Old 10-15-2009, 07:19 PM   #11176
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Originally Posted by Scottrik View Post
Previous poster is correct. Multiplication and division have the same precedence so they are performed left to right. Same holds true for addition and subtraction once all the other operations are out of the way.
P(lease)
E(xcuse)
M(y)
D(ear)
A(unt
S(ally)
is the pnemonic we use to teach the order of operations, generally 6th-8th grade math. P(arenthese or grouping symbols), E(xponents), M(ultiplication and/or D(ivision) left to right, A(ddition) and/or S(ubtraction) again from left to right.
Doesn't matter if calculating gear ratios or whatever. To experiment try your hypothesis out...do the indicated multiplication first and then the division. You will end up with a very different (MUCH smaller, something just a bit over 1.0 in fact) result.
I always calculate it Spur x internal/pinion.
IIGQ4U is offline   Reply With Quote
Old 10-15-2009, 07:20 PM   #11177
Originally Posted by Nick Priest View Post
64/32 would give you 4
61/32 would give you 3.8
Those two ratios won't mesh at all, I've tried 63/35 and the was a massive gap between the spur and pinion, I had to go to 63/38 just to get some meshing.
For running a 17.5, especially without turbo/timing advance, you'll need some big pinions. I'm currently using 70/34 which as room to go either way with the ratios and I'm thinking of going 70/35. This is for a track that takes up two tennis courts. But I'm also using a Tekin RS with the 200 software.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 10-15-2009, 07:27 PM   #11178
Scottrik's Avatar
Trader Rating: 241 (100%+)
Which is yet another way to Tipperary as long as you perform the order of operations as you've written them. Again, do them anything but left to right and you'll be at sea.
Especially with roll-out there are several base formulas you can start with depending what the variable is that you don't know...just keep manipulating the formula algebraically.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 10-15-2009, 07:32 PM   #11179
revo61's Avatar
Trader Rating: 18 (95%+)
I thought it was (spur/pinion)x internal
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 10-15-2009, 07:37 PM   #11180
Scottrik's Avatar
Your parens are redundant...you would perform the division first.
AGAIN--there are often several ways to express a formula that will get you to the same result.
Suppose spur 108
Pinion 46
Internal 2.0
spur / pinion x internal yields 1.348 x 2.0 = 4.7
OR
spur x internal / pinion yields 216 / 46 = 4.7
Old 10-15-2009, 07:48 PM   #11181
Suspended
Who cares
Long as you get the answer it doesn't matter
It's frightening to think that with modern medicine and all technique available to them, they can’t really help you; I should think in the old days you know you were better auf, because nowadays they’re all specialists, everyone’s becoming better and better at less and less! And eventually someone’s gonna to be superb, AT NOTHING!
Nick Priest is offline   Reply With Quote
Old 10-15-2009, 07:59 PM   #11182
Lebatek's Avatar
Send a message via AIM to Lebatek
But what did Aunt Sally do??
John Lebak
Sponsored by: Team Associated, Reedy, Airtronics, LRP, and Mugen
Lebatek is offline   Reply With Quote
Old 10-15-2009, 08:00 PM   #11183
Scottrik's Avatar
What you're playing with, algebraically, is across the equals sign. As long as I perform the same operation on both sides I can make an infinite number of equations that will get to the same point. If I multiply both sides by a gajillion the equation looks quite different but yields the same result, thus there are truly an infinite number of ways the formula could be written yet produce the same.
We were given two variants of the formula, though, that are wonderful if you have a bunch of bits you've thrown together already and want to know what the FDR is. I would argue that more often we know the target FDR we want, the internal ratio is a given (can't be changed), and we'd really rather not change the spur unless we absolutely have to. What we USUALLY need to find out is the pinion that will yield the desired FDR. To do so we need to manipulate either of the formulas we've been given (and shown to work) which segregate FDR on one side and get them to show the pinion as segregated on one side.
Let's start with the first formula we were given (easier to get the desired result) and see how we can manipulate it to churn out the pinion we need to hit a desired FDR given internal ratio and spur.
spur x internal ratio / pinion = FDR
Multiply both sides by pinion and we have
spur x internal ratio = FDR x pinion
Now divide both sides by FDR
spur x internal ratio / FDR = pinion
Which I would argue, again, is far more useful in more "real world" situations.
Try it with the numbers I used in my previous example (the stuff that's on my VTA car).
Old 10-15-2009, 08:03 PM   #11184
Scottrik's Avatar
See...NOW you're starting to sound like one of my seventh graders
I believe she farted. Why else would she need to be excused?
Old 10-15-2009, 08:17 PM   #11185
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
really guys??!!!
pinggoy is offline   Reply With Quote
Old 10-15-2009, 08:21 PM   #11186
revo61's Avatar
I know they are redundant, but I wanted to make sure they knew to do it first. I never knew you could do it the other way. Learned something new thanks.
Suppose spur 108
Pinion 46
Internal 2.0
OR
Old 10-15-2009, 09:10 PM   #11187
geeunit1014's Avatar
My physics teacher always said it was please excuse my dumb arrogant students
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 10-15-2009, 09:18 PM   #11188
Scottrik's Avatar
Seems kinda harsh...then again if he's saddled with PHYSICS students who need reminders re: the order of operations I can probably understand his frustration.
Old 10-15-2009, 09:27 PM   #11189
Trader Rating: 75 (100%+)
I had a science teacher who asked us to prove the law of gravity. We threw out the 2nd story window.
MUDVAYNE is offline   Reply With Quote
Old 10-15-2009, 09:29 PM   #11190
Suspended
That's highly amusing.
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
