Old 10-29-2009, 06:02 AM   #11266
bfong13's Avatar
Trader Rating: 17 (100%+)
Originally Posted by M.Abramowicz View Post
Found this in internet
Pics from blog:
http://jdracing.blogs.se/2007/5/
Juho's car:
http://data4.blog.de/media/895/1472895_7b1d8c2bca_l.jpg
http://data4.blog.de/media/896/1472896_9290576640_o.jpg
Look to the Craig’s car:
http://data1.blog.de/media/003/1424003_7e7a917c26_o.jpg
Hm, which one steering linkage was better ??? Anybody know?
Regars!
m
Not sure which steering linkage was better, but I believe this is rather old. Juho's car isn't set up like that anymore.
bfong13 is offline   Reply With Quote
Old 10-29-2009, 06:25 AM   #11267
Scottrik's Avatar
Trader Rating: 240 (100%+)
Originally Posted by MoonTrap View Post
Is anyone changing out the steel axles/dogbones for lighter ones?, has anyone noticed it being faster to use lightweight / aluminum dogbones and axles from other manufacturers, have you noticed it being faster due to less rotating mass?
A couple things...
Firstly, like volume to like volume, titanium is significantly heavier than aluminum which is the material on the far-and-away bigger part of the CVD. Like about half again heavier. If you require proof of this put a similar size Ti screw and Al screw on a scale. Now if they "pare" down the titanium it will be similar weight, but then you've given up the strength advantage.
Replacing the outboard steel portion of the CVD with Ti would net something like a 20% reduction in weight (from a part that, on it's own, isn't particularly heavy) but as some are noticing Ti is usually (depending on alloy) somewhat more brittle than steel. Compound problem if threads are cut rather than rolled.
Finally, things like CV axles and driveshafts are where you'll see the LEAST benefit of lightening rotating mass because all the mass is very close to the axis of rotation--you're not "swinging" anything.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 10-29-2009, 06:44 AM   #11268
Trader Rating: 38 (100%+)
The Ti CVD/CVAs are the entire pieces through the axle. It is less than half the weight of the steel. Does anyone make an aluminum bone for the TC5? Might be OK for their rear of the car.
or8ital is offline   Reply With Quote
Old 10-29-2009, 06:59 AM   #11269
Warren Weaver's Avatar
Trader Rating: 43 (100%+)
The tir cvds are aluminum not titanium
R1 WURKS-AWESOMATIX USA-LRP-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 10-29-2009, 07:01 AM   #11270
S_fender's Avatar
These are Old pics from 2007.
Craig (Drescher) used current production parts.
Juho has "prototype" parts maid with TC4 parts (Shaft, steering hubs).
S_fender is offline   Reply With Quote
Old 10-29-2009, 07:22 AM   #11271
Scottrik's Avatar
In which case they've taken a weaker material and made the part weaker yet by removing material...it doesn't surprise me that people experience breakage. The ONLY way to get the part "less than half" is to have less material. Like volume for like volume, irrespective of alloying for either, the Ti piece should weigh approx. 20% less than a steel part.
And the fact remains that the rotational mass effect is virtually nil. You likely see a reduction in unsprung weight, particularly the mass out at the end, but unless your last name is Blackstock or Baker I'd be surprised if you could show me a difference on the clock...where it counts.
Old 10-29-2009, 08:08 AM   #11272
No disagreement. They are hallow so it is less material. Im talking about Ti Racing not Titanium the material.
Old 10-29-2009, 10:17 PM   #11273
Trader Rating: 19 (100%+)
Originally Posted by Ralph Walters View Post
Got my spur gear hub from them and I must say the machining on this is top notch. I've also heard that there will be more to come from them for our TC5.
zake540 is offline   Reply With Quote
Old 10-30-2009, 03:08 AM   #11274
Robert_K's Avatar
Guy's
I'm looking for the Losi LCD Dual Joint Drive Shafts.
I've been searching thru the JXS Manual and could find these parts.
Are these the parts the switch to dual joint axels or did I forget something:
A9757 C-Hubs / Hubs
A1233 C-hub bus / Kogels
A3333 LCD Drive Shaft's
A6365 Bearing Bus
A6916 Bearings
A6916 Bearings
Best Regards
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 10-30-2009, 06:53 AM   #11275
Super Moderator
racer1812's Avatar
Trader Rating: 28 (100%+)
I'm new to the whole TC thing and I need a little help. I've searched and can't find a constant answer to this question: What is a good starting FDR point with a 17.5 on a sweeping carpet track with the longest straight being only 50ft.? I'm gonna use 48p. Spur/pinion combo? Will RRP machined spurs fit? I know the spur hub uses 3 screws so I'm not sure and I don't have the car in my hands yet so I can't check myself. We run pre-mounts and need some input on what to get there too. We're just starting this class so it's not like I can ask anyone local. Thanks guys
Stop the hate! 'White Wheels Matter'
racer1812 is offline   Reply With Quote
Old 10-30-2009, 06:55 AM   #11276
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
Originally Posted by Robert_K View Post
Guy's
A9757 C-Hubs / Hubs
A6365 Bearing Bus
A6916 Bearings
A6916 Bearings
Best Regards
Robert
You'll also need the Losi hex's, and possibly the crush tube that goes between the bearings in the steering block.
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 10-30-2009, 07:07 AM   #11277
Get the tir tc5 stealth cvds they have the same angles as the lcds
Old 10-30-2009, 10:32 AM   #11278
Redwood's Avatar
I would start at around 4.5 and add teath depending on temps after your run. Hard to give solid numbers these days with all the various speedo options, timing etc.
As for spurs, I know that RW racing, associated and Kimbrough spurs all work, never dealt with RRP so I can't help you there. I run a 70T 48P RW spur and a 33T spur and it meshes fine.
Can't help with premounts though, as we run on wood here, kinda like ice racing, gotta have spiked tyres.
Regards
Neal
Redwood is offline   Reply With Quote
Old 10-30-2009, 11:18 AM   #11279
Super Moderator
racer1812's Avatar
Regards
Neal
Thanks for the input, got her in the mail and it has a different spur hub on it so I'm all good in that area. And I'm gonna go with 64p but thanks for the FDR input I'll just buy a bunch of gears and see what works, if nothing else I can use'm on my pan car.
Old 10-30-2009, 10:29 PM   #11280
I'm still new to the on road scene and grew tired of having to order cyclone parts when there is plenty of associated parts on the wall of my lhs. I've got a tc5r in route to me and was curious as to what lipos will fit with no mods. Or is it better to go with one of the lipo trays that I've seen. I think I saw somewhere that exotek, associated both have one. Amy recommendations? I've been running the protek 3800 30c lipo in my cyclone with no issues and no mods so I probably won't go much larger then a 3800. Will it fit without any mods? Is the tray more of a balance issue? One more thing, are there any must upgrade parts? Thanks!
AndysD8 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
