. i supply a nearly all of the team drivers and alot other people worldwide so i know the bulkheads i supply work. fact!!
Old 12-05-2009, 03:25 PM   #11487
hi all
regards greig
Hi Greig, with Pablo's design we are finding that because the motor mount is not connected in any way to the current bulkheads there is no chance of the std bulkheads now bending because of a hit on the motor.Of course there is still the option of adding the inexpensive lowered Exoteck bearing holders to lower the CG,My personal opinion and testing is the layshaft is better left in its std position now with the reduced lipo weight limits around the world.
The current trend is to flip the belts on the TC5 and run your electronics and lipo as much down the centre line as possible,with leaving the layshaft at its std position it allows you to mount the cells way closer to the centre line without fouling on the 20t pulleys.
If anyone is running the Exoteck chassis with the option bearing blocks or Greigs lowered design would have found the most inward battery mount position is not possible to use for this reason.
Once again my testing tells me there is more advantage in running everything as central as possible than lowering the layshaft, i am sure Greig would agree some what here as the whole idea of his bulkhead is to also mount the motor more on the centre line, if this was not the case he would have only lowered the layshaft and left the motor in its existing position?
The moral here guys is both Pablo's and Greigs products improve you current TC5,I am sure neither of these guys is putting in an order for a new Ferrari because of the expected sales of there products,so go with which ever one you like best and fits your budget,i am sure you will be happy with the performance either way!
HPI - HB - KYOSHO - TEAM DURANGO - LRP - GENSACE - JCONCEPTS - ABSIMA - ALPHA - HOBBIES AUSTRALIA
DAZC is offline   Reply With Quote
Old 12-05-2009, 10:21 PM   #11488
I'm sure both upgrades are quite viable to improving the TC5. One problem that I'll have with the full bulkhead and motor mount is that I don't have the tools and know how to modify the chassis plate that creates a problem for me if I were to get them.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 12-06-2009, 01:19 AM   #11489
Dazc post is one of the most sensible iv seen on here in a wile! what he says is exactly true, it really does sound like pablo has put some thought into the modification of the original bulkheads and it will be great to see what he comes up with. im glad that some people see that we are looking to improve the car and not put it down. its exactly true that i wont be ordering a ferrari.lol. to manufacture these bulkheads is a lot of time and effort which i do more for helping the team drivers etc than a money spinner as im sure people will agree if you can imagine how long it takes to drill and tap the 13x 3mm holes in each set!! as im not associated and not got there set up. but im all for pablos idea if its an option for a different budget as everone doesnt want to spend the same and i think this is another option that will be great.
really look forward to this mod when it gets posted as its great to see new ideas.
ps daz i would agree with you about the motor being moved more towards the front of the car if thats what you were saying?
greig
greig
Old 12-06-2009, 06:21 AM   #11490
ghostman24's Avatar
Trader Rating: 25 (100%+)
I think that it is ridiculous for someone else to have to make improvements on a manufacturers car. Don't get me wrong I think it is great that someone spends the time to thinks of improvement. I just don't understand why AE doesn't make improvements to there own product. Some other manufacturers do. I just wanted to throw this out ther. It has been on my mind for awhile now. I am not saying anything bad to anyone or about anyone. I am just stating a fact. Just my .02 cents.
ghostman24 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
