Old 10-14-2009, 06:45 AM   #11146
Castradamus's Avatar
Trader Rating: 53 (100%+)
I have general questions. What washers / shims are you using to adjust the bumpsteer? Is anyone using anything other than plastic for the wheelbase and inboard toe / width? Please post part # for anything you are using. Thanx
Destiny | Xenon USA | Speedzone | High Velocity RC | TQ Wire | dIgItS pAiNt
He who is not courageous enough to take risks will accomplish nothing in life. - Muhammad Ali
Castradamus is offline   Reply With Quote
Old 10-14-2009, 07:55 AM   #11147
geeunit1014's Avatar
Associated PN 31286 has 4 2mm and 4 1mm shims. Normally on the setup sheet youll see black/silver (the ballstud) + the mm shim. You can also use them for wheelbase if you wish (just a bling factor really ). I use them for toe as well. Easier to keep track of how many mm's are in vs what * shim is in, plus the plstic shims can get squished, and then the value changes.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-14-2009, 09:43 AM   #11148
bfong13's Avatar
Trader Rating: 17 (100%+)
What washers/shims are people using for the hex spacing? I see on some set-up sheets from the factory drivers that sometimes they change the hex spacing. What are the part numbers for the hex spacing shims?
bfong13 is offline   Reply With Quote
Old 10-15-2009, 07:10 AM   #11149
I recently got back into the sport and just finished building a TC5R. How do I set the camber on it with all the suspension slop? I was checking it with a Hudy setup system and there appears to be 2 degrees of camber play front and rear. I've tried replacing the stock ball ends with RPM heavy duty ones which removed some of the slop but the rest seems to be coming from the bearings. Is there any way to remove this play?
If I set the camber at -1.5 it deflects to +0.5 if I push the car sideways like what happens in a corner.
Do I set the camber based on cornering loads or straight line loads where the tire isnt under any side loading?
spongerX is offline   Reply With Quote
Old 10-15-2009, 07:43 AM   #11150
pcar951's Avatar
Trader Rating: 19 (100%+)
I always set my car up on the Hudy board using static values. It's true that settings deflect under load but I've never had a problem. My Xrays are probably worse than my TC5R. I just ignore a little slop, hey it's better than things binding.
pcar951 is offline   Reply With Quote
Old 10-15-2009, 08:51 AM   #11151
Trader Rating: 62 (100%+)
I use Tamiya wheel shims .I don't know the part # sorry
The Wease is offline   Reply With Quote
Old 10-15-2009, 12:41 PM   #11152
ChadB.'s Avatar
Trader Rating: 21 (100%+)
I just picked up a TC5 yesterday second hand and I was wondering if there is anything I would need for the car besides the usual spare parts. Also, I'm not sure if this has been asked, but I have seen a lot of the set-up pages on AE website and it seems that a lot of the drivers are using the slipper spool. What's the difference between the slipper spool and the regular spool?
ChadB. is offline   Reply With Quote
Old 10-15-2009, 12:43 PM   #11153
cyclone x's Avatar
be sure to build the shocks right the first time
Chase Chandler
Sponsors:HOTBODIES Express .The Track. Stevo Racing
Cars: VE8, F104 PRO, B4.1, HPI BLITZ, Losi SCTE
cyclone x is offline   Reply With Quote
Old 10-15-2009, 12:46 PM   #11154
Scottmisfits's Avatar
The slipper spool will give a slight slip when you nail a board. It's almost like running your diff really, really, really tight. Just less chance of snapping the diff screw.
Scottmisfits is offline   Reply With Quote
Old 10-15-2009, 12:56 PM   #11155
ChadB.'s Avatar
Is there any difference between the offroad shocks and tc shocks, the way they are set up? Most of my experience is in offroad, so that is why I am asking. I plan using the MIP shock o-rings, like Rick said to use in the other thread.
Is there any performance advantages from the slipper spool to the regular spool? Or is it just a safety thing so you are not breaking a part.
Old 10-15-2009, 01:25 PM   #11156
Scottrik's Avatar
Trader Rating: 245 (100%+)
All right, I give up. Where have Associated hidden the team driver setup sheets on their site?
Many thanks,
Scottrik
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 10-15-2009, 01:27 PM   #11157
Go to racing up in the top bar. Then right below the RC10 logo is another selection bar. Click set ups. Then pick the type of vehicle or the driver.
Old 10-15-2009, 01:28 PM   #11158
Trader Rating: 38 (100%+)
Many thanks,
Scottrik
http://www.rc10.com/racerhub/setup/0setups_tc5.htm
but there are some elsewhere such as:
http://67.199.85.166/racing/setups.php?modelname=TC5
or8ital is offline   Reply With Quote
Old 10-15-2009, 02:35 PM   #11159
mr crum's Avatar
Send a message via Yahoo to mr crum
after loosin a main qualifying position sunday im back with the solid spool the slipper loosened up with thrust bearings and all
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 10-15-2009, 02:42 PM   #11160
ChadB.'s Avatar
Is this something that happens often?
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
