Old 11-16-2009, 08:44 AM   #11371
XXX8ight's Avatar
Trader Rating: 47 (98%+)
i am new to onroad.... is $225 a good deal on a TC5 ran 3 times. It is set up for rubber tire but it comes with all the foam tire stuff including the chassis.
Tekno, Proline, and REX Novarossi Team Driver
XXX8ight is offline   Reply With Quote
Old 11-16-2009, 10:31 AM   #11372
CL
CL's Avatar
Trader Rating: 32 (100%+)
Default Changing arm mounts
When you guys change the lower arm mounts on the TC5, do you take the bulkhead apart or do you just unscrew the mount with the bulkhead attach to the chassis?
Believe in yourself!
CL is offline   Reply With Quote
Old 11-16-2009, 10:33 AM   #11373
Trader Rating: 38 (100%+)
With it attached to the chassis but I replaced all the screws with cap head screws so that is a lot easier with a ball driver.
or8ital is offline   Reply With Quote
Old 11-16-2009, 10:49 AM   #11374
Rick Hohwart's Avatar
Originally Posted by MoonTrap View Post
Are people swapping out the belts to so called "low friction" variants?. I saw on Keven Hebert's TC5 from the IIC that he ran normal TC5 belts. Are "low friction" belts necassary, or people even cutting the teeth on the belts?
Like Keven said, the stock belts last a long time and are very free. I don't think there is any reason to change them.
Originally Posted by performance26 View Post
what bodies do you guys run on your tc5. i have one been running mazda speed 6 i was wondering if the new bodies that have came out are better than the mazda. i havent ran in a year and trying to get back into it for next year.
I prefer the LTC-R. It think it gove more steering but at the same time it feels easier to drive.
Originally Posted by Xchange View Post
Hi guys,
I m new with the TC5, and i have many trouble with the shock!
I have a lot of air on the cap and the shock have a full rebound set.
Keven tell me to drill de cap to remove air but now my cap loose oil.
Any one tryed tamyia shock on the TC5 ?
If yes, what is our result?
If you are losing oil it is because the bladder is not sealing. If you drill a hole in the cap, use no rebound foam, and HB shock bladders, the TC5 shock will work as well and any other shock. You don't need to spend a lot of mony on Tamiya shocks when you can spend a little to upgrade the stock shocks.
Rick Hohwart is offline   Reply With Quote
Old 11-16-2009, 10:50 AM   #11375
Maybell's Avatar
Just loosten the screws with a 2mm ball driver.
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 11-16-2009, 10:50 AM   #11376
scootr117's Avatar
Hex Driver would work too.....I think OR8ITAL is thinking with the other brain again...
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 11-16-2009, 10:56 AM   #11377
CL
CL's Avatar
Thanks guys!
Old 11-16-2009, 10:57 AM   #11378
No, ball driver like these:
http://edsracingproducts.com/categor...ers-Metric.htm
Easier to get to the screw at an angle
Old 11-16-2009, 11:02 AM   #11379
CL
CL's Avatar
Yeah, I have them. Thanks!
Old 11-16-2009, 11:29 AM   #11380
Thumbs up
If you have ball 2.5mm driver, you should change screws for 2.5mm hex
Then should be MORE easy ;-)
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 11-16-2009, 05:04 PM   #11381
mr crum's Avatar
Send a message via Yahoo to mr crum
hey guys in the market for a new lipo charger what are your suggestions
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 11-16-2009, 05:56 PM   #11382
Trader Rating: 26 (100%+)
Send a message via AIM to kriiiss
does associated make an aluminum bellcrank for the tc5?
kriiiss is offline   Reply With Quote
Old 11-16-2009, 06:25 PM   #11383
xtrememadness's Avatar
Send a message via AIM to xtrememadness
pulsar 3
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 11-16-2009, 06:34 PM   #11384
Scottmisfits's Avatar
Not cheap but I think the Hyperion line of chargers are right at the top of the game. With the right charger, they have the update available to let it charge the Hyperion LiPo batteries at a 5c rating. 5000mah pack charge rate of 25 amps? Oh yeah!!!
Scottmisfits is offline   Reply With Quote
Old 11-16-2009, 07:34 PM   #11385
That's insane. How would you need to charge at 5c??
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
