Old 11-03-2009, 04:41 PM   #11296
Airflow's Avatar
Originally Posted by geeunit1014 View Post
You may want to try the slipper spool in the front instead of a diff. You wont get any more drive than with a spool...
What yokomo diff balls are you using? Because the stock ones are not metric, they are 3/32". That may be causing you some issues..
Im using Yokomo 3/32 diff balls and diff thrust springs. Way cheaper
than AE's. Even with the original diff balls, I cant fully tighten it. it's smooth
now and not too loose but really prefer a little more tight. Ill try to sand
the area where the diff outdrives meet to give it more space to tighten.
Airflow is offline   Reply With Quote
Old 11-03-2009, 05:44 PM   #11297
twelvegauge's Avatar
Send a message via AIM to twelvegauge Send a message via MSN to twelvegauge
Default TC5's pulling left, Can't figure it out, NEED HELP
I have had my TC5's for a while now and cant figure out why they pull to the left when I accelarate. they go perfectly straight when I coast and evrything is tight and smooth. I checked the chassis for tweek and evrything else I can think of.
I use a spool in the front of both my cars. I did switch the belts around to make it easier to get my pinion out though. Can anyone help?
www.sycrcmaraceway.com
Maple Acres Raceway, SYC R/C Racing
I-Lap Timing System, R/C Scoring Pro
Replacement fans for esc's & heat sinks
biscayne348@gmail.com or 630-935-0132
twelvegauge is offline   Reply With Quote
Old 11-03-2009, 06:13 PM   #11298
LOW ET's Avatar
Trader Rating: 95 (100%+)
make sure you don't have a broken bone blade
LOW ET is offline   Reply With Quote
Old 11-03-2009, 08:16 PM   #11299
Ozzie's Avatar
Trader Rating: 23 (100%+)
Is there an easy way to tell the difference between the standard parts and hard parts? I have gotten mine mixed up and now can't seem to tell the difference.
Speedy Billls RC - www.speedybillsrc.com
Ozzie is offline   Reply With Quote
Old 11-03-2009, 08:17 PM   #11300
pakk's Avatar
Trader Rating: 79 (100%+)
I wouldn't call it an easy way, but they are different shades of black. Grab a known hard arm and a known soft arm. Put them next to each other in good light and you will see the difference.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 11-03-2009, 08:19 PM   #11301
Ozzie's Avatar
Old 11-03-2009, 08:22 PM   #11302
Imperfect weight balance?
I've had the car pull when the weight balance became unbalance when the fan was removed.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 11-03-2009, 08:23 PM   #11303
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
hard is a litttle shinny...
mine too but i just try to live with it,,,, compensate with steering trim...
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 11-03-2009, 10:22 PM   #11304
defcone's Avatar
Trader Rating: 15 (100%+)
The part where the pin goes into the dogbone, ther sides have worn down and have movement. I think that's where's causing the pulling to one side under acceleration on mine. Maybe give your's a check.
defcone is offline   Reply With Quote
Old 11-04-2009, 01:47 AM   #11305
Redwood's Avatar
Check your front droop is the same left to right first. If they are slightly out then the car will pull under acceleration but not during coasting.
Regards
Neal
Redwood is offline   Reply With Quote
Old 11-04-2009, 02:33 AM   #11306
Regards
Neal
That could be a possibility, I don't have droop blocks so I use my ride height tool to check it. They do seem a little different, I will have to figure out a way to make my own blocks for now just started a new job and haven't gotten paid yet. Thanks
Old 11-04-2009, 03:10 AM   #11307
Also the last race I wen't to I changed my shocks and the problem got worse, I never checked to see if they were all the same length. I bought them off e-bay rebuilt them and used em and never checked each one. The droop was a little off by a 1mm or 2 I will have to wait till I get home later to drive it.
Old 11-04-2009, 03:40 AM   #11308
Redwood's Avatar
By the sounds of it, it is probably droop. The TC5 comes with a droop gauge, but no blocks. I use a book, and sit the chassis on the right number of pages to match the droop gauge. Very primitive solution but it works.
While you are at it, unscrew all the bulkhead and topdeck screws, dont remove them, just loosen them. Then re-tighten them, that should remove the owrst of the chassis tweak if there is any, which can cause your car to not drive straight.
Regards
Neal
Old 11-04-2009, 07:12 AM   #11309
Scottmisfits's Avatar
I don't use the droop gauge either. I use a down travel measurement. I set my ride height and then set the down travel.
Let's say I have a 5mm ride height and want 2mm of down travel. I use two ride height gauges and block the chassis up at 7mm (5mm+2mm). Now I adjust the droop screws until the tires "just" touch the set up board.
Scottmisfits is offline   Reply With Quote
Old 11-05-2009, 01:45 AM   #11310
Redwood's Avatar
I had the chance to take a look at the fastest TC5 in my area at the weekend and noticed that the front and rear bulkheads were cut, to reduce front to rear stiffness.
After looking at the rear bulkhead designs of all the recently released chassis, it seems that a split rear bulkhead is the way to go. Look at the Mi4, Photon or T3 read bulkheads, all separate the rear diff holding bulkhead from the motor holding part.
So I am considering removing the upper bulkhead material from just behind the motor and the lower material from near the servo.
Has anyone else tried these mods? What effect if any did it have on the handling of the car, for carpet rubber or tarmac rubber.
Neal
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
