Old 12-02-2009, 06:37 PM   #11461
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
Here are a couple of sedan bodies just finished up for you guys to check out. A little different flavor from the usual!
...Jim
W.E.D.
Get Faster Gear
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 12-02-2009, 07:08 PM   #11462
revo61's Avatar
Trader Rating: 18 (95%+)
Try 4.5 fdr.
Originally Posted by ChadB. View Post
Does anybody have a good 17.5 rubber set-up out there. I am currently using Kevin Hebert's set-up with 45wt. oil in the front and 35wt. oil in the back. The seems pretty good to me, but I am getting eaten up out there.lol. Also I am struggling with a good gear ratio. I currently have 104 spur and a 34 pinion. The motor I have is Tekin 17.5 and a LRP SPX speedo. The track has a 75 ft. straightaway and not to technical infield. Any help would be great. I am kind of new to electric TC.
Chad Burdick
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 12-02-2009, 07:37 PM   #11463
geeunit1014's Avatar
Chad Burdick
Profile 8, 10* on motor, 5.8 FDR, and go from there.
Originally Posted by Hebiki View Post
honestly... i dont think im good enough to see if i went 0.1 faster or not.... Keven Hebert apparently will have one for the Ko Propo Grand Prix (which will be held at the same track I race at) and Christer Andersen (sp?) won with it (on carpet) in europe where he beat Rheinard. so thats your proof right there.
i did feel i was more consistent with it. but that could be the product of Sean's set up as well as the chassis. who knows?
Left to Right balance was easier to achieve..... the battery holders are awesome since they're weighted too. . overall id recommend the chassis without hesitation.
Keven had one for his mod car @ champs. I asked him how he liked it, and he said there's not too much of a performance difference, a little easier to drive. I ran one in 13.5 as well there, I definitely had good pace, I was just struggling with not over-driving the car, and people taking you out
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 12-02-2009, 09:42 PM   #11464
ChadB.'s Avatar
Trader Rating: 21 (100%+)
So do you guys think the set-up on my car is fine? As for the motor goes, I had the timing cranked all the way up to 20 degrees and profile 8 on the speedo. I started the night with a 5.1 FDR and it ran pretty hot. I ended the night with a 6.1 and it was pretty cool.
ChadB. is offline   Reply With Quote
Old 12-03-2009, 03:33 AM   #11465
Redwood's Avatar
Gearing was simple a year ago, now it is a dark art. The best people can give you is starting FDR and some general advice.
4.5 FDR with 17.5 motor is normally a good starting point, but with the SPX and other 'dynamic timing' speedos, that won't work, maybe 6 is a better start point.
The hard truth is, you have to start conservative and experiment. You may need to turn the motor timing down, if I understand correctly (unlikely, so complicated) then low motor timing gives you the torque for the infield and the additional timing (turbo) the speedo adds on will give you the top end. This is how I think the team wave and Tekin speedos do it, but the SPX may be different. If you have to gear an SPX at 6, and a team wave at 3.7 then they are certainly different, and only experimentation with your car and your motor and your track will tell you what is best.
Gearing used to be so easy!
Regards
Neal
Redwood is offline   Reply With Quote
Old 12-03-2009, 03:34 AM   #11466
Redwood's Avatar
On another note, can anyone recommend me some carbide diff balls for the TC5. I just want some that will not wear for a few years.
Cheers
Neal
Old 12-03-2009, 08:57 AM   #11467
Hebiki's Avatar
Trader Rating: 26 (100%+)
Cheers
Neal
also.. when you find a prebuilt thrust bearing.. let me know too.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 12-03-2009, 10:00 AM   #11468
Trader Rating: 38 (100%+)
Top Racing USA has ceramic prebuilt thrust bearings that fit but you need Tamiya 415 diff nut and screw. They sell ceramic diff balls too.
or8ital is offline   Reply With Quote
Old 12-03-2009, 01:37 PM   #11469
trerc's Avatar
Trader Rating: 89 (100%+)
Tamiya makes a pre built thrust bearing too. Losi makes 3/32 carbide diff balls although carbide aren't really worth the money. If you wanna spend $ on harder diff balls go with ceramic tho there's nothing wrong with standard balls as long as you break the diff in slowly so you don't flat spot the standard balls.
trerc is offline   Reply With Quote
Old 12-03-2009, 01:49 PM   #11470
hey ive been searching throw many pages on here. does anyone know who makes the inline motor mount?
TEAM GENESIS R/C, Roche P12 2017, Roche F-1, PAINT BY MIKEY
onroad dude is offline   Reply With Quote
Old 12-03-2009, 02:03 PM   #11471
trerc's Avatar
PM sent
Old 12-03-2009, 02:04 PM   #11472
Fabricio's Avatar
Send a message via MSN to Fabricio Send a message via Skype™ to Fabricio
the e-mail of the guy that make the bulkheads [email protected]
ARC R10 - ORCA - SANWA - EPIC
Fabricio is offline   Reply With Quote
Old 12-03-2009, 02:52 PM   #11473
Originally Posted by Pablo Diablo View Post
I have been testing a prototype part for the TC5 which is due for release in about a week. Maybe someone knows about this or maybe the are 2 new parts comming out for the TC5.
Guys,i have one of Pauls pre production motor centralizing mounts,no need for redrilling of the chassis,just some minor dremaling needed on the top plate.
Existing AE bulkheads are retained!
Its a really simple and effective solution to making the motor mount inline,and does improve the cars performance.
When you actually see it you will wonder why someone has not come up with this system earlier.
Watch this space as i am sure Paul (aka Pablo Diablo)with have more info to follow.
HPI - HB - KYOSHO - TEAM DURANGO - LRP - GENSACE - JCONCEPTS - ABSIMA - ALPHA - HOBBIES AUSTRALIA
DAZC is offline   Reply With Quote
Old 12-03-2009, 04:14 PM   #11474
Hebiki's Avatar
Default thrust bearing....
so i have a ton of tamiya thrust bearings (which i didnt know you could use in the TC5R). what do i have to change.. just the screw and diff nut to use the tamiya thrust bearing?
Hebiki Design Works
Old 12-03-2009, 04:17 PM   #11475
yep
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
