Old 10-16-2009, 12:27 AM   #11191
ChadB.'s Avatar
Trader Rating: 16 (100%+)
So which is better for this car. A 64 pitch or a 48 pitch?
ChadB. is offline   Reply With Quote
Old 10-16-2009, 01:07 AM   #11192
ronsand's Avatar
Originally Posted by traitor View Post
Hello , sorry I am new too on road/TC5R , a few posts back someone asked what was the best FDR for a TC5R with a NOVAK 17.5 and the response was 4.2-3.8FDR use a 72t or 75t spur 48p. When I put either of those spurs in there is not enough adjustment room in the motor mount too use the correct pinion(19t/20t) to get that FDR. Am I missing something , not doing something right. Could someone please help I`ve got my first race starting tommorow and I just need too know what spur/pinion is best too start of with for the 17.5 on a medium size track or what I`m doing wrong? Thanks too all this is a great thread keep up the good work all!!
use this gear chart: http://abram.eu.org/gear.php
Mugen MBX7 - Tekno V4 MBX6 - DEX410v3 - DEX210 - DESC410 - Serpent S411 - Futaba 4PKs - Tekin RX8 + RS Pro - Werks B6
ronsand is offline   Reply With Quote
Old 10-16-2009, 04:08 AM   #11193
chrisfrom619's Avatar
Send a message via Yahoo to chrisfrom619
64 pitch if you are racing on clean race track or permanent track and carpet track.
48 pitch for club racing, drifting and bashing around.
#1 Sponsor: Wifey
Hpi baja, traxxas e-maxx,slash, AE TC5R, RC18R,SC10, Thunder Tiger EB4 S2, and Futaba 4pk
DHW Raceway San Diego CA.
Novice Class
chrisfrom619 is offline   Reply With Quote
Old 10-16-2009, 04:53 AM   #11194
48p is good as its a little more foregiving then 64p. 48p is good on permanent tracks that are outdoor and get alot of dirt and dust on the track, I've picked up enough black gunge in my spurs/pinions/pully from the nitros.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 10-16-2009, 12:08 PM   #11195
ChadB.'s Avatar
So there is no performance advantage from one to the other?
Old 10-16-2009, 12:15 PM   #11196
Rick Hohwart's Avatar
if the gears are in good condition and meshed properly, the difference will be so small that you will not be able to notice. Although I beleive 64p will if anything be more efficient and allows finer adjustments.
I run 48p in modified all the time and have used it in 13.5 with good results.
Rick Hohwart is offline   Reply With Quote
Old 10-16-2009, 12:21 PM   #11197
ChadB.'s Avatar
Ok sounds good. Thanks for your help guys.I am still trying to learn everything.
Old 10-16-2009, 03:27 PM   #11198
bfong13's Avatar
Trader Rating: 17 (100%+)
For most applications, 48p is fine, however, 64p allows for more exact gear ratios. 64p gears are really necessary for pan cars when back in the day people were using nimhs, brushed motors, and had to really achieve exact gear ratios to make a 4-5 minute race, taking into account battery power, motor, and tire diameter of their foam tires. Foam tires change diameter practically after every run, so back in the day, exact gear ratios really mattered because nimh batteries didn't last as long or provide as much power as lipos.
The only advantage to 64p over 48p is being able to achieve a more exact gear ratio.
bfong13 is offline   Reply With Quote
Old 10-16-2009, 03:34 PM   #11199
ChadB.'s Avatar
I remember those times back then when using the 2000 cells in offroad, and they didn't last long. I couldn't imagine using them in a Tc now. This is good info here. These reason why I was asking this was because some were saying they use a 64 pitch. Also I think Ae is the only one that is using a 48 pitch. But it nice to know this stuff.
Old 10-16-2009, 04:39 PM   #11200
mr crum's Avatar
Send a message via Yahoo to mr crum
the downside to 64p gears are u have a greater chance of getting debris stuck in the mesh
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 10-16-2009, 04:44 PM   #11201
alb
Trader Rating: 19 (100%+)
I can remember using 1200's in 12th scale for 8 minutes! Anyone remember the phase "don't pull it all the way"
alb is offline   Reply With Quote
Old 10-16-2009, 05:03 PM   #11202
Scottrik's Avatar
Trader Rating: 240 (100%+)
And having to pay CLOSE attention to how often you tapped the boards...more than twice or so (depending if you had to start from a dead stop) and you may as well pull it in 'cause you weren't going to make it.
I've still got a couple Trinity 1/12 mod motors from '88 or so that we ran with those 1200SC batteries. Fabbed copper endbells and brushes the size of a grain of rice. Those were the days...NOT. Drove me to go race 1/8 onroad at the time because no need for battery voodoo.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 10-16-2009, 05:09 PM   #11203
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Anyone notice Levanen's TC5 at the ETS? He's got a new motor mount which allows motor to be put closer to center, and the servo is mounted Tamiya TRF 416 style. Are these his own tweaks or this is something AE is testing and plans to release?
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 10-16-2009, 07:35 PM   #11204
Suspended
His motor mount is a just a standard one modified to move it closer to the centre line of the car, a friend of mine machines bulkheads which do this making it similar to how a 416 is mounted.
Far stronger than the standard items as well
Pm me if you're interested.
Cheers Nick
It's frightening to think that with modern medicine and all technique available to them, they can’t really help you; I should think in the old days you know you were better auf, because nowadays they’re all specialists, everyone’s becoming better and better at less and less! And eventually someone’s gonna to be superb, AT NOTHING!
Nick Priest is offline   Reply With Quote
Old 10-16-2009, 11:10 PM   #11205
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
I finally got my car hooked up perfect tonight...thanks fr all the great posts and advice guys...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
