Old 10-05-2009, 09:48 PM   #11056
Originally Posted by Nick Priest View Post
Muppet
WTF????
These are Muppets.
MonkeyFist is offline   Reply With Quote
Old 10-05-2009, 09:51 PM   #11057
fatbear's Avatar
Send a message via Yahoo to fatbear
Guys, as I said earlier, the motor mounts do bend easily. You may not even notice the hit that makes them bend. they are only fixed by three points and they have alot of weight(the motor) hanging out from them. A hit on the end of the motor would create alot of leverage.
Please everyone take of your motor mount and check them on a flat surface. I guarantee at least a few of you will find they are bent.
Team Tekin www.teamtekin.com
B-Fast R/C Performance www.bfastrc.com
AKA www.raceaka.com
Ryper Hobbies www.ryperhobbies.com.au
fatbear is offline   Reply With Quote
Old 10-05-2009, 09:51 PM   #11058
Suspended
Originally Posted by MonkeyFist View Post
WTF????
These are Muppets.
Eugh... i'm not even going to attempt to explain or waste my time insulting you thoroughly.
It's frightening to think that with modern medicine and all technique available to them, they can’t really help you; I should think in the old days you know you were better auf, because nowadays they’re all specialists, everyone’s becoming better and better at less and less! And eventually someone’s gonna to be superb, AT NOTHING!
Nick Priest is offline   Reply With Quote
Old 10-05-2009, 09:54 PM   #11059
One thing I've been thinking of with the standard mount when/if it take a hit hard enough to bend it means the mount takes alot of the shock of the impact, where as the bulkhead with the motor mount were to get hit by the same impact and not bend, where would the car absorb the impact?
I did find that running the standard mount useful the other day as I was having a electronic problem in one car all I did was take the motor mount out and swapped with the one in my other TC5 while leaving the motor still attached to the mount, 2 screws and 3 solder joints and I had moved a motor to another car with needing to re-mesh the pinion and spur.
EDIT: Woah this thread is moving fast.
Team Associated B5m | Team Associated T5m | Team Associated TC6 | Team Associated TC5x
Scooter79rs is offline   Reply With Quote
Old 10-05-2009, 10:02 PM   #11060
Verndog's Avatar
Trader Rating: 16 (100%+)
Verndog... my car HAS taken a huge hit in the side which tore open part of the chassis and split under where the motor sticks out, the bulkhead came off perfectly straight with no tweak..... just split carbon fibre weaving sticking out all over the place!!
Do I have to provide pictures for that as well LOL
No pictures required. So you have just proven my point by your own admission.
Would you rather replace this $12.00 motor mount with the old TC5 design...or the $60.00 chassis with your new design...provided the posted pic was really straightened and driven as you said yourself.
http://www3.towerhobbies.com/cgi-bin...?&I=LXRUR3&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXRUP3&P=7
I suggest your buddy find a new "spokesperson"....this one is all buggered down...whatever that means...
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 10-05-2009, 10:15 PM   #11061
robk's Avatar
Trader Rating: 22 (100%+)
These cars will bend bulkheads, just like the Corally cars, Xray cars, etc.etc.
If you take your car apart, you will probably have a bent bulkhead. It won't be visible to the eye, but if you rock it on a table, you'll see it's not 100% flat. RDX cars were notorious for this, so it has nothing to do with design, more to do with high speed wrecks.
Also, I guarantee the one piece bulkhead would bend as well on a hit that made a potato chip out of that motor mount. If that really came off of a car like that you'll be needing a chassis and top plate as well
BTW why can't you guys make the bulkhead so it takes the plastic carriers for the layshaft bearings? That's about as bad as getting the diff out of a HPI pro2
Old 10-05-2009, 10:20 PM   #11062
pakk's Avatar
Trader Rating: 79 (100%+)
Agree, but I think the reason was to keep the spur lower. I don't know about you guys, but if I could, I'd rather have my TC5 spur lower.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 10-05-2009, 10:25 PM   #11063
Trader Rating: 75 (100%+)
How about the added benefit over moving the motor over to better balance the car. have you thought of that?
MUDVAYNE is offline   Reply With Quote
Old 10-05-2009, 10:31 PM   #11064
Verndog's Avatar
My guess is because they are a better design for balance and weight distribution, hence potentially faster...not because the TC5 bulkheads are inheritantly weak in design and people are bending them often....as your posts suggest.
I still say a hit that would bend that motor mount to that extent would ruin the chassis or worse if the new mount didn't give way...that can easilly be seen IMO.
Keep reading. It would appear so.
I was only questioning the "sales pitch" on what is really gained in strength, and the potential impact of a more rigid design.
---Team Hoarders---
Old 10-05-2009, 10:33 PM   #11065
oh, my bad. sorry bra.
Old 10-05-2009, 10:38 PM   #11066
Suspended
The bulkheads had NOTHING to do with the chassis splitting, END OF!, If anything it's to do with the inferior quality carbon fibre that associated use. The gentleman who had the bent standard motor mount split the chassis under the motor mount on his outdoor car using the standard motor mount and bulkhead, says a lot for the quality of associated.....
Old 10-05-2009, 10:41 PM   #11067
Suspended
Also may I add that was without impact, it quite literally came apart for no reason.
Old 10-05-2009, 10:45 PM   #11068
Scottmisfits's Avatar
Well then why make parts, or promote parts for a car that's a piece of crap?
Stay out of this thread. You have not helped anyone and just started a bunch of trouble.
Let's try and get back to post's that might actually help and PROMOTE a great car like the TC5, what this thread is about anyway.
Scottmisfits is offline   Reply With Quote
Old 10-05-2009, 10:52 PM   #11069
robk's Avatar
Sounds like user error
Old 10-05-2009, 10:53 PM   #11070
Suspended
Because the car has great potential once the factory issues have been addressed. Also I believe you will find I do not cause the trouble only defending the product against a bunch of people who don't even have experience of it!
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 02:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 08:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 09:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 01:54 PM
SEO by vBSEO 3.5.0
