Old 10-15-2009, 02:44 PM   #11161
Trader Rating: 38 (100%+)
Originally Posted by mr crum View Post
after loosin a main qualifying position sunday im back with the solid spool the slipper loosened up with thrust bearings and all
Did you use the TC3 diff screw and nut? That usually solves it.
or8ital is offline   Reply With Quote
Old 10-15-2009, 03:05 PM   #11162
mr crum's Avatar
Send a message via Yahoo to mr crum
i use the diff screw and t nut from a t3 so i dont know i know that wen ur slipper spool loosens up the car goes to crap
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 10-15-2009, 03:12 PM   #11163
Yeah it doesnt handle for anything as it is likely going from 4wd to 2wd.
Old 10-15-2009, 04:33 PM   #11164
cyclone x's Avatar
but other then that its a great car so good luck man
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 10-15-2009, 04:50 PM   #11165
Trader Rating: 3 (80%+)
Default HELP/CONFUSED
Hello , sorry I am new too on road/TC5R , a few posts back someone asked what was the best FDR for a TC5R with a NOVAK 17.5 and the response was 4.2-3.8FDR use a 72t or 75t spur 48p. When I put either of those spurs in there is not enough adjustment room in the motor mount too use the correct pinion(19t/20t) to get that FDR. Am I missing something , not doing something right. Could someone please help I`ve got my first race starting tommorow and I just need too know what spur/pinion is best too start of with for the 17.5 on a medium size track or what I`m doing wrong? Thanks too all this is a great thread keep up the good work all!!
traitor is offline   Reply With Quote
Old 10-15-2009, 04:56 PM   #11166
cyclone x's Avatar
switch to 64p and like a maybe a 90T spur
Chase Chandler
Old 10-15-2009, 05:04 PM   #11167
AeRacer805's Avatar
A 100 spur with a 52 pinion puts your FDR right at 3.8
"When you are not practicing someone else is and when you meet that person they will beat you."
TC6, Top Photon, B4.1, SC10 FT, Orion Motors and Servos, Tekin RS
AeRacer805 is offline   Reply With Quote
Old 10-15-2009, 05:07 PM   #11168
cyclone x's Avatar
the FDR really depends on ur track because at my track the 17.5 guys role with a 4.6 FDR
Chase Chandler
Old 10-15-2009, 05:08 PM   #11169
Suspended
Are you sure you have worked it out correctly? 72/20 is 7.2 overall..
72/34 would give you 4.2
64/32 would give you 4
61/32 would give you 3.8
It's frightening to think that with modern medicine and all technique available to them, they can’t really help you; I should think in the old days you know you were better auf, because nowadays they’re all specialists, everyone’s becoming better and better at less and less! And eventually someone’s gonna to be superb, AT NOTHING!
Nick Priest is offline   Reply With Quote
Old 10-15-2009, 05:11 PM   #11170
First off thanks for all your help.To be totally honest with you Im not exactly sure how too figure out FDR if you could tell me how you do it that would be much appreciated
Old 10-15-2009, 05:14 PM   #11171
Suspended
To work out FDR you do
Spur / Pinion x internal ratio..
Example...
72 / 34 = 2.11
2.11 x 2 (tc5 internal ratio) = 4.23 FDR
Old 10-15-2009, 05:24 PM   #11172
Thank You!
Old 10-15-2009, 05:29 PM   #11173
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Example...
72 / 34 = 2.11
In the order of operations doesn't multiplication precede division? Though I suppose in the case of calculating gear ratio, it doesn't affect the outcome.
IIGQ4U is offline   Reply With Quote
Old 10-15-2009, 06:06 PM   #11174
geeunit1014's Avatar
They are on the same order, so if if you have them both, you just go left to right
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 10-15-2009, 07:14 PM   #11175
Scottrik's Avatar
Trader Rating: 243 (100%+)
Previous poster is correct. Multiplication and division have the same precedence so they are performed left to right. Same holds true for addition and subtraction once all the other operations are out of the way.
P(lease)
E(xcuse)
M(y)
D(ear)
A(unt
S(ally)
is the pnemonic we use to teach the order of operations, generally 6th-8th grade math. P(arenthese or grouping symbols), E(xponents), M(ultiplication and/or D(ivision) left to right, A(ddition) and/or S(ubtraction) again from left to right.
Doesn't matter if calculating gear ratios or whatever. To experiment try your hypothesis out...do the indicated multiplication first and then the division. You will end up with a very different (MUCH smaller, something just a bit over 1.0 in fact) result.
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
