Old 11-13-2009, 06:51 AM   #11356
Scottmisfits's Avatar
It would actually be a smaller spur and pinion.
What gearing are you trying to run? I have gone to a 100/46 with no issue.
Scottmisfits is offline   Reply With Quote
Old 11-13-2009, 08:12 AM   #11357
Xchange's Avatar
Trader Rating: 10 (92%+)
Hi guys,
I m new with the TC5, and i have many trouble with the shock!
I have a lot of air on the cap and the shock have a full rebound set.
Keven tell me to drill de cap to remove air but now my cap loose oil.
Any one tryed tamyia shock on the TC5 ?
If yes, what is our result?
Xchange is offline   Reply With Quote
Old 11-14-2009, 02:47 AM   #11358
John_S's Avatar
i ran tamiya shocks on my car for a few months but went back to the ae shocks as they feel alot nicer when on the car in my opinoin
John_S is offline   Reply With Quote
Old 11-14-2009, 07:17 AM   #11359
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
Originally Posted by Xchange View Post
Hi guys,
i just drilled my shocks cap.and tried to build one shock and it did not leak.... althought i did not build all the shocks since im using trf shocks... im just wondering if i have to remove all blue foams from the cap or just the big one? and leave the small blue foam on the cap..
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 11-14-2009, 08:11 AM   #11360
Redwood's Avatar
My bad, I run 48p so not sure how big a 96T spur, 64 pitch was.
Regards
Neal
Redwood is offline   Reply With Quote
Old 11-14-2009, 08:50 AM   #11361
bfong13's Avatar
Trader Rating: 17 (100%+)
Hi guys,
Hmmm...make sure your bladder is seated properly and that you don't have too much oil in the shock body.
The shocks should work fine with a small bleeder hole drilled in the caps and no rebound foam.
bfong13 is offline   Reply With Quote
Old 11-14-2009, 11:24 PM   #11362
Trader Rating: 3 (80%+)
Hey guy`s when you drill the shock cap what size hole roughly are you drilling and are you putting a screw in the hole once you are done bleeding the shock,Thanks in advance.
traitor is offline   Reply With Quote
Old 11-14-2009, 11:46 PM   #11363
pinggoy's Avatar
i used 1.5mm drill bit, and you dont need too put anything to the hole
TAMIYA TRF416X
Old 11-15-2009, 12:16 AM   #11364
pakk's Avatar
Trader Rating: 79 (100%+)
anyone using the exotek chassis for carpet?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 11-15-2009, 11:14 AM   #11365
MikeR's Avatar
Trader Rating: 14 (100%+)
Yes, Christer is along with a bunch of other big team drivers now
http://www.exotekracing.com/EXOTEK_N...NATIONALS.html
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 11-15-2009, 10:02 PM   #11366
LOSI123's Avatar
Trader Rating: 63 (100%+)
where can i get the one piece rear bulkheads that make the motor more in? and can they be used with the standard chassis and top deck
LOSI123 is offline   Reply With Quote
Old 11-16-2009, 01:37 AM   #11367
Redwood's Avatar
Check a post from 'Leg Iron' on the previous page.
The origional topdeck and chassis can be used with some modifications, you have to remove some material to allow the motor to move inward 5mm. Easy as pie to do with a dremel though.
Regards
Neal
Old 11-16-2009, 06:03 AM   #11368
Trader Rating: 38 (100%+)
I have a good deal on a TC5F in the for sale forum if anyone is interested.
On-Road Cleaning Out Sale! Lots of Items!
or8ital is offline   Reply With Quote
Old 11-16-2009, 06:19 AM   #11369
I kinda tempted to get the one-piece bulkheads, especially with my motor mount and left rear bulkhead being bent on my TC5r which is tweaking the chassis.
I'm currently doing the TRF style servo to my TC5r and one thing I'm thinking of, is it possible to do on the Exotek chassis? I made a slight mistake with the steering link ballstud and now I gotta drill another hole to move the ballstud forward so it doesn't hit the bulkhead. I just noticed the TRF servo allows more room for the ESC and Rx, awesome, no more mounting the Rx on its side.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 11-16-2009, 06:49 AM   #11370
The exotek chassis is too narrow to perform the mod and have both sides of the servo screwed to the chassis. You would need to do just one side and use servo tape. Perhaps someone could convince exotek to have a small bump out and pre-drill the holes for the mod in the next run of them.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
