Old 11-05-2009, 02:38 AM   #11311
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Originally Posted by Redwood View Post
By the sounds of it, it is probably droop. The TC5 comes with a droop gauge, but no blocks. I use a book, and sit the chassis on the right number of pages to match the droop gauge. Very primitive solution but it works.
While you are at it, unscrew all the bulkhead and topdeck screws, dont remove them, just loosen them. Then re-tighten them, that should remove the owrst of the chassis tweak if there is any, which can cause your car to not drive straight.
Regards
Neal
They were different on both sides and front and rear. It seemed to help, thanks for the sugestion.
I have been told in the past when you retighten the chassis screws to cris cross when you tighten them like torking an engine head or intake and to do it in small incramints or don't crank them down right away untill they are all seated snugly in the holes then torque them down all the way.
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
biscayne348@gmail.com or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 11-05-2009, 06:10 AM   #11312
Suspended
No need to criss cross when tightning as non of the parts are joined together, when doing the bulkheads I always tighten the middle screw until it just starts to pinch then the outside 2 the same, then fully tighten them.
Happy days
It's frightening to think that with modern medicine and all technique available to them, they can’t really help you; I should think in the old days you know you were better auf, because nowadays they’re all specialists, everyone’s becoming better and better at less and less! And eventually someone’s gonna to be superb, AT NOTHING!
Nick Priest is offline   Reply With Quote
Old 11-05-2009, 05:38 PM   #11313
mr crum's Avatar
Send a message via Yahoo to mr crum
your exactly right start in the middle and work your way out alternating left to right
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 11-05-2009, 05:43 PM   #11314
mr crum's Avatar
Originally Posted by Scottmisfits View Post
I don't use the droop gauge either. I use a down travel measurement. I set my ride height and then set the down travel.
Let's say I have a 5mm ride height and want 2mm of down travel. I use two ride height gauges and block the chassis up at 7mm (5mm+2mm). Now I adjust the droop screws until the tires "just" touch the set up board.
i use setup board and integy ride height/droop gauge set the car flat on the board then i go 5mm in the front 3mm in rear so after you put the tires back on you have a droop of 10mm or 5mm above ride height in the front and 8mm or 3mm above ride height in the rear
TEAM B.R. RACING
Old 11-07-2009, 04:06 AM   #11315
getpip's Avatar
Thumbs up Haloween Classic
Well done Mr Herbert.
Any set up sheets most welcome!
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 11-07-2009, 03:28 PM   #11316
xtrememadness's Avatar
Send a message via AIM to xtrememadness
congratulations on your win kevin by the way where did you get the cool black setup boards you guys were using.
CRAIG SANTRY / TAMIYA / TEAM ASSOCIATED / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / FUTABA / LRP / TEKIN / PROTOFORM / JACKSON RC / HORSHAM RC / EXOTEK RACING / REEDY
xtrememadness is offline   Reply With Quote
Old 11-07-2009, 05:27 PM   #11317
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
Default Buidling Tips...
Hey all, just picked up the TC5R this afternoon after about a 6 year absence from the RC scene.
Anyways, any tips to start with on building this car?
Thanks in advance.
wolfeman09 is offline   Reply With Quote
Old 11-07-2009, 05:43 PM   #11318
haywood's Avatar
Trader Rating: 48 (100%+)
Default TC5
http://redirectingat.com/?id=42X1295...90576640_o.jpg
Holy spur gear batman!
How many teeth?
Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 11-07-2009, 06:36 PM   #11319
pakk's Avatar
Trader Rating: 79 (100%+)
looks like 48p?
But what's with the white diff, does it do anything beside make me ask questions?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 11-07-2009, 07:30 PM   #11320
geeunit1014's Avatar
Just to be sure, the 1B arm mounts will put the arm Higher than 3A correct?
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 11-08-2009, 01:21 AM   #11321
How many teeth?
I'd would say that it's around 90 teeth 48p.
I don't know how but I've somehow managed to find a setup to works on low traction rubber/ashphalt while trying to get a setup for med traction rubber/ashphalt. But hey I'm not complaining.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 11-08-2009, 07:07 AM   #11322
hey sometimes the best setups are found on accident
Old 11-08-2009, 07:25 AM   #11323
Mind sharing that low traction rubber/asphalt setup? I've been after one myself. Slowly getting there but the car is still looser than I'd like.
spongerX is offline   Reply With Quote
Old 11-08-2009, 07:36 AM   #11324
Thanks in advance.
Stock up on extra diff bolts/nuts. Associated part # 6575. Around $2.90 or less at most places.
Put the diff spring in a vice grip or some sort of clamp for 1-2 hours to reduce the tension in it. It makes doing up the diffs a lot easier.
When putting the stock nylock diff nut in the plastic T piece make sure its fully seated at the bottom before trying to do up the bolt. Tap the nut in place with another tool first to fully seat it.
Be really careful tightening this bolt/nut combo. They strip super easily so it's good to have a couple spares on hand. Associated part # 6575 comes with the nut seated in the T piece already.
Other than the diff the car goes together really easily. I found drilling the shock caps with a really small drill bit helped me get zero rebound on the shocks. Theres a molded area on the cap that looks like this was planned but not done for some reason. Shocks work ok with just the bladder minus the foam pieces.
Old 11-08-2009, 08:21 AM   #11325
Hi!
What zero rebound give to you? What was wrong when you have some rebound before drill hole in shock cap?
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
