Old 09-30-2009, 10:13 PM   #10936
pakk's Avatar
Trader Rating: 79 (100%+)
Are you just making new holes to mount the servo and mount? What kind of bit are you using to countersink the chassis?
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
Old 10-01-2009, 07:37 AM   #10937
Suspended
Default Servo Mod
remove your sevo and akerman assembly
shave off the existing servo link mount
(Where your steering link used to snap on)
Carefully drill a fifth hole in the akerman using an 1/8" drill bit, centered left to right
(it should be drilled behind the existing holes, Besure it will clear both tie rods when steering extreme left and right)
Place your servo so that the horn is furthest from the Bulkhead(closest to the tire)
Carefully mark the center of each hole of each servo mounts (mounts should be fasten tightly to servo)
Drill out marks with an 1/8 inch drill bit (drill slowly as not to flake the fibre when penatrating bottom of chassis)
With a counter sink bit (lowes,home depot) counter sink bottom of chassis
Install akerman and servo adjust linkage as needed
Good Luck!
BOSS RC MOTORSPORTS
Horsham Rc; Horsham, PA
Trains and Lanes Raceway; Easton, PA
Jackson RC; Jackson, NJ
X_________________________________________________ _Nathan "Nate" Laskey
Quiet Storm is offline   Reply With Quote
Old 10-01-2009, 11:36 AM   #10938
speedsterblade's Avatar
Originally Posted by or8ital View Post
At the rate in which everyone is moving to the Exotek chassis and modifying/buying new bulkheads perhaps Associated should investigate making a TC5R-LS (lipo spec).
Changes could be:
-Narrow rear bulkheads
-New chassis (narrower, modified for new bulkheads, lipo weights included, optional holes for the Keven servo mod)
-New upper deck for the narrow bulkheads
-Revised one-way in which the pulley could easily be mounted for a flipped belt configuration
-Revised steering to optionally allow for Keven servo mod
-Anything else?
Other changes could include:
-More flexible belts??
Seems like it could even be offered as an upgrade kit.
I'd buy a LS (if resonally priced) instead of having to do it all yourself. I'll be glad when the chassis are designed w/ lipo's, heavier brushless motors and mass centralization in mind from the start of design... I heard some of the other manufactors have this in the works but duno for sure... mass centeralization has proven itself in many other forms of racing for years now. RC just needs to ketchup.
#47 MoneyShot Racing
www.nashrcracer.com
http://thunder.rc50.com/
SMC - Customer Service 2nd to None! (thanks Dan!!)
speedsterblade is offline   Reply With Quote
Old 10-01-2009, 12:27 PM   #10939
revo61's Avatar
Trader Rating: 18 (95%+)
Its here already, its called the Losi JRXS- R.
http://www.losi.com/Products/Feature...rodId=LOSK0256
JQ The Car Black Edition/Reds R7E/Reds 2113 pipe
Airtronics MT44/Savox servos
Sidewinder Team Strike V2 30%
USA.JQRACING.COM / WWW.NEMORACINGUSA.COM
revo61 is offline   Reply With Quote
Old 10-01-2009, 12:44 PM   #10940
Trader Rating: 76 (100%+)
Hey guys I have a Exotek chassis, battery brace, and one peice rear bulkheads for sale.
TC5 w/ Exotek Chassis-Brace and One Piece Bulkheads
MUDVAYNE is offline   Reply With Quote
Old 10-01-2009, 12:56 PM   #10941
poochy's Avatar
is there a way to tell if the arms are hard or soft type?
poochy is offline   Reply With Quote
Old 10-01-2009, 01:12 PM   #10942
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
No, Its called the Shumacher MI4
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 10-01-2009, 01:31 PM   #10943
Thanks! Very interesting...definitely centralized! the speedo location could be an issue depending on what you got and if you need a fan... gotta be a cake job to balance it!
www.nashrcracer.com
Old 10-01-2009, 03:16 PM   #10944
Default Metric or imperial ?
Hi. Just wondering. Does the TC5R use metric or imperial screws ? I'm in a country in which i can't get anything imperial so that can make the difference in my decision to get one or not.
Storm_PT is offline   Reply With Quote
Old 10-01-2009, 03:20 PM   #10945
mr crum's Avatar
Send a message via Yahoo to mr crum
the tc5 is the first associated car ever to be metric so you will b just fine
SPEED PASSION TEAM DRIVER
ADAB RACING FACTORY PILOT
WWW.ADRENALINERACEWAY.COM
FL INDOOR R/C COMPLEX
TEAM B.R. RACING
mr crum is offline   Reply With Quote
Old 10-01-2009, 03:49 PM   #10946
Nice to know. I asked because i checked out the parts list for the TC5 in Associated's site and there were imperial screws there.
Here: http://67.199.85.166/main/maincatego...&nav=on1.10nav
Stuff like "Droop Set Screws, 10-32 x 5/16", "Precision Diff Thrust Ball, 5/64", etc...
Old 10-01-2009, 04:09 PM   #10947
Ignore my last post. Just skimmed over the manual for the TC5R and theres only one mention of a 0.50" screw driver and i can't find where its used.
Perfect.
Old 10-01-2009, 07:55 PM   #10948
rezenclowd3's Avatar
Send a message via AIM to rezenclowd3
I believe its used for the battery strap screws. I stopped using the battery strap for multiple reasons, but that is one.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 10-01-2009, 08:39 PM   #10949
pakk's Avatar
Instead of a whole new car, I'd like to see associated to come out individual upgrade parts.
But until, I will mod away. I'm going to give the servo mod a shot.
--pakk
*Photon* *SC10 4x4*
RCRD
Old 10-02-2009, 02:46 PM   #10950
Midnight's Avatar
Trader Rating: 85 (100%+)
I did a search and came up empty. Trying to decide which to one to go with, tc5r or f. I plan on racing on indoor concrete and carpet.
RC8T; Losi 2.0B; FT T4; AKA & RB
Hoffman Photography, www.carolinasrc.com
Midnight is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
